Getting Rid Of Loly Column - Framing - Contractor Talk
Old 01-24-2010, 11:13 AM   #1
arcticbouncer's Avatar
Trade: Plumber
O.K here goes ... I am working on basement finishing job I am doing the plumbing and radiant floor the guy doing the framing for all the walls is getting rid of one of the lolly columns in the basement there is a tripple 2x10 mid house support run from end to end they are putting 2x10 on both sides of the existing bean and bolting and nailing them together and then going to remove one lolly. the total run is 53 feet with a lolly every 8 feet from the starting from both gable ends there a 2 in the center about 4' apart from each other, The house is a single level ranch basement about 6 foot under grade 53'x25'. Can you just add extra lumber around a joint and remove a lolly ? It seems like a little over kill with the lollys but I know they are there to help support a 2x10 seam . Is there a better way besides knocking the old support out and replaceing it with a LVL ? The lolly the are going to remove is the scond one from the gabel end so it is the first time the inside 2x10 is seemed . the main beem is supported by concrete block at the gable end then a lolly the the next lolly has the big X on it .
arcticbouncer is offline
Old 01-24-2010, 11:25 AM   #2
Framer53's Avatar
Trade: Handyman
Rewards Points: 366
Re: Getting Rid Of Loly Column
None of this should be done without an engineer looking at the situation and designing how to eliminate the lolly column. They are there for a reason.
Framer53 is offline
Old 01-24-2010, 11:29 AM   #3
genecarp's Avatar
Rewards Points: 2,000
Please complete your profile, and continue to the intro page and tell us a little about yourself and your professional experience, thankyou and welcome to ct"...gmod
genecarp is offline
Old 01-24-2010, 11:30 AM   #4
Anti-wingnut's Avatar
Rewards Points: 3,428
The short answer is no. We don't know the particulars of this building, and what the engineer designed. That said, it would seem that there is a fair chance that the framer is doing this on his own accord, and there is no permit, engineer, or achitect involved in this project. I would guess that the framer may be talented at nailing wood together, his ability to design and analyze structures is poor, verging on dangerous.
Ask the PE
Anti-wingnut is offline
Old 01-24-2010, 11:35 AM   #5
Joe Carola's Avatar
Trade: Framing Contractor
Rewards Points: 1,012
There are several ways to do this. You said adding 2x10's and then said lvl's. Which is it?
Depending on what the girder is supporting above I have used lvl's to do this before. I've never used 2x's to do this. Most of the time we use a flitch plate on each side of the girder bolted or one thick flitch plate bolted. Every one I do is designed by an Architect. I hope the framer is following a set of plans drawn by an Architect or Engineer. Ask him if your curious.
Joe Carola
Joe Carola is offline
Old 01-24-2010, 11:36 AM   #6
tcleve4911's Avatar
Trade: Remodeling contractor
Rewards Points: 1,008
Please post pictures of this process.
Back in Maine
Dubbin' Around
Doin' good stuff ......
tcleve4911 is offline
Old 01-24-2010, 11:40 AM   #7
tcleve4911's Avatar
going to remove one lolly. Can you just add extra lumber around a joint and remove a lolly ? It seems like a little over kill with the lollys The lolly then a lolly the next lolly has the big X on it .
Oh yeah.......it's a Lally Column
Back in Maine
Dubbin' Around
Old 01-24-2010, 11:50 AM   #8
Trade: Plumber
See that learned something today lally not lolly (* thanks ) . I have seen a bunch of people doing reno jobs and general building and every day it seems like there is another guy who did "this" on another site so it SHOULD work her too. Seems like a big " should ". The bad part is I have worked with the carpenter on several jobs before this one just wondering how to approach this matter or leave it for the home owner to fix when the foundation cracks along with the sheetrock when the weight is redistributed ?
P.S you guys are quick to reply pretty darned amazing . Thanks keep your fingers safe !
Old 01-24-2010, 11:56 AM   #9
tcleve4911's Avatar
You are not serious ....right??
