I Messed Up, Any Advice? - Framing - Contractor Talk
Old 01-18-2018, 12:15 PM   #1
tool-geek's Avatar
Rewards Points: 6
Long story short. A crew I hired did not use pressure treated lumber on the frame's sole plate during a basement renovation. Obviously, the ground is concrete.
What can I do before inspection happens? I was thinking of claiming its cedar, or pushing cedar shims under the plate (the ground is ridiculously uneven).
Code says "required naturally durable lumber or pressure treated sole plate". This is in NJ.
tool-geek is offline
Old 01-18-2018, 12:32 PM   #2
Sure, I can do that...
jlhaslip's Avatar
Trade: carpentry/renovations
Rewards Points: 196
Re: I Messed Up, Any Advice?
Can you get a layer of 6 mil Poly under it and then paint some preservative on the top surface?
jlhaslip is offline
Old 01-18-2018, 12:35 PM   #3
rblakes1's Avatar
Rewards Points: 3,688
Did they supply the lumber or did you? Have they been paid in full? Tell them to get back there and fix it
Sent from my SM-N910V using Tapatalk
rblakes1 is online now
The Following User Says Thank You to rblakes1 For This Useful Post:
Sir Mixalot (01-18-2018)
Old 01-18-2018, 12:45 PM   #4
larry228's Avatar
Trade: residential remodeling
Rewards Points: 8
An inspector told me 15 years ago that pressure treated was not required for basement floor contact IF you were positive there was continuous 6 mil poly under the slab
I never understood how I could prove this to anyone, and never took him up on this shortcut.
Has anyone else ever heard this?
In the prehistoric days- before pressure treated was commonly available- we would tack 15# felt to the underside of the sole plate.
larry228 is offline
Old 01-18-2018, 01:06 PM   #5
tool-geek's Avatar
Rewards Points: 6
yes, they were paid. I was thinking of taking the 6 mil tape. But how would I prove its there lol.
Would claiming the wood is cedar work? Technically, cedar is rot resistant too.
Old 01-18-2018, 01:24 PM   #6
Mordekyle's Avatar
Rewards Points: 5,748
How far along are you? Is the renovation nearly finished? Can you pry up the wall and get Felt under there?
To prove it's there, a picture is worth 1000 words. Several pictures are certainly worth more.
You could claim it is cedar. Until you gouge it with a knife and it does not pass the sniff test.
Mordekyle is online now
Old 01-18-2018, 01:28 PM   #7
gbruzze1's Avatar
Rewards Points: 2,608
Lol if I was an inspector and came in and saw that, and you told me it was cedar, you would be so phukd. You could carefully try to run a sawzall above and below the plate to remove it, then slide the pressure treated in. Only problem is itís a pain in the ass to cut out, and then you have to toe nail all the studs in. How many feet of wall needs to be changed?
gbruzze1 is offline
The Following User Says Thank You to gbruzze1 For This Useful Post:
Tom M (01-19-2018)
Old 01-18-2018, 01:43 PM   #8
tjbnwi's Avatar
Rewards Points: 2,766
Well now that we know the bottom plate is wrong---did the put the fire stop in between the top plate and first floor joists?
tjbnwi is online now
Old 01-18-2018, 01:53 PM   #9
rrk's Avatar
Rewards Points: 3,908
Sounds like you got what you paid for, a central american basement. There is no way you will pass inspection, you try to fool them they will be all over you forever.
rrk is online now
The Following 8 Users Say Thank You to rrk For This Useful Post:
brickhook (01-18-2018), Deckhead (01-18-2018), Fouthgeneration (01-18-2018), M.F Custom (01-18-2018), Rio (01-18-2018), Stilla (01-20-2018), TimNJ (01-18-2018), Tom M (01-19-2018)
Old 01-18-2018, 02:04 PM   #10
fourcornerhome's Avatar
Trade: home improvement contractor
Rewards Points: 350
Check with your inspector. They may allow you to coat the wood with a waterproofing sealer
fourcornerhome is online now
The Following 2 Users Say Thank You to fourcornerhome For This Useful Post:
Metro M & L (01-19-2018), Rio (01-18-2018)
Old 01-18-2018, 03:13 PM   #11
General Contractor
greg24k's Avatar
Rewards Points: 8,522
See what year the house was built. If it was built after when a 6mil plastic under the slab requirement was in effect, many towns in NJ waives the use of PT lumber on the slab... It will be inspectors call.
