O...m...g...!!! - Framing - Contractor Talk
O...m...g...!!!
Old 01-22-2012, 06:51 PM   #1
Shingler extraordinaire
A&E Exteriors's Avatar
Trade: Roofing, Decks, Additions
Rewards Points: 15,154
O...m...g...!!!
So, I'm doing a frozen new construction roof on a single story with a walkout basement. Now I haven't framed a whole house sense november of '06 so it's been awhile. Anyway, I noticed this whole frame is 24" oc , exterior/ common garage walls are 2x6 , all interior walls and garage walls are 2x4.
Has framing really changed that much in 5 1/2 years?
A&E Exteriors is offline
Old 01-22-2012, 06:52 PM   #2
Re: O...m...g...!!!
And the guys doing the framing butchered it....sub of sub of sub....
Old 01-22-2012, 06:56 PM   #3
Gen. Contractor
Ninjaframer's Avatar
Trade: Residential Light commercial
Rewards Points: 2,610
Re: O...m...g...!!!
I've seen a ton of farm loan homes framed 24" o.c. Fast and cheap doesn't leave room for good.
"slow makes smooth, smooth makes fast"
Ninjaframer is offline
Old 01-22-2012, 06:57 PM   #4
WildWill's Avatar
Rewards Points: 504
Re: O...m...g...!!!
It seems this is the way things are spec'd now now. My last one was spec'd like that and I changed it on site.
WildWill is offline
Old 01-22-2012, 07:02 PM   #5
Re: O...m...g...!!!
Pure crap if you ask me.
Old 01-22-2012, 07:04 PM   #6
Re: O...m...g...!!!
Sometimes I wish I was able to apprecatethe first two framing crews I worked for when I worked for them. They were really really good.
Old 01-22-2012, 07:06 PM   #7
JBM's Avatar
Trade: Masonry
Rewards Points: 10,920
Re: O...m...g...!!!
220 221 whadtever it takes!
JBM is offline
The Following User Says Thank You to JBM For This Useful Post:
chris klee (01-22-2012)
Old 01-22-2012, 07:27 PM   #8
JT Wood's Avatar
Trade: carpenter
Rewards Points: 2,560
Re: O...m...g...!!!
it's not uncommon here, what is the specific problem you have with it?
Airdrie AB Renovation Contractor | Kitchen Renovations | Basement Developments | Facebook
JT Wood Construction Serves Airdrie, Cochrane, Olds, Mountainview, Rockyview and Crossfield, Alberta.
JT Wood is offline
Old 01-22-2012, 07:38 PM   #9
Ciaos mitigator
chris klee's Avatar
Rewards Points: 1,290
Re: O...m...g...!!!
i have seen a couple houses framed 24" oc and it was called being green. it allows more insulation and less thermal bridging.
sounded like a good excuse for being cheap
CK Carpentry
chris klee is offline
The Following User Says Thank You to chris klee For This Useful Post:
CanningCustom (01-22-2012)
Old 01-22-2012, 07:39 PM   #10
Ciaos mitigator
chris klee's Avatar
Re: O...m...g...!!!
my issue is the drywall inside is usually still 1/2" and it waves between the studs. esp the ceilings
CK Carpentry
Old 01-22-2012, 07:40 PM   #11
Gen. Contractor
Re: O...m...g...!!!
The lids are 5/8 right?
Old 01-22-2012, 07:54 PM   #12
Re: O...m...g...!!!
Doesn't look right, looks cheap. Cost savings has to be bare bones minimal. The fact that the "framers" should work at a meat market probably has a little to do with it, but I don't like it. Mostly I guess it looks cheap.
It just reenforces the idea that I will have to frame my own house one day, or buy the one I'm in now and add an upstairs.
Old 01-22-2012, 07:57 PM   #13
Gen. Contractor
Re: O...m...g...!!!
I wouldn do it on my house but if everything stacks like it should (joist, stud, truss/ rafter) its still structurally sound. You just can't find a stud to nail your family picture up is all.
Old 01-22-2012, 08:25 PM   #14
Ciaos mitigator
chris klee's Avatar
Re: O...m...g...!!!
not the couple i saw around here. 24" trusses with 1/2 rock in the whole house. tract houses of course.
CK Carpentry
Old 01-22-2012, 09:02 PM   #15
JustaFramer's Avatar
Trade: Exiled For Life
Rewards Points: 2,000
Re: O...m...g...!!!
With truss joists for the floor layout at 2' oc. I don't see a point to 16" oc. Nothing stacks anymore and there is no rim joist on the perpendicular of these truss joists. House tract framing is cobbled together junk.
JustaFramer is offline
Old 01-23-2012, 04:37 PM   #16
TSHIELDS's Avatar
Trade: Builder/Carpenter
Re: O...m...g...!!!
In my area 16 oc exteriors and sometimes 24 or 19.2 interiors
TSHIELDS is offline
Old 01-23-2012, 04:57 PM   #17
Framer53's Avatar
Trade: Handyman
Rewards Points: 366
Re: O...m...g...!!!
Are we living in the past gentlemen?
houses for a long time have been way over engineered for strength. Now it happens to be that houses are more economical to heat and cool with 2'centers.
if you build on 2' centers around here, we use 5/8 rock to prevent the interior waves.
you better get used to the fact that in the future this will become the norm not the exception it is today.
I am old enough to remember that in the 50=60's plywood was looked on as terrible way to build and cheap. Funny thing is those houses for the most part are still standing.....
Framer53 is offline
The Following User Says Thank You to Framer53 For This Useful Post:
WildWill (01-23-2012)
