Need Math Help From The Gurus ;) - Framing - Contractor Talk
Thread Tools
Old 12-06-2015, 02:23 PM
Gen. Contractor
Ninjaframer's Avatar
Trade: Residential Light commercial
Rewards Points: 2,610
So I'm building a 10,000 sq ft monster with a spiral staircase in a 3 story cylindrical turret with pinnacle roof (witches tit is what I've always called it but anyway...)
Here's my math question:
What is the formula for finding the arc length of a segment starting from only having the radius and chord length known?
Especially when the angles aren't 90,45,45?
For instance with a circle with a radius of 6' and a chord length of 7' what is the arc length?
And remember- I haven't got any formal math education so keep it simple- I have a basic understanding of trig functions but I'll need to be walked through
By the way- havnt seen yall in awhile just been swamped. I went from a 2-3 man show doing a few homes a year to doing over a dozen a year and being president of the local HBA. It's been a ride Name:  ImageUploadedByContractorTalk1449429786.419484.jpg
"slow makes smooth, smooth makes fast"
Ninjaframer is offline
The Following 8 Users Say Thank You to Ninjaframer For This Useful Post:
asevereid (12-06-2015), AustinDB (12-17-2015), Calidecks (12-06-2015), CENTERLINE MV (12-09-2015), hdavis (12-09-2015), Jaws (12-06-2015), KAP (12-06-2015), Railman (12-08-2015)
Old 12-06-2015, 02:26 PM
Always Learning
overanalyze's Avatar
Trade: Builder/Remodeler
Rewards Points: 1,686
Re: Need Math Help From The Gurus ;)
Don't have your answer but good to hear from ya! Awesome that things are going well for you!!
overanalyze is offline
Ninjaframer (12-06-2015)
Old 12-06-2015, 02:50 PM
Easyfier of Complexitries
digiconsoo's Avatar
Trade: Framing Components
Rewards Points: 1,552
Will this help you?
http://planetcalc.com/1421/
Originally Posted by hdavis View Post
It's probably better you write about something where you aren't functionally ignorant, you're just embarrassing yourself.
Originally Posted by tipitop View Post
Trump is lucky he didn't mess with me.
http://www.digiconsoo.com
digiconsoo is offline
Old 12-06-2015, 02:57 PM
Gen. Contractor
I looked at that and played with my trig master calculator till 4am last night. I'd need some one to walk me through it.
Once I learn a formula I'm good but I don't have any formal education so I can't read equation very well.
Old 12-06-2015, 03:01 PM
Tom Struble's Avatar
Trade: siding
Rewards Points: 20
Tom Struble is offline
hdavis (12-09-2015)
Old 12-06-2015, 03:09 PM
digiconsoo's Avatar
I looked at that and played with my trig master calculated till 4am last night. I'd need some one to walk me through it.
I'm not a very good teacher, but I'll try -
In the meantime, here's an even better calculator -
In the example you have in your OP, the "width of arc" in the formula is a chord.
So just punch in radius (72)
width of arc (84)
set the output of arc length to inches
push calculate.
I'll work on the formulaic explanation if someone doesn't beat me to it.
http://www.handymath.com/cgi-bin/arc...ss=1&decimal=5
Old 12-06-2015, 03:28 PM
Gen. Contractor
Ya an explanation of formula is what I'm after. I keep a black book of all this kind of stuff so once I get it it goes in there
Old 12-06-2015, 03:49 PM
CarpenterSFO's Avatar
Rewards Points: 2,044
You have a piece of pie. The chord cuts across the curve, making a triangle with the two radii.
split that triangle down the middle, and you have two right triangles, each with hypotenuse equal to the radius of the circle (6’ in your example) and one side equal to the chord divided by two (or 3.5 in your example).
The “central” angle of each right triangle has a sine (opposite over hypotenuse) of 3.5/6.0 in your example. In other words, that angle (half of the pie piece) is arcsin(3.5/6.0), or sin^-1(3.5/6.0), or 35.685 degrees in your example. Since the original pie piece had two of the halves, the total angle is 35.685*2 = 71.371. The length of the arc (a string laid around the edge of the circle, is (71.371/360) * 2*pi*r, or (71.371/360) * 2 * pi * 6.0 = 7.474, in your example.
Given the radius r and chord c, the formula is
((2 * arcsin((c/2)/r))/360)*2*pi*r
Simplified, and if arcsin will answer in radians rather than degrees (as Excel does), that is arcsin((c/2/r)*2*r
or in Excel, for your example, “=ASIN((7/2)/6)*2*6"
Probably someone else should check all that. It's important to get the parenthesis right, or if you're doing it with a calculator, the order of operations, which is:
If your calculator operates in radians (rather than degrees). Again, Excel by default operates in radians.
chord/2
Then that divided by radius.