If not, cut the plate out and replace... extra work, but that's on you, you hired them, your job to oversee everything is done right and within code compliance.
greg24k is offline
Old 01-18-2018, 03:27 PM   #12
kirkdc's Avatar
Trade: Remodeling (mostly kitch/bath)
Rewards Points: 2,802
Be creative with the code termed "naturally durable lumber."
Natural = it's wood, real wood
Durable = wood is very durable, anyone would agree on that
Lumber= its a precisely cut piece of wood.
kirkdc is offline
Old 01-18-2018, 07:03 PM   #13
MarkJames's Avatar
Trade: Handyman Services
Rewards Points: 17,625
If I couldn't get something under them, my conscience would make me replace them. Not that difficult after you get over the anger.
I'm dealing with worker pf_up's on my job right now and I'm just fixing them. (I'm not in a telling mood right now, sorry.)
MarkJames is offline
Old 01-18-2018, 07:12 PM   #14
rblakes1's Avatar
And every 10' horizontally from the studs to the block wall?
Old 01-18-2018, 07:29 PM   #15
Stryker1-1's Avatar
Trade: Low Voltage Systems
Rewards Points: 2,350
Even if they were paid ring them up and tell them to get back in to fix it.
Sent from my SM-G870W using Tapatalk
Stryker1-1 is offline
The Following 2 Users Say Thank You to Stryker1-1 For This Useful Post:
Deckhead (01-18-2018), Golden view (01-18-2018)
Old 01-18-2018, 08:10 PM   #16
Artist and not a curator
Deckhead's Avatar
Trade: Carpentry,
Rewards Points: 5,334
Just claim it's cedar?
So you're okay with lying about your **** ups instead of making them right?
Wow.
And cedar... Really?
Dude you thought the wall was built by Hitler. You had no plan or scheme. You look like a fool trying to convince us.
Deckhead is offline
The Following 3 Users Say Thank You to Deckhead For This Useful Post:
avenge (01-18-2018), MarkJames (01-18-2018), SuperiorHIP (01-19-2018)
Old 01-18-2018, 08:14 PM   #17
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 5,076
Inner10 is offline
Old 01-18-2018, 08:39 PM   #18
Business Owner
P42003's Avatar
Trade: Pest & Termite Control
Rewards Points: 158
What about treating it with BoraCare?
P42003 is offline
Old 01-18-2018, 08:52 PM   #19
MTRmatt's Avatar
Rewards Points: 4
Wow.
Yeah...Everything he said.
Call(or drive back over to the deli parking lot) and tell your subs to fix it. ?
MTRmatt is offline
Old 01-18-2018, 08:56 PM   #20
diplomat
Golden view's Avatar
Rewards Points: 1,042
Not redoing it and lying is a quick path to ruining yourself. Saw it out and toenail. No big deal.
Golden view is online now
The Following 5 Users Say Thank You to Golden view For This Useful Post:
brickhook (01-18-2018), Deckhead (01-20-2018), greg24k (01-18-2018), m2akita (01-30-2018), rrk (01-18-2018)
Im bidding for a commercial painting job. any advice? BaranG Painting & Finish Work 13 02-25-2014 01:54 AM
Sealer removal advice over exposed aggregate and stamped? oktex56 Concrete & Paving 10 01-14-2013 03:57 PM
Advice sought on prefinished hardwood installation UpNorth Flooring 5 07-28-2012 08:31 PM
Need some advice on dealing with a possible client MP CONST Business 11 07-19-2012 12:16 AM
Best paint / advice for aluminum siding? Jdub2083 Painting & Finish Work 15 07-12-2012 01:15 AM
