Framing For Sound Proofing - Page 2 - Framing - Contractor Talk
Old 11-10-2019, 07:18 PM   #21
artinall's Avatar
Trade: Repairs & Finishing
Rewards Points: 458
Re: Framing For Sound Proofing
Originally Posted by overanalyze View Post
...and an auto drop bottom seal.
They okay on carpet or better for hard floor surfaces?
artinall is offline
The Following User Says Thank You to artinall For This Useful Post:
overanalyze (11-10-2019)
Old 11-10-2019, 07:36 PM   #22
Always Learning
overanalyze's Avatar
Trade: Builder/Remodeler
Rewards Points: 1,106
Either is fine. They are adjustable. They activate with a plunger on the hinge side and drop down to the flooring.
overanalyze is online now
artinall (11-10-2019)
Old 11-10-2019, 10:08 PM   #23
Porterfarm's Avatar
Trade: Handyman/ Home Improvement Contractor
Rewards Points: 28
[QUOTE=artinall;7650627]
Originally Posted by Warren View Post
Gotta do something with the door, that is your weakest link. The exterior door would help, as it also seals at the bottom. You could keep the wall 2x4, then add 2"foam before drywall. Vibration is the worst enemy.
You suggesting installing an exterior door on an interior wall member?
Like the foam idea but...never to be adjusted/reset again.
You should consider block wall with a solid door.
Insulated wall each side of the block. Then you need to treat the ceiling. Double ceiling with lots of drywall. Insulate the cavities. Roxul .
You will need to address the ceiling leave no gaps.
Good luck
Porterfarm is online now
The Following User Says Thank You to Porterfarm For This Useful Post:
Fouthgeneration (11-20-2019)
Old 11-11-2019, 01:05 AM   #24
LRG WoodCrafting
Leo G's Avatar
Trade: Maker of Fine Sawdust
Rewards Points: 5,269
Seal the room and then put a complete vacuum in it. As we all know sound can't travel in a vacuum. And the people in the room would die from no air. So they really won't hear anything.
5/8" drywall, staggered studs with cellulose insulation, solid core doors. Have curtains on the theater side of the wall to start the deadening before it even hits the wall.
Sawdust Follows Me Everywhere
WWG1WGA
Carpenter by day.
Mad scientist by night.
http://lrgwood.com
Leo G is online now
Old 11-12-2019, 08:43 PM   #25
artinall's Avatar
Rewards Points: 458
What about homasote? Very effective?
artinall is offline
Old 11-12-2019, 09:10 PM   #26
Fire up the BBQ
griz's Avatar
Rewards Points: 376
it can be PART of your sound proofing assembly...
the key is to disrupt the sound waves (vibrations) so they do not pass thru an assembly.
all the components work together to create a sound proof barrier.
but as i said earlier, it is not cheap to do.
griz is online now
The Following 4 Users Say Thank You to griz For This Useful Post:
artinall (11-13-2019), Fouthgeneration (11-20-2019), Jaws (11-12-2019), overanalyze (11-12-2019)
Old 11-12-2019, 10:36 PM   #27
Goin' Down in Flames....
Seven-Delta-FortyOne's Avatar
Trade: Highwayman
Rewards Points: 778
Just staple some shag carpet to the walls, man.
It's totally Shag-adelic. Man.
Framing for Sound Proofing-screen-shot-2019-11-12-19.34.14.png   Framing for Sound Proofing-screen-shot-2019-11-12-19.31.59.png
The Following 4 Users Say Thank You to Seven-Delta-FortyOne For This Useful Post:
DaVinciRemodel (11-13-2019), griz (11-12-2019), Jaws (11-12-2019), overanalyze (11-13-2019)
Old 11-13-2019, 03:48 PM   #28
Tom M's Avatar
Rewards Points: 7,260
Acoustic tile serves a purpose.........just sucks to repair it if needed.
I have used homasote backing and neoprene gaskets between plates and floor/ceiling.
Another product is "Quiet rock" This I have not tried out so I can verify its claims but in any application mentioned insulation is going to help
Tom M is online now
Old 11-13-2019, 03:55 PM   #29
artinall's Avatar
Rewards Points: 458
How'd the Homasote do?
artinall is offline
Old 11-13-2019, 04:44 PM   #30
Tom M's Avatar
No complaints. Only so much you can do
Tom M is online now
Old 11-14-2019, 08:07 AM   #31
eastcoastjoe's Avatar
Trade: GC aka adult baby sitter
Rewards Points: 76
I used homosote on both sides of a 2x4 wall separating bedrooms in my house. I also sealed around penetrations and outlets. I can have my computer at 3/4 volume and hear absolutely nothing in the other room.