Then arcsine that.
Then that times 2.
Then that times the radius.
If your calculator operates in degrees
chord/2
Then arcsine that.
Then that * pi
Then that divided by 180
Then that times 2.
- Bob
Last edited by CarpenterSFO; 12-06-2015 at 04:27 PM. Reason: Needed to account for radians v degrees.
CarpenterSFO is offline
The Following 8 Users Say Thank You to CarpenterSFO For This Useful Post:
Birch (12-08-2015), BlueRidgeGreen (12-07-2015), digiconsoo (12-06-2015), Jaws (12-06-2015), Ninjaframer (12-06-2015), SBE Builders (12-06-2015), TimberlineMD (12-09-2015), wallmaxx (12-08-2015)
Old 12-06-2015, 03:55 PM
digiconsoo's Avatar
Much better explanation than what I was writing!
And I cheated and checked it with the calculator, it agrees.
Old 12-06-2015, 04:10 PM
Fire up the BBQ
griz's Avatar
Rewards Points: 20
I imagine either one of these guys can help.
Try the SBE website, lots of info there.
Nice to see you back & that you are doing well....
https://www.contractortalk.com/members/birch-50235
http://www.sbebuilders.com/
griz is offline
The Following 2 Users Say Thank You to griz For This Useful Post:
Old 12-06-2015, 05:05 PM
Gen. Contractor
Both Sim and Birch have helped me before- I hope one of them pop in. Birch has been good about writing out keystrokes for the type of calc I use and explaining formula in a way I can grasp both awesome guys!
Thanks for the responses so far- it's good to poke back in here every so often- see a ton of new names for sure
Old 12-06-2015, 05:16 PM
Or:
- Bob
The Following User Says Thank You to CarpenterSFO For This Useful Post:
Birch (12-08-2015)
Old 12-06-2015, 05:28 PM
aptpupil's Avatar
Rewards Points: 1,894
Wish it was explained to me in school that this stuff could be remotely useful in the future.
aptpupil is offline
The Following 5 Users Say Thank You to aptpupil For This Useful Post:
BlueRidgeGreen (12-07-2015), CarpenterSFO (12-06-2015), hdavis (12-09-2015), Ninjaframer (12-06-2015), Xtrememtnbiker (12-06-2015)
Old 12-06-2015, 05:31 PM
Gen. Contractor
That's the freekin truth.
Geometrist
Warren's Avatar
Trade: framing/remodeling
Rewards Points: 560
You must have some really crappy prints to not have this info at your fingertips. I don't hesitate to call on the archy when something is missing that I need to do my job. Shouldn't have to be that complicated.
Warren is online now
Old 12-06-2015, 05:39 PM
Pretty tough for a kid in high school to accept that. My older son accepted it on faith that math would help him succeed in life. My younger son doesn't accept it, and though he's an outstanding math student, there hasn't been a lot of his free will involved in getting there and staying there. He'll thank me when he's 50, or not.
- Bob
hdavis (12-09-2015)
Old 12-06-2015, 05:40 PM
digiconsoo's Avatar
Sure would like to see the construction of the spiral staircase, if you can take a few pictures during....
The Following User Says Thank You to digiconsoo For This Useful Post:
Old 12-06-2015, 06:27 PM
Gen. Contractor
They are so bad I had to call the architect because there was not even dimensions to the radius point for the turret anywhere- on any page. I couldn't even lay out the foundation.
I'd want to know how to do this math anyway though just me
Old 12-06-2015, 06:34 PM
Gen. Contractor
chord/2
Then arcsine that.
Then that times 2.
chord/2
Then arcsine that.
Then that * pi
Then that times 2.
Perfect- thanks for dumbing it down for me it didn't occur to me to split the triangle and create 2 with right angles- duh.
The Following User Says Thank You to Ninjaframer For This Useful Post:
CarpenterSFO (12-07-2015)
Old 12-06-2015, 06:50 PM
Xtrememtnbiker's Avatar
Trade: General Remodeling
That was me because the math seemed stupid. Go figure that now I'm bad with math and need to use it.
I only did geometry I believe, never did calculus. I've toyed with taking some online math class or something to see if I can improve my skills.
Xtrememtnbiker is offline
Thread Tools
Rate This Thread
The Topic of Math Joasis General Discussion 113 10-19-2012 07:53 PM
Dumb question, double check my math? guyute65045 Excavation & Site Work 14 12-31-2010 07:31 PM
Math 1950-2007 dayspring Off Topic (Non Trade) 3 07-22-2007 09:18 AM
