Framing On Radiant Floors - Framing - Contractor Talk
Old 11-30-2009, 09:48 PM   #1
ryanh's Avatar
Trade: Home Construction/Reno
Rewards Points: 75
Can someone tell me how embeded the pipes are in a radiant floor usually?. When attaching a bottom plate to the concrete i usually use my 3" ramset nails. Do I run the risk of going to deep?
What options do I have?
ryanh is offline
Old 11-30-2009, 10:01 PM   #2
RobertCDF's Avatar
Trade: Custom deck builder
Rewards Points: 1,533
Re: Framing On Radiant Floors
DO NOT RAMSET!!! you will likely hit them. They are weaved around fairly close together. Glue the plates down with PL. This is what we do in cases like this. Usually we will go in and snap it all out and glue the plates down then come back a couple days later to frame it up.
RobertCDF is offline
The Following User Says Thank You to RobertCDF For This Useful Post:
Rio (01-16-2010)
Old 11-30-2009, 10:10 PM   #3
wyoming 1's Avatar
Trade: General contractor
Rewards Points: 520
Yeah what he said!
wyoming 1 is offline
Old 11-30-2009, 10:58 PM   #4
JT Wood's Avatar
Trade: carpenter
Rewards Points: 2,560
It's risky.
The pipes are supposed to be 2.5" down but it would be a major pita if you hit one.
I use pl premium as well.
JT Wood is offline
Old 12-01-2009, 01:45 AM   #5
ryanh's Avatar
Rewards Points: 75
I wasn't sure if I was going to put the gap at the top so I wanted to pre build the wall and then ramset it into place.
Also I was planning on putting a sill gasket under the bottom plate, I will have to skip it if im going to use PL
ryanh is offline
Old 12-01-2009, 02:10 AM   #6
KennMacMoragh's Avatar
Trade: Repair/Remodel
Rewards Points: 3,262
I don't think there's any way to tell how deep they are unless you know the guy that put them in. I remember working on a condo with radiant floor heating and I was told the pipes were buried one inch. So any underlayment had to be glued down, not nailed or screwed.
Are you attaching partition walls? Do the walls all have something else they can nail to? If so, glue will probably be enough. But if you have to use nails, I would hire someone who installs those radiant floors to come out and see if he can locate them for you so you can miss them. Btw, I've always used 2 1/2" ramset nails for attaching a bottom plate to concrete, they shoot in a lot easier and seem to hold fine.
KennMacMoragh is offline
Old 12-01-2009, 06:24 AM   #7
mikeswoods's Avatar
Trade: interior remodeling
Rewards Points: 2,664
Like everyone else said! Glue the bottom plate--------
mikeswoods is offline
Old 12-01-2009, 09:46 AM   #8
N.Schiffer's Avatar
Trade: Custom Builder
Rewards Points: 75
I personally would get in contact with the radiant floor guy, if these are exterior bearing walls I would rather install the sill gasket and nail (I'm assuming they're not because typically you'd have to have embedded anchors in the concrete) and I would assume that they left the piping far enough away from the exterior edges, but again I would double check. For interior non-load bearing, I agree with the rest, and just use PL to glue it down.
Nick Schiffer
Specializing in Custom Sheds
Custom Carpentry
& General Construction
N.Schiffer is offline
Old 12-02-2009, 09:23 AM   #9
ryanh's Avatar
Rewards Points: 75
Well I wanted to put a sill gasket under the interior wall bottom plates so the wood doesn't contact the cement, but then I wouldn't be able to glue property...
I'll try and hunt down the guy who did the floors.
ryanh is offline
Old 12-02-2009, 12:08 PM   #10
I eat sawdust.
Winchester's Avatar
Trade: Deck Design/Build
Rewards Points: 2,000
Are you allowed using PT there?
Winchester is offline
Old 12-02-2009, 05:07 PM   #11
ClemS's Avatar
Trade: Framing
radiant tubing is best with minimal coverage on it. less crap on top = less crap to heat.
use 2" cut nails, or pins if you like them better. 1/2" penetration is enough to keep the shoe in place, and you're guaranteed not to hit a line.
gluing plates down sounds like fun though *yawn*
ClemS is offline
Old 12-03-2009, 08:35 AM   #12
ryanh's Avatar
Rewards Points: 75
Yes you are allowed, but its rarely ever seen. I've seen PT used maybe once. Im not sure if its because of the extra cost or some people might be bothered by the smell ??
ryanh is offline
Old 12-03-2009, 10:54 AM   #13
topsail's trimcat
woodworkbykirk's Avatar
Rewards Points: 384
if we know theirs radiant going in we put down overpour plates first for all the walls meaning one plate down the sheathing. the plumber can then run his pipes in each room and the concrete guys can do their pour. we then come back in and nail down to the overpour plates.
if gluing we cut a every 3rd stud a little longer to ensure a good snug fit for the glue to grab the shoe
woodworkbykirk is offline
Old 12-14-2009, 11:33 PM   #14
clinkard's Avatar
Rewards Points: 25
We have sprayed the floor with water with the thermo cranked for a couple hours and it will show you exactly where the pipes are.
clinkard is offline
Old 12-15-2009, 11:42 AM   #15
N.Schiffer's Avatar
Rewards Points: 75
clinkard, I never even thought of that. Simple but effective!
Nick Schiffer
Custom Carpentry
Old 12-15-2009, 07:18 PM   #16
Cjeff's Avatar
Trade: Renovations
Amazing!!!!!! So low tech even i could do it
Cjeff is offline
Old 12-15-2009, 09:50 PM   #17
Zimmermann
BrianFox's Avatar
Trade: Wood Cutter
Rewards Points: 250
Typically on all the radiant floors I've had to deal with the tubing did not go out to the exterior walls.
I still didnt tapcon or ramest the exterior wall plates but usually the tubing is anywhere from 6"-12" in from exterior walls.
Youre main worry would be in the field of the rooms / party walls.
Happiness is produced not so much by great pieces of good fortune that seldom happen, as by little advantages that occur every day.
- Benjamin Franklin
BrianFox is offline
Old 01-16-2010, 02:07 PM   #18
Custom Builder
Chris@Sunrise's Avatar
Rewards Points: 502
We frame everything up then the tubing guys come tube it and then the gypcrete guys come pour it. We put 2x2 down whereever theres hard wood. This means no worries on broken pipes beat up gyp. Also allows us to put backing down everywhere for cabniets carpet tack strip floor plugs or anything else.
Chris@Sunrise is offline
Old 01-16-2010, 02:12 PM   #19
Custom Builder
Rewards Points: 502
heres a pic after tubing is in.
Old 01-16-2010, 02:13 PM   #20
Custom Builder
Rewards Points: 502
hopefully this is it
Framing Documents To Die For NC2X4 Framing 33 09-17-2010 10:45 AM
Framing a radiant heat basement with no nails rusty1986 Framing 9 08-21-2008 09:15 PM
Radiant Barrier Fact Sheet Ed the Roofer Roofing 0 02-09-2008 08:57 PM
Radiant Floors using floor joists and reflective barriar Jacey Flooring 1 07-06-2007 12:04 PM
Hardwood Floors over Radiant Heat bigtick Flooring 10 12-08-2005 03:43 PM
