Gable Or Hip Roof? - Framing - Contractor Talk
Gable Or Hip Roof?
Old 01-20-2014, 09:00 AM   #1
CJ21's Avatar
Rewards Points: 702
Gable Or Hip Roof?
I will try to start on my 12x20 garage project this spring or summer. But I am wondering should build a 4/12 gable roof or a 4/12 hip roof to match my parents house. This will be my first framing project since I left trade school in three years.
CJ21 is offline
Old 01-20-2014, 09:09 AM   #2
TimelessQuality's Avatar
Trade: GC/Remodeling
Rewards Points: 1,730
Re: Gable Or Hip Roof?
Which ever matches the house...
Can you scale it up a bit, 12x20 is pretty small, and the cost/sf isn't that much to go bigger
-Steve
TimelessQuality is offline
Old 01-20-2014, 09:12 AM   #3
CJ21's Avatar
Rewards Points: 702
The blueprints is a 12x20 garage. The building official wont mind if I change the roof design. Is a hip roof hard to do? Its been awhile since I frame one.
CJ21 is offline
Old 01-20-2014, 10:35 AM   #4
framer55's Avatar
Trade: carpenter
Rewards Points: 20
Shouldn't be too hard CJ.
Still have your books from school?
on't worry, we can help you if you get stuck.
d
framer55 is offline
Old 01-20-2014, 10:52 AM   #5
knucklehead's Avatar
Trade: Extraordinary Carpenter
Rewards Points: 2,728
Easy. And that size would be about as simple as you could do.
NKLHD
knucklehead is offline
Old 01-20-2014, 10:54 AM   #6
CJ21's Avatar
Rewards Points: 702
Yes I still have the books. The plan call for 2x4's for rafters? Will 2x4's pass code?
CJ21 is offline
Old 01-20-2014, 11:15 AM   #7
bdavis466's Avatar
No way 2x4's would pass here...unless you mean 2x4 trusses?
I agree with the previous post about making the garage bigger. I just finished mine, 22x48 and now wish I would have doubled the size of it. It won't cost much more to make it a little larger.
bdavis466 is offline
Old 01-20-2014, 11:37 AM   #8
Eater of sins.
ScipioAfricanus's Avatar
Rewards Points: 486
For as short a span on RR as you are talking about then the code (IRC 2012) will allow for 2x4 DF #2 or better on 24" centers.
Dead load = 10 or 20# etc.
Andy.
ScipioAfricanus is offline
Old 01-20-2014, 12:15 PM   #9
Smithanator's Avatar
Trade: General contractor
Rewards Points: 274
Do not use 2by4. 24 on center. !!! Bad idea. If you stick frame. Witch you should ...go 16" on center 2by6 or better. I would use 2by8.
Smithanator is offline
Old 01-20-2014, 12:17 PM   #10
Rewards Points: 274
Hip roof like that pretty simple but def more involved than straight gable roof.
Old 01-20-2014, 12:40 PM   #11
CJ21's Avatar
Rewards Points: 702
I live in Alabama so we don't have problems with snow loads.
CJ21 is offline
Old 01-20-2014, 12:44 PM   #12
Get a price on a truss package... You'll probably be surprised how reasonable it can be
-Steve
Old 01-20-2014, 12:52 PM   #13
Rewards Points: 274
Even if 2by 4s would pass. Witch they wouldn't. You can't even get a birds mouth cut on them
Old 01-20-2014, 12:57 PM   #14
Rewards Points: 274
It will be substantial cheaper to stick build and not buy trusses. Especially since you are doing work.
Old 01-20-2014, 01:32 PM   #15
CJ21's Avatar
Rewards Points: 702
Will 2x6's then. It will be cheaper to stick build, and plus its good practice.
CJ21 is offline
Old 01-20-2014, 01:42 PM   #16
Rewards Points: 274
Yes
Old 01-20-2014, 01:53 PM   #17
Rewards Points: 274
If you go 2ft on center ,then you have to put h clips on roof sheathing pita. It makes no sense in my book not to stack frame over your studs 16" on center and buy a couple extra 2by6s. Plus much better frame job. Thumbs up . I would be happy to help you with any ?s
Old 01-20-2014, 01:55 PM   #18
Rewards Points: 274
I did nothing but cut in roofs on new houses I built for 10 yrs
Old 01-20-2014, 02:02 PM   #19
Rewards Points: 274
If you have a I phone get power 1ce construction calculator . It will cost you $5 and tell you all you need to know. Type in span and voila
Old 01-20-2014, 02:31 PM   #20
CJ21's Avatar
Rewards Points: 702
I just was taught to frame rafters 2 ft on center.
CJ21 is offline
Dormer Shed Roof, Barrel Roof, CutIn Dormer, Eyebrow Dormer sbebuilders Framing 33 04-18-2013 05:29 PM
Joe Fusco's roof framing calculator bookmdanno Roofing 2 07-18-2012 02:41 PM
Looking for advice on beams/joists for unique roof... vella Carpentry 9 04-10-2012 11:37 PM
Metal roof question Burby Roofing 11 01-22-2009 01:16 PM
