Leveling - Framing - Contractor Talk
Leveling
Old 06-18-2019, 05:18 PM   #1
Joekid76's Avatar
Trade: Electrical and carpentry
Leveling
Why is it that contractor's and carpenters think you need a 4' or 6' level at the most to level a wall ? You need to be able to level the wall by holding the level on the bottom plate and the upper plate. Being doing this for over 25 years and had a general contractor read a forum on here discussing this and read that only a 4' and at the max is a 6' level needed. I use a 8' on my standard walls and a plate level or a laser level to level the top plate with the bottom. So just wondering what genius out thinks you can level a 8' to 12' wall with only a 4' to 6' level. Today's lumber is terrible so making sure that the bottom and top plate is level is the way to do it. Also make sure when crowning your studs to place all of the crowns the same direction.
Joekid76 is offline
Old 06-18-2019, 05:50 PM   #2
Fire up the BBQ
griz's Avatar
Rewards Points: 2,290
Re: Leveling
not sure where you are from but out on the coast here we refer to using a whiskey stick, in the manner you describe, as making sure a wall is plumb...
also very common to use a 4' level to plumb walls....
a straight edge is the trick...
if i ever got to the point where i had to level a top plate i think i would just pack my chit up and move on....
griz is online now
The Following 6 Users Say Thank You to griz For This Useful Post:
A&E Exteriors (06-20-2019), Dirtywhiteboy (06-20-2019), hdavis (06-18-2019), Rooster Cogburn (06-26-2019), Tinstaafl (06-18-2019), TNTRenovate (06-19-2019)
Old 06-18-2019, 05:55 PM   #3
Dirtywhiteboy's Avatar
Rewards Points: 10,086
Re: Leveling
Joekid76,, 25 years
do you know what plumb means
Dirtywhiteboy is offline
The Following 11 Users Say Thank You to Dirtywhiteboy For This Useful Post:
B.Johnson (06-18-2019), Calidecks (06-18-2019), cedarboarder (06-19-2019), Defenestrate (06-23-2019), Golden view (06-22-2019), griz (06-18-2019), jproffer (06-21-2019), Rio (06-19-2019), Rooster Cogburn (06-26-2019), Seven-Delta-FortyOne (06-18-2019), TNTRenovate (06-19-2019)
Old 06-18-2019, 05:58 PM   #4
eastcoastjoe's Avatar
Trade: GC aka adult baby sitter
Rewards Points: 42
Re: Leveling
Yep, when I started out (36 now) we used a 4ft level with a plywood strait edge. We got an entire house with 1/8", minus bowed studs ect. Lasers are cheating, but they sure are awesome. I'm glad I got the tail end of old school framers.
eastcoastjoe is offline
Old 06-18-2019, 05:58 PM   #5
dave_dj1's Avatar
Trade: general contractor
Rewards Points: 1,060
Re: Leveling
I typically stand back, put my thumb up and give 'er the ole hairy eyeball, works most of the time
We (pros) pick our lumber and eyeball each piece so our walls ain't wavy either
If I have to level the top plate on a new build I will fire the concrete guy
dave_dj1 is offline
Old 06-18-2019, 06:07 PM   #6
Goin' Down in Flames....
Seven-Delta-FortyOne's Avatar
Trade: Highwayman
Rewards Points: 2,186
Re: Leveling
If you're using an 8' level, you're doing it wrong.
You need to use a plate level, which has built-in stand-off blocks.
I think you mean plumb, not level, by the way.
Crowning studs is first day laborer $#1t, bro. Exterior walls, the crown goes to the outside. Interior, pick a side, and keep it consistent.
I've only built to 3 stories, and I haven't leveled a plate. Maybe on multi-story stuff, I don't know.
You need to get better framers.
Get Off My Lawn.
"There are no big projects. There are only small machines". - R. G. LeTourneau
Old 06-18-2019, 06:09 PM   #7
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 1,335
Re: Leveling
I generally level floors, not walls. I plumb them.
But yeah, a 4' level will do the job just fine in conjunction with a straightedge.
Tinstaafl is offline
The Following 2 Users Say Thank You to Tinstaafl For This Useful Post:
Rooster Cogburn (06-26-2019), TNTRenovate (06-19-2019)
Old 06-18-2019, 06:12 PM   #8
Tom M's Avatar
Rewards Points: 3,476
Re: Leveling
He's an electrician. You all understood his thought process but gave him the "Contractortalk beat down. LOL Hence the reputation.
Tom M is offline
The Following 4 Users Say Thank You to Tom M For This Useful Post:
Fouthgeneration (06-18-2019), Frank Castle (06-19-2019), Seven-Delta-FortyOne (06-18-2019), TheConstruct (06-19-2019)
Old 06-18-2019, 06:16 PM   #9
hdavis's Avatar
Rewards Points: 2,900
Re: Leveling
Probably because that's all you need. Personally, I've found longer levels get knocked around and go out easier than the shorter ones.
hdavis is online now
A&E Exteriors (06-20-2019), Rooster Cogburn (06-26-2019)
Old 06-18-2019, 06:19 PM   #10
rblakes1's Avatar
Rewards Points: 3,118
Re: Leveling
Welcome to CT
-Rich
rblakes1 is offline
The Following User Says Thank You to rblakes1 For This Useful Post:
Old 06-18-2019, 06:24 PM   #11
EricBrancard's Avatar
Trade: Builder/Renovator
Rewards Points: 516
Re: Leveling
Some guy told me something he heard on the internet so here I am to yell at the internet.
