How Would You Guys Frame It? - Framing - Contractor Talk
Old 02-22-2015, 01:07 AM   #1
GC/carpenter
Calidecks's Avatar
Rewards Points: 98
I recently built a deck for a very good customer. (Deck with an ocean view) even though I told them I'm pretty much just doing decks these days, they insisted I remodel their Master bath. So I Agreed. She found this on Houzz and adamantly wants this ceiling and tub below. I think it's very cool looking and look forward to framing it. However a lot of thoughts have come to mind on how to tackle the framing. There's 16 ways to skin a cat and I believe this is one of those cats. It has some similarities of a groin vault. So what do you guys got for me.
How would you guys frame it?-1424585433391.jpg   How would you guys frame it?-1424585476789.jpg
Calidecks is offline
Old 02-22-2015, 01:18 AM   #2
CarpenterSFO's Avatar
Rewards Points: 2,044
Re: How Would You Guys Frame It?
Plywood profiles with blocking in between to stabilize and to screw sheetrock.
Edit: The plywood sheets all parallel to the back wall. And I'd skip the chandelier and go straight to bare wires.
- Bob
CarpenterSFO is offline
The Following 5 Users Say Thank You to CarpenterSFO For This Useful Post:
Calidecks (02-22-2015), FrankSmith (02-22-2015), Jaws (02-22-2015), RiverBG (02-22-2015), Walraven (02-22-2015)
Old 02-22-2015, 01:30 AM   #3
GC/carpenter
Calidecks's Avatar
Rewards Points: 98
What? Bare wires? Splain Lucy!
Old 02-22-2015, 01:33 AM   #4
GC/carpenter
Calidecks's Avatar
Rewards Points: 98
Plywood sheets all parallel to the back wall sounds good.
Old 02-22-2015, 01:45 AM   #5
m1911's Avatar
Trade: finish carpenter
Rewards Points: 15,632
I'm trying to draw a sketch, but I need a few more drinks first.
piece of ply for the front arch up to the ceiling. Then a piece of ply with same arch on back wall. 2x's from front to back perpendicular to front ply. cut 2 pieces of ply for side arches and follow arch to join ceiling. I'm sure that made no sense.
and that's why I'm no architect!
Originally Posted by tipitop View Post
That guy in video have mental issues plus eat hole turtle from some reason
m1911 is offline
The Following User Says Thank You to m1911 For This Useful Post:
Old 02-22-2015, 01:50 AM   #6
GC/carpenter
Calidecks's Avatar
Rewards Points: 98
I'm waiting on plans as we speak. But I want to think on it now.
Old 02-22-2015, 01:54 AM   #7
m1911's Avatar
more importantly, make sure that lamp is on a gfci circuit, I think it's required.
m1911 is offline
Old 02-22-2015, 01:54 AM   #8
GC/carpenter
Calidecks's Avatar
Rewards Points: 98
It's almost like l have to just start. Get all the absolutes out of the way. Like I think I need to plant a piece of ply on all three walls the shape of each arch. Then install the front ply matching the back of course.
Another thought was to build it on the ground, so I can access through the top.
Old 02-22-2015, 01:58 AM   #9
GC/carpenter
Calidecks's Avatar
Rewards Points: 98
The whole underneath is concaved
Old 02-22-2015, 02:00 AM   #10
RiverBG's Avatar
Trade: Home rehab specialist
Rewards Points: 764
Thumbs up!
Looks like a fun project
RiverBG is offline
The Following User Says Thank You to RiverBG For This Useful Post:
Old 02-22-2015, 02:21 AM   #11
GC/carpenter
Calidecks's Avatar
Rewards Points: 98
I believe everything in San clemente has to be a GFCI breaker. The last remodel I did there, even the lights had to have them. My electrician says they are very sensitive and create a lot of call Backs. Especially lights.
Old 02-22-2015, 02:24 AM   #12
m1911's Avatar
Yup, the can lights above the showers. Steam, light sockets and GFCI don't play well together...
m1911 is offline
Old 02-22-2015, 02:38 AM   #13
hdavis's Avatar
Rewards Points: 344
Looks like intersecting 3 centered arches. You'll need to make laminated pieces for where the arches intersect. Otherwise, plywood and blocking like Bob said takes care of most of it, just not the smaller crossing arch.
hdavis is online now
Old 02-22-2015, 05:51 AM   #14
pappagor's Avatar
Trade: general contractor
Rewards Points: 32
i would use a arch kit from archkit .com yes it is cheating but i win at the bank and you are still cutting sheet rock
pappagor is offline
The Following 3 Users Say Thank You to pappagor For This Useful Post:
Calidecks (02-22-2015), digiconsoo (02-23-2015), Framer53 (02-22-2015)
Old 02-22-2015, 08:00 AM   #15
KemoSabe
loneframer's Avatar
Rewards Points: 12,218
First, I would make a plywood template of the side walls and lay it out on 12" centers, from the middle out both ways. Mount these to the sides. Then, I would use laminated plywood "ribs" from front to back on 12" centers. As you progress toward the center, you can determine at what point your arch will take a level plane to match the side arch by your layouts on the side templates. For example, from the front, it looks like possibly 2 full ribs before you fall into the side arch. You can determine by your layouts on the side template, how high from the bottom plane and on what bevel you must cut a level plane to match the template. I do the same process with barrels that die into a hip or valley.
loneframer is offline
The Following 5 Users Say Thank You to loneframer For This Useful Post:
blacktop (02-22-2015), Calidecks (02-22-2015), m1911 (02-22-2015), overanalyze (02-22-2015), SAcarpenter (02-22-2015)
Old 02-22-2015, 08:38 AM   #16
Joseph A. Capece
CENTERLINE MV's Avatar
Trade: Builder - General
Rewards Points: 1,432
wacky board is your friend.
Follow us on FACEBOOK
www.centerlinebuilders.net
Martha's Vineyard General Contractors - Builders -
Commercial/Residential - Additions - Renovations
CENTERLINE MV is offline
The Following User Says Thank You to CENTERLINE MV For This Useful Post:
festerized (02-22-2015)
Old 02-22-2015, 08:42 AM   #17
tjbnwi's Avatar
Rewards Points: 186
Check your local electrical code. The install in the photos would be a violation of the NEC, no hanging lights within 3' of the tub, GFI protected or not.
tjbnwi is online now
The Following 4 Users Say Thank You to tjbnwi For This Useful Post:
Calidecks (02-22-2015), Jaws (02-22-2015), m1911 (02-22-2015), ScipioAfricanus (02-22-2015)
Old 02-22-2015, 09:51 AM   #18
Randy Bush's Avatar
Trade: Exterior Remodeling
Rewards Points: 34
Yep just because there is a picture of something like that does not make it legal.
Randy Bush is online now
Old 02-22-2015, 12:21 PM   #19
GC/carpenter
Calidecks's Avatar
Rewards Points: 98
I'm thinking a recessed can light
Old 02-22-2015, 01:48 PM   #20
GC/carpenter
Calidecks's Avatar
Rewards Points: 98
This is it, right here. Thanks Lone.
Contractor body build for my '54 Chevy 1-1/2 ton mehtwo Vehicles 300 11-08-2014 02:01 PM
Replacing steel frame windows oRIDDLERo Windows, Siding and Doors 20 07-16-2014 06:36 PM
Guys with new f150 take a look BCConstruction Vehicles 7 09-22-2012 09:08 AM
last post regarding worker, you guys need------- davinci Off Topic (Non Trade) 81 07-19-2012 05:40 AM
Commercial Door Frame Installation Help kenscott88 Windows, Siding and Doors 9 02-09-2011 04:34 PM
