Just Curious... - Framing - Contractor Talk
Just Curious...
Old 05-16-2015, 10:52 PM   #1
JesseCocozza's Avatar
Rewards Points: 810
Just Curious...
For the guys who frame, specifically guys who have a crew who frame hip roofs with trusses. How many of your guys (crew) have the ability to calculate rafter, hip rafter, and Jack rafter lengths?
The reason I ask is because we are in the land of trusses here, so the mindset for a lot of guys is that it's a puzzle that just needs to get assembled. Unfortunately, most of the hip components that get sent out are total crap and require slight modifications in order for them to fall on layout, be plumb, and plane properly. I find that a lot of guys don't have the experience to spot these mistakes and rely on string lines and power planers to make things work, which drives me crazy.
This question stems from my frustration in not being able to find guys who have this ability. So I'm just curious if this is an unrealistic expectation of mine, or if this is a common struggle with you as well?
I mean as it stands now, I'm sending my guys home with quizzes in order to help teach them these things.
JesseCocozza is offline
Old 05-17-2015, 12:06 AM   #2
TWarner's Avatar
Trade: Framing
Rewards Points: 12
Re: Just Curious...
I'm employed, also in the land of trusses, and feel its a perfectly reasonable expectation for you to have as an employer. I guess like most things, it takes someone to teach you, so good on you for that.
TWarner is offline
The Following User Says Thank You to TWarner For This Useful Post:
JesseCocozza (05-17-2015)
Old 05-17-2015, 12:47 AM   #3
Framer87's Avatar
Trade: Framing
Rewards Points: 1,156
Re: Just Curious...
We're framing in the land of trusses and CM pro is our friend... every hip measurement comes from our own calcs, and not just how the puzzle fits. Never do we send up a block, fascia, rafters, or anything with any angle that does not fit. All figured out by the cutman with CM pro. As a matter of fact for irregular hips there is no other way. How else do you get all your cheek cuts and angles if you have an 8" and an 10" pitch for example?
Framer87 is offline
The Following User Says Thank You to Framer87 For This Useful Post:
Old 05-17-2015, 06:10 AM   #4
402joel's Avatar
Trade: carpenter
Rewards Points: 393
Re: Just Curious...
I feel for you guys in the land of trusses, I've never lived there
Trusses used to be a rare sight around here and roof cutting was a requirement for a competent carpenter, unfortunately that has changed in recent years with the proliferation of truss and wall plants by the local lumber yards.
I've managed to be a hold out as my 2 sons and I will only frame hand cut projects, and there are still plenty of those.
NRA Life Benefactor
SAF Life
402joel is online now
The Following 2 Users Say Thank You to 402joel For This Useful Post:
JesseCocozza (05-17-2015), kiteman (05-17-2015)
Old 05-17-2015, 03:16 PM   #5
Rewards Points: 810
Re: Just Curious...
I am the same way, but there not many guys that have this knowledge or experience. This is kind of the whole point of my post. How in the world do some of these guys make it so long without learning how to do it properly. It's crazy.
The Following User Says Thank You to JesseCocozza For This Useful Post:
Framer87 (05-18-2015)
Old 05-17-2015, 03:37 PM   #6
Fire up the BBQ
griz's Avatar
Rewards Points: 654
Re: Just Curious...
The same issue was around 35-40 years ago.
More time and labor is wasted on cutting roofs and stairs than anything.
Before trusses there was no option but to stack a roof. However, even in those days truly competent roof cutters were always in demand. There were any number of guys that could eventually cob a roof together. Once trusses started becoming the norm, that started the death knell for competent roof cutters. As time went by there became no one who could/wanted to teach and not many interested in learning. The pro roof cutters working today are few and far between.
Stairs are pretty much the same deal. Tremendous amounts of time and material wasted in cutting them.
So all this leads to the shortage of carpenters who have the basic knowledge to make the components of a hip truss package work.
griz is online now
Old 05-17-2015, 05:39 PM   #7
pappagor's Avatar
Trade: general contractor
Rewards Points: 32
Re: Just Curious...
the only time i hand frame is for valley sets it is the way it is. still know how to but just can not beat the truss. one more part of the trade that is going going gone
pappagor is offline
Old 05-17-2015, 06:46 PM   #8
Geometrist
Warren's Avatar
Trade: framing/remodeling
Rewards Points: 54
Re: Just Curious...
Most of the larger houses we build are about 75% truss, 25% stick. Trusses are never gonna completely replace stick, but they are very useful for larger spans and more economical. While I have never met a roof that I couldn't stick (so far!) I have also never used a CM, or any calculator on site to stick a roof. Just the way I was taught. When I started 30 years ago, nobody had a calculator on site. Doesn't make ame any better, nor any worse than a guy that does.
As far as my employees, I have two 20 year carpenters on board. Neither guy could probably take a full stick from start to finish. If they could, they would likely have moved on and started their own gig. My methods vary depending on the roof. A basic new construction, single, pitch gable would likely just be calculated on a scrap of 2x4 in less than a minute. A hip would take a couple extra steps, but still not too hard. On many remodels, the string will likely come out, as the likelihood of the existing being entirely accurate, is minimal.