Are you the GC?
Back in Maine
Dubbin' Around
Old 01-24-2010, 12:01 PM   #10
just wondering how to approach this matter or leave it for the home owner to fix when the foundation cracks along with the sheetrock ( or possibily much worse {added by anti-wingnut})when the weight is redistributed ?
The million dollar question. You're not an expert on beam and column capacity, and are not hired as one. You were not brought aboard as a owners representative, inspector, or consultant. And your knowledge of this subject comes from a bunch of anonymous cranks on the internet.
But your concern is well placed.
I do not have an easy answer how you should act to protect the homeowner, your own set of individual morals and ethics, and the professional autonomy of the (hack) framer.
Good luck
Old 01-24-2010, 12:02 PM   #11
He's the plumber Cleve
Old 01-24-2010, 12:04 PM   #12
tcleve4911's Avatar
Well then grab a sawzall and just cut the frikkin' thing out!!!!
Back in Maine
Dubbin' Around
The Following 4 Users Say Thank You to tcleve4911 For This Useful Post:
Anti-wingnut (01-24-2010), bconley (01-24-2010), Framer53 (01-24-2010), Tinstaafl (01-24-2010)
Old 01-24-2010, 12:20 PM   #13
katoman's Avatar
Trade: carpenter
This is why we have building permits.
katoman is offline
The Following User Says Thank You to katoman For This Useful Post:
Old 01-24-2010, 12:34 PM   #14
David Festa
festerized's Avatar
Rewards Points: 2,030
Have an architect/engineer spec out a “Better Header” system
http://www.betterheader.com/
festerized is offline
Old 01-24-2010, 12:55 PM   #15
Geometrist
Warren's Avatar
Trade: framing/remodeling
Rewards Points: 178
Good luck
Please do not use the word "framer" to define a hack like that. Anybody who would consider doing that without consulting an engineer is not a framer!!
Easy Gibson
Warren is online now
Old 01-24-2010, 01:10 PM   #16
katoman's Avatar
Trade: carpenter
Here's an example of someone who sees hack work in progress.
What is he supposed to do? Call the building department? Tell the "carpenter" ( it hurt using that word ) to do it correctly or he will call the bldg. dept.?
Suggestions for the OP?
katoman is offline
Old 01-24-2010, 01:31 PM   #17
Thom
thom's Avatar
Rewards Points: 4,748
the plumber should talk to the owner.
"Please, have the carpenter leave the lally column in place until after my portion of the job is done and I'm no longer needed on site."
thom is offline
The Following User Says Thank You to thom For This Useful Post:
reveivl (01-24-2010)
Old 01-24-2010, 01:34 PM   #18
tcleve4911's Avatar
Also know as a "Flitch plate"
Back in Maine
Dubbin' Around
Old 01-24-2010, 02:40 PM   #19
reveivl's Avatar
Trade: Renovations
Rewards Points: 1,000
Thom has it right. It's not your business except that you have to be in there while someone is removing structure from the house. That IS your business: you might get hurt. Mention it to the home owner and see where he goes from there.
reveivl is offline
Old 01-24-2010, 06:16 PM   #20
Zimmermann
BrianFox's Avatar
Trade: Wood Cutter
Rewards Points: 250
Stamped drawing from my engineer-$250
structural safety and piece of mind- priceless
Happiness is produced not so much by great pieces of good fortune that seldom happen, as by little advantages that occur every day.
- Benjamin Franklin
BrianFox is offline
Porch Column Repair mpt1123 Historical Restoration 5 01-11-2010 07:33 PM
Column question Robie Historical Restoration 4 03-18-2009 04:53 PM
Plumbing a brick column curapa Masonry 4 03-12-2009 07:57 PM
Column Support Help!? canet2007 Construction 3 09-16-2008 07:33 PM
AISC Steel Pipe Column on Conc. Curb Wall Atlantex Welding & Steel Trades 0 08-20-2007 03:59 PM