EricBrancard is online now
The Following 5 Users Say Thank You to EricBrancard For This Useful Post:
A&E Exteriors (06-20-2019), KAP (06-18-2019), mrcat (06-18-2019), TheConstruct (06-19-2019), TNTRenovate (06-19-2019)
Old 06-18-2019, 06:34 PM   #12
Trade: Highwayman
Re: Leveling
I was helpful......
..........Sort of......
Get Off My Lawn.
Tom M (06-18-2019)
Old 06-18-2019, 06:49 PM   #13
KAP's Avatar
Trade: Custom
Rewards Points: 33,886
Re: Leveling
It says electrician and carpentry... doesn't specify which the 25years applies to...
KAP is offline
Old 06-18-2019, 08:18 PM   #14
Fire up the BBQ
griz's Avatar
Re: Leveling
not at all intended as a beat down....
but the guy had a pretty good rant about "leveling" walls with the added caveat that he been doing this for 25 years....
sorry, but plumb & level are very basic construction terms that are not interchangeable....
sparkies i know are well aware of the terminology....
griz is online now
The Following 5 Users Say Thank You to griz For This Useful Post:
Calidecks (06-18-2019), Dirtywhiteboy (06-18-2019), hdavis (06-18-2019), Seven-Delta-FortyOne (06-18-2019), TNTRenovate (06-19-2019)
Old 06-18-2019, 08:30 PM   #15
back doors to hell put in
Irishslave's Avatar
Rewards Points: 2,612
Re: Leveling
Level plus Plumb=89.999999999999999 degrees.
Got a perfect level floor? Believe it or not I can plumb the wall with a 10' brace and a tape measure
Television is fake...The internet is real
Irishslave is offline
The Following User Says Thank You to Irishslave For This Useful Post:
Justin Rhoades (07-07-2019)
Old 06-18-2019, 08:55 PM   #16
hdavis's Avatar
Re: Leveling
Only if the floor is level....
Rio (06-19-2019), Seven-Delta-FortyOne (06-18-2019)
Old 06-18-2019, 08:55 PM   #17
Fouthgeneration's Avatar
Trade: Masonry
Rewards Points: 8,249
Re: Leveling
7D-41: RE: crown, always nail with the crown up, so stud isn't proud of stud one side? Otherwise you are pressing down, picking up the other end of the curved stud.... slower, harder, less flat wall.
bigger rooms get the belly?
Are homes with sideways hung Drywall less flat? vertically?
Fouthgeneration is offline
Old 06-18-2019, 09:29 PM   #18
Irishslave's Avatar
Re: Leveling
Aren't they all?
hdavis (06-18-2019)
Old 06-18-2019, 09:43 PM   #19
Irishslave's Avatar
Re: Leveling
Most accurate level I ever used was a water level.....unfortunately it didn't do plumb. Plumb bob is dead on but not workable.
Best level for this is Stabila Plate level with the standoff tabs. The lines on the vial are about the same as the width of the bubble. No 1/8 variation like on the cheapies. None of this "It's inside the lines holmes". Inside the lines isn't straight if you have 3/16" of fluid from the bubble to the line on the other side
Old 06-19-2019, 05:53 AM   #20
Joekid76's Avatar
Re: Leveling
I don't think many people are completely understanding with what I'm saying about the top plate being level from the bottom plate to the top plate. I do use a plate level when needed. I've been doing carpentry for over 25 years and an electrician for 25 years. I've frame up to 3 story homes and always used a 8' to extendable plate level. There's some rude comments on here. How you get a wall level vertical with a straight edge is not possible. The ones using a 3' and a straight edge plywood is not going to get a wall level and plumb. Everyone has different ways of doing things. You can not level any wall top to bottom with a 3' level. I'm a electrician and a carpenter. A laser level is not cheating it is doing it the easiest and fastest way possible. I could go on and on. But leveling a wall with a 3' level or eyeing it is not going to get a wall level from the bottom plate to the top plate. The floor being level to build a wall level straight up and down has nothing to do with what I'm saying and discussing. Also if you can find a concrete company who can pour a level wall or floor you sir have found the perfect concrete guy so good luck with that. I do believe there is too many keyboard commandos on this site. Common sense is needed in life. Good luck with you 3' to 6' levels. I've do believe I've seen a lot of no common sense comments that make no sense. I know what crowing studs are and which way to set the crowned studs. I know my walls are level and straight. Plain ridiculous to level a wall off studs with a 3' level. Good luck with your 1/8" to 3/16" within level. As you go on like that the farther the walls or entire project/house becomes more and more level. I do believe I've had enough of the no nonsense answers and comments on here. Somewhat of a joke to those who don't read and understand my original post.
Joekid76 is offline