Easy Gibson
Warren is online now
Old 05-17-2015, 08:52 PM   #9
SAcarpenter's Avatar
Trade: residential/remodeling carpenter
Rewards Points: 938
Re: Just Curious...
I can get by, and have framed a few stick roofs that I actually was impressed I did so well on, but by no means could I figure or frame stick roofs as efficiently as guys who do it all the time
You can rest when you're dead
SAcarpenter is offline
Old 05-18-2015, 04:53 PM   #10
muskoka guy's Avatar
Trade: framer/builder
Rewards Points: 558
Re: Just Curious...
Teach them to be one with a straight edge, its a framers best friend. That's what I teach my employees. Why wait for me to come around. First thing I am going to do is grab a straight edge and throw it on what every they are working on. If its not right, the straight edge will show it off right away.
muskoka guy is offline
Old 05-18-2015, 08:33 PM   #11
Rewards Points: 810
Re: Just Curious...
This is kind of the problem. I get too many guys that are great at walls and subfloors. They make things nice and straight and flat, but cutting a roof of another story. Not enough guys that can sort out the cuts / angles properly without guessing.
Old 05-18-2015, 08:46 PM   #12
Chad McDade's Avatar
Trade: Carpenter/GC
Rewards Points: 348
Re: Just Curious...
I was lucky enough to be taught by a great roof stacker - the guy could stick a roof in his sleep. He never used a CM - just a framing square and a string. I use a CM now but I also haven't done any serious framing in years.
I think you are on the right track though - teach them. Most truss guys can't stick because they were never taught.
__________________________________________________ ____________________________________________
“When the only tool you have is a hammer, you tend to see every problem as a nail.” - Abraham Maslow
Chad McDade is online now
Old 05-18-2015, 08:53 PM   #13
Fire up the BBQ
griz's Avatar
Rewards Points: 654
Re: Just Curious...
I don't think most modern day Carpenters have a framing square, much less know how to use it.
A guys skill level used to be determined relevant to his knowledge of the use of a framing square....
griz is online now
The Following 2 Users Say Thank You to griz For This Useful Post:
Chad McDade (05-18-2015), JAH (05-19-2015)
Old 05-18-2015, 09:15 PM   #14
Thread Reading Aficionado
Builders Inc.'s Avatar
Trade: Certified Building Contractor
Rewards Points: 1,458
Re: Just Curious...
Framing Square yes, but not without square locks. Those things are awesome!
Builders Inc. is offline
Old 05-18-2015, 09:16 PM   #15
Rewards Points: 810
Re: Just Curious...
While I appreciate that skill level, I'll take what I can get!
In all seriousness. I've done this long enough to know that each carpenter has his own way of attacking a build. I try not to get too hung up on the route they choose. I am focused on helping them to see the "triangles" in everything. If I can give them a CM and help them see the different triangles in their mind's eye, I think they'll get there. If they can figure it out faster or easier with a square, great, but I have a feeling that will come later.
Old 05-18-2015, 09:17 PM   #16
Artist and not a curator
Deckhead's Avatar
Trade: Carpentry,
Rewards Points: 3,636
Re: Just Curious...
Don't sweat it. The thing you mentioned was one of the big reasons I went solo and reminded myself again recently.
For those who don't know, our area is absolutely wretched for competent carpenter's, especially if it takes any amount of skill more than, "can't drink beer till after jobsite". Keep looking, hopefully you can find someone.
Dude you thought the wall was built by Hitler. You had no plan or scheme. You look like a fool trying to convince us.
Deckhead is online now
Old 05-18-2015, 09:19 PM   #17
Deckhead's Avatar
Trade: Carpentry,
Re: Just Curious...
Just helped a guy frame a roof. He took a 5500 sq ft roof and took a week to make it not plane. It was horrible. Framing around here is for a different breed, get the market if you can.
Old 05-18-2015, 09:21 PM   #18
mnld's Avatar
Trade: drywall junky
Rewards Points: 498
Re: Just Curious...
Remember when framing squares were sold with the little book that showed how to use it for hips, valleys, jacks, stairs, etc. etc. I bought one when I was 16 and read that little book so many times I think I saw it in my sleep! Not saying I ever learned to use it to its full potential though!
I have a neighbor that to this day doesn't use a speed square. I've learned a lot from that guy.
mnld is offline
Old 05-18-2015, 09:24 PM   #19
Rewards Points: 810
Re: Just Curious...
I thought you only did decks??!! You didn't tell me you were for hire. Now I'm offended!
Old 05-18-2015, 09:26 PM   #20
kiteman's Avatar
Rewards Points: 16
Re: Just Curious...
I don't think most modern day Carpenters have a framing square, much less know how to use it.....
All they know now is a speed square, and still not all the scales on those.
An old framer once told me "For years I thought I was the best damn carpenter in California. Come to find out I'm just competent."
kiteman is offline
The Following User Says Thank You to kiteman For This Useful Post:
griz (05-18-2015)
Curious how you'd design & build this pinwheel Finish Carpentry 13 02-02-2014 02:42 PM
Curious dproc Decks & Fencing 18 05-24-2013 10:21 PM
Curious Dadodeez35 General Discussion 8 01-26-2013 10:36 AM
curious about Chuck Dustyrose Off Topic (Non Trade) 18 03-17-2009 05:34 PM
