Header Bearing - Framing - Contractor Talk
Header Bearing
Old 12-30-2016, 11:41 AM   #1
SBS Building's Avatar
Trade: carpenter
Rewards Points: 4
Header Bearing
I have been searching on wall design/anatomy for a while now without any clear answers.
How much bearing does a header need in a structural timber frame? The carpenters I am working with at the moment use:
- Window: 1 king stud, two trimmers providing 90mm bearing roughly
- Door: - 1 king stud, 3 trimmers providing 135mm bearing roughly
To me this seems a bit backward as often a window opening is larger than a doorway opening.
I am pretty sure that for concrete lintels, a minimum of 100mm bearing is needed and 150mm for steel lintels, but I cant find anything on timber lintel/header bearing.
SBS Building is offline
Old 12-30-2016, 07:35 PM   #2
hdavis's Avatar
Rewards Points: 1,546
Re: Header Bearing
Timber framing is a world of its own. In light wood frame construction, there is no need for more than one king stud and one jack stud in most cases. For windows, trimmers are frequently kept on layout to give some support and to have something to attach sheathing and drywall to.
hdavis is offline
Calidecks (12-30-2016), ScipioAfricanus (12-31-2016)
Old 12-30-2016, 08:38 PM   #3
Bull Trout's Avatar
Rewards Points: 102
Re: Header Bearing
What do the plans call for? Structural timber frame requires engineering to get a permit around here, should have a detail
Bull Trout is online now
The Following User Says Thank You to Bull Trout For This Useful Post:
hdavis (12-31-2016)
Old 12-30-2016, 09:10 PM   #4
Sure, I can do that...
jlhaslip's Avatar
Trade: carpentry/renovations
Rewards Points: 196
Re: Header Bearing
The Engineer of Record on the Project should have done a Finite Element Analysis of the frame as designed and made changes to suit the on-site and regional requirements with respect to loads on the Frame. His drawings will answer your question. Where I live, there is no "Building Code" once an Engineer stamps the drawing. What he says is required is the right answer.
As usual, the Header or Beam bearing is determined by the forces acting upon it. Often in a Timber Frame, the typical standards of "1 1/2 inches of bearing" for joists and min 3" for beams goes out the door because the TF stuff is typically wider and provides more bearing surface than stick framing.
jlhaslip is offline
The Following 3 Users Say Thank You to jlhaslip For This Useful Post:
hdavis (12-31-2016), ScipioAfricanus (12-31-2016), Tom M (12-30-2016)
Can I install 1st floor header in the 2nd floor? TommyF Framing 14 07-10-2015 11:14 AM
Load Bearing Wall Diozark Framing 20 01-01-2013 04:29 PM
Improper Header Size greg24k Framing 9 03-27-2009 07:18 PM
Is this an incorrect header Maplehead Carpentry Picture Post 10 10-06-2008 06:54 AM
Framing a header after removing a load bearing wall tnt Framing 2 12-13-2006 10:17 PM
