Metal Turnbuckle Thingys For Plumbing Walls - Framing - Contractor Talk
Old 05-19-2015, 03:33 PM   #1
Box Builder
Morning Wood's Avatar
Rewards Points: 6
For the life of me I can't remember the name of these things. I have seen them and always wanted to have a few. They are the metal bracing that have screws on both ends. You nail one end to the wall and the other to the subfloor and turn the bar to plumb the wall. Thought it would be easier than fighting 2x braces and spring braces. Thanks, Nick.
Morning Wood is offline
Old 05-19-2015, 03:37 PM   #2
Creter's Avatar
Rewards Points: 1,966
Re: Metal Turnbuckle Thingys For Plumbing Walls
This?
http://www.dhcsupplies.com/store/p/4...late-Used.html
Creter is offline
Old 05-19-2015, 03:52 PM   #3
Box Builder
Rewards Points: 6
Yeah. Sort of. But they are nicer than those. They are kind of made specifically for framing wood walls.
I was actually thinking I could make some out of tubing or angle. Probably be cheaper to buy though. Doesn't one of the threads need to be left handed?
Old 05-19-2015, 03:59 PM   #4
I own stock in FotoMat!
480sparky's Avatar
Rewards Points: 2
Wall braces.
This post has been modified from its original version. It has been formatted to fit this screen and edited for content.
480sparky is online now
The Following User Says Thank You to 480sparky For This Useful Post:
Morning Wood (05-19-2015)
Old 05-19-2015, 04:05 PM   #5
Fire up the BBQ
griz's Avatar
Rewards Points: 18
http://www.amazon.com/Qualcraft-2620.../dp/B0000VUNUQ
griz is online now
Old 05-19-2015, 04:27 PM   #6
Box Builder
Rewards Points: 6
Yes. Thanks guys. You see. Wall Braces. That is the complicated name I couldn't remember. 😯
The Following 3 Users Say Thank You to Morning Wood For This Useful Post:
hdavis (05-19-2015), kwunch (05-19-2015), Xtrememtnbiker (05-19-2015)
Old 05-19-2015, 06:47 PM   #7
Box Builder
Rewards Points: 6
Geez, I gotta think I could make those for less than $70/piece.
Old 05-19-2015, 06:58 PM   #8
MTN REMODEL LLC's Avatar
Trade: Remodel and new build Colorado @ 7651 FT
Rewards Points: 1,428
Does make a couple of c-clamps/duplex nails/2x4s look like a bargain.
Never stop learning (xcep fer speling en typeing)
MTN REMODEL LLC is offline
Old 05-19-2015, 07:28 PM   #9
Randy Bush's Avatar
Trade: Exterior Remodeling
Rewards Points: 26
I have these that I use, think they are really for concrete form walls, but they still get the job done.
Randy Bush is offline
The Following User Says Thank You to Randy Bush For This Useful Post:
donerightwyo (05-19-2015)
Old 05-19-2015, 07:56 PM   #10
Geometrist
Warren's Avatar
Trade: framing/remodeling
Rewards Points: 2
These would be handy for those stubborn walls that refuse to be pulled in. At least the ones where the Lull can't get to. Never a problem pushing the walls.
Warren is online now
Old 05-19-2015, 08:57 PM   #11
Box Builder
Rewards Points: 6
I think I could make them pretty cheaply if I could leave them full length and not break them down like they have done. Must be for shipping. Anyone have these things. Are they set up to pretty much be on a 45
Old 05-19-2015, 09:04 PM   #12
Always Learning
overanalyze's Avatar
Trade: Builder/Remodeler
Rewards Points: 22
We have about a dozen or so homemade ones. An old timer gave them to me. He used old 3/4 galv pipe and a turn buckle at one end. We screw them to the floor and studs. They are awesome for getting the walls perfect! Ours are only about 9' long so they dont work for tall walls.
overanalyze is online now
Old 05-19-2015, 10:12 PM   #13
Box Builder
Rewards Points: 6
Would you mind taking a photo of yours and posting it if you get a chance?
Old 05-20-2015, 06:59 AM   #14
Always Learning
Rewards Points: 22
Sure. I will try and remember today.
Old 05-20-2015, 05:17 PM   #15
I'm The BOSS
jaydee's Avatar
Trade: builder / remodeler
Rewards Points: 4,733
I have some homemade ones also.
next time I'll use a really coarse thread,
something like 6 per inch.
they freeze up or strip out, every once in a while.
We'll give your home a NEW IMAGE
New Image Construction & Design
New image Construction.com
Facebook
jaydee is offline
Old 05-21-2015, 05:04 AM   #16
pappagor's Avatar
Trade: general contractor
Rewards Points: 32
i have some i think proctor made them 10 ft long 1 1/4 tube.
you could make them yourself in a hour or less with a steel tube and a 1 inch threaded rod.
pappagor is offline
Old 05-21-2015, 07:43 PM   #17
kyle_dmr's Avatar
Rewards Points: 998
I use a gradall if I can't get it level. Minimal work just a slight twist of the wrist. No wall holds up to that.
kyle_dmr is offline
The Following 2 Users Say Thank You to kyle_dmr For This Useful Post:
kiteman (05-21-2015), overanalyze (05-21-2015)
Old 05-21-2015, 09:52 PM   #18
Box Builder
Rewards Points: 6
All this talk of level and I'm always shooting for plumb.
The Following User Says Thank You to Morning Wood For This Useful Post:
SamM (05-22-2015)
Old 05-21-2015, 10:07 PM   #19
Always Learning
Rewards Points: 22
We used our Bobcat and a ratchet strap today to straighten a beam for a porch roof. Soil was too soft to hold a stake firm. Didn't need much...couple clicks past tight got it perfect!
Old 05-22-2015, 04:31 AM   #20
Forming and Framing
FramingPro's Avatar
Trade: Shell builder
Rewards Points: 3,582
Woot!
Im after fortune and frame
http://www.proicf.com
FramingPro is offline
Popping metal roof Accent Roofing Roofing 6 04-16-2013 08:39 PM
What is the max distance for load baring walls in a residence? kgcaddesign Architecture & Design 13 06-03-2012 02:35 PM
Sagging floors, over spanned joists, load bearing walls without support and more technique Remodeling 104 05-14-2010 04:16 AM
Metal roof question Burby Roofing 11 01-22-2009 01:16 PM