I also used some at my camp and the smell was awful. Waited a month before covering to see if it went away. No dice, ripped it out and threw it away. I find the black colored didn't smell and the grey was awful. Neither had a name printed on them, so no help there.
eastcoastjoe is offline
The Following User Says Thank You to eastcoastjoe For This Useful Post:
artinall (11-14-2019)
Old 11-14-2019, 11:22 AM   #32
artinall's Avatar
Rewards Points: 458
Originally Posted by eastcoastjoe View Post
I used homosote on both sides of a 2x4 wall separating bedrooms in my house. I also sealed around penetrations and outlets. I can have my computer at 3/4 volume and hear absolutely nothing in the other room....
Very useful, THX
artinall is offline
Old 11-15-2019, 04:11 PM   #33
builditguy's Avatar
Rewards Points: 1,932
All of the above ideas are good.
I don't know if anyone mentioned a seal at the bottom of the door. When you shut the door, the seal drops down.
One thing I know for sure. No matter what, people will think there is too much sound coming through. I've done everything from walls to rooms to confessionals. No matter what, someone thinks it should be better.
They also never want to spend the money, to do the best possible.
FYI. A door for a sound proof room, cost about $3,500. Think sound studio quality.
builditguy is offline
The Following User Says Thank You to builditguy For This Useful Post:
griz (11-15-2019)
Old 11-16-2019, 01:53 PM   #34
rblakes1's Avatar
Rewards Points: 3,526
I was going to mention Quiet Rock, were used it in a few commercial jobs where sound proofing was needed between units.
It's not cheap, but works well. It's also really friggin heavy
-Rich
rblakes1 is offline
The Following 2 Users Say Thank You to rblakes1 For This Useful Post:
overanalyze (11-17-2019), Tom M (11-16-2019)
Old 11-20-2019, 01:40 PM   #35
Punching above his weight
Easy Gibson's Avatar
Trade: Gun for hire.
Rewards Points: 15,220
Also you have to cut it with an angle grinder.
Easy Gibson is offline
Old 11-20-2019, 02:49 PM   #36
artinall's Avatar
Rewards Points: 458
You are kidding...?
Was pondering how to get through that metal layer.
artinall is offline
Old 11-20-2019, 06:02 PM   #37
Fouthgeneration's Avatar
Trade: Masonry
Rewards Points: 9,335
Conventional Dry wall, sprayed with very low growth "foam" , think undercoating / rubber dampening layer...On "back side'i
Install a "Noise door" over regular door again coat both with lead/ rubber sound deadening products, and a thermal/ sound SPLIT Jamb....
buy a Bose active noise reducer.......
old school lay "nogging" brick and CMUs between studs with coarse concrete fill or perlite.
Saw the studs in the walk-in closet long ways in the center, interrupt the cut at half high with off set slit...
lay out the party wall out of square or(make a couple of "random offsets" to reduce the room's resonance..) to the other 3 walls of the theater room. Saw cut deep the floor slab at BOTH closet wall line.
just add an "extra" MASONRY sand filled wall near the closet?
Get an sound engineer to analysis the floors and walls to make their resonant frequencies sub-sonic or super sonic....
Fouthgeneration is offline
Old 11-24-2019, 05:00 PM   #38
artinall's Avatar
Rewards Points: 458
On the OuietRock - can nails be shot for the base/door casing?
artinall is offline
Old 12-03-2019, 04:56 AM   #39
artinall's Avatar
Rewards Points: 458
Contacted QuietRock - can be shot with nails and they recommend caulk on any pulled nails. Also, they suggested their EZ-Snap that's easier to cut than QuietRock.
https://www.quietrock.com/products/ez-snap
artinall is offline
Old 12-28-2019, 06:12 PM   #40
artinall's Avatar
Rewards Points: 458
In the interest of 2 x 6's I could have been more vocal with the basic layout (blue)...here.
There will be 3 breaks in the outer wall while the inner closet is standard stud.
Would it really make sense to do this in wider 6's with these angles? Shouldn't the wider framing maintain on both ends and also where there are breaks/angles... so, with these obstructions would that defeat the purpose of "offset studs" for better soundproofing?
Debating how much a standard wall, doubling up 1/2" sheetrock on the far outside only would give...or maybe 1/8" black mat since I'm not prepared for the heavier 1/4"
artinall is offline
