Framing In A Large Overhang - Framing - Contractor Talk
Old 01-15-2019, 07:56 AM   #1
Bradmxz's Avatar
Trade: Plasterer
Hi. Let me start with the back story. My wife and I are building a cottage on a very limited budget at the moment. It’s 24x16 with an open loft. The front of the cottage will have a 4’ deck with a 6’ roof overhang for extra shelter. I don’t have a problem with anything other than how to frame in the support for the overhang. I will be using a ridge beam. Now the peak is simple as I just carry my ridge beam 6’ past the front wall, but what about the bottom of the rafters. How do I make this work? There will be 6x6 post on the corners of the 4’ deck that will hold up whatever I use to build the overhang.
Bradmxz is offline
Old 01-15-2019, 09:37 AM   #2
hdavis's Avatar
Rewards Points: 2,208
Re: Framing In A Large Overhang
Is this just going to be a gabled end continuation of the main roof?
hdavis is online now
Old 01-15-2019, 09:58 AM   #3
Ed Hartmann's Avatar
Rewards Points: 306
Sounds like you just need a porch beam if I understand what you are trying to accomplish. It both supports the roof and defines the space. It also works out where the roof overhand is usually lower then the porch, again making the space feel more like a "room" with the ceiling higher than the houses soffits.
Occasionally you see a porch with the beam above and the overhang continues as the porch roof. It works but it looks a little less proportioned or elegant.
Ed Hartmann is offline
The Following User Says Thank You to Ed Hartmann For This Useful Post:
Tom M (01-16-2019)
Old 01-15-2019, 02:29 PM   #4
Bradmxz's Avatar
Trade: Plasterer
What I was hoping to do is just continue the roof and leave it open.
Bradmxz is offline
Old 01-15-2019, 02:30 PM   #5
Bradmxz's Avatar
Trade: Plasterer
If I understand you correctly, i should continue my walls top plate and support it on the end of the deck corner.
Bradmxz is offline
Old 01-15-2019, 02:39 PM   #6
Bradmxz's Avatar
Trade: Plasterer
I’m sorry I should’ve posted this in my first post so you get a complete understanding of what we want. Unfortunately these plans aren’t that good and don’t show me how they have this tied into the main roof. But I can see how continuing my top plate would allow me to set my boards from the ridge beam.
Framing in a large overhang-74b582f0-3174-4e8f-bf7b-0edddd83945e_1547581063675.png
Bradmxz is offline
Old 01-15-2019, 02:49 PM   #7
Fire up the BBQ
griz's Avatar
Rewards Points: 2,470
it's not your top plates that will be extended but rather their height.
you need a beam calc'd for loads, tied into the house via plates/hardware,
then a post & footing on the other end.
griz is online now
hdavis (01-15-2019)
Old 01-15-2019, 07:07 PM   #8
Bradmxz's Avatar
Trade: Plasterer
Ok this is exactly what I’m looking for. Could you elaborate a bit on it please. Proper drawings would show this to me but like I said we are on a budget and these plans are the best I have.
Bradmxz is offline
Old 01-15-2019, 07:47 PM   #9
Fire up the BBQ
griz's Avatar
how much snow you get?
griz is online now
Old 01-15-2019, 07:48 PM   #10
knucklehead's Avatar
Trade: Extraordinary Carpenter
Rewards Points: 2,728
Just throw a couple of double 2x10's up there supported by the post on the end. There is no other way to do it .
NKLHD
knucklehead is offline
Old 01-15-2019, 07:53 PM   #11
You are on a need to know basis here.
You could do it without headers, but it might get kind of complicated and it might be a little over your head.
NKLHD
Old 01-15-2019, 08:07 PM   #12
Bradmxz's Avatar
Trade: Plasterer
I’d say about 6 inches.
Bradmxz is offline
Old 01-15-2019, 08:13 PM   #13
Bradmxz's Avatar
Trade: Plasterer
Yes that’s what I was thinking at first but figured I better ask someone, and what better place to ask. But the problem here is the inside of the cottage is going to be an open loft and it would look rather ugly to have them toe-nailed to the bottom of the other rafters.
No need for ignorance though. I came looking for advice and help not to be put down. I understand the concept of headers and load bearing. Because I’m not at this 30 years doesn’t mean I don’t have some understanding of it.
Bradmxz is offline
Old 01-15-2019, 09:00 PM   #14
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 1,018
Originally Posted by Bradmxz View Post
Because Iím not at this 30 years doesnít mean I donít have some understanding of it.
Yet you have done nothing to establish your credentials as a professional contractor here. While it's our custom as a professional courtesy to offer advice to fellow contractors about work that is outside of their specialty, that usually comes after a bit of pre-qualification that shows you actually belong on this site.
We are not here to tutor DIY'ers.
Tinstaafl is online now
The Following 2 Users Say Thank You to Tinstaafl For This Useful Post:
Fixed (01-16-2019), hdavis (01-15-2019)
Old 01-15-2019, 09:14 PM   #15
hdavis's Avatar
If you don't want toe nailing to show, either put solid blocking in to hide them, or use structural screws up through the top plate into the bottom of the rafter. Structural screws are faster, but they cost.
Tom M (01-16-2019)
Old 01-15-2019, 09:14 PM   #16
Bradmxz's Avatar
Trade: Plasterer
Ok then. Thank you for that. I guess I’ll leave and get help elsewhere. I am a contractor and framing just isn’t my specialty. Not a welcoming community I guess.
Bradmxz is offline
Old 01-15-2019, 09:25 PM   #17
hdavis's Avatar
Ok then. Thank you for that. I guess Iíll leave and get help elsewhere. I am a contractor and framing just isnít my specialty. Not a welcoming community I guess.
There are tons of DIYers that pose as contractors.
Establishing bonafides is as simple as a link to your website, youtube video, something that shows you as a plasterer.
That gets you going here.
Fixed (01-16-2019), VinylHanger (01-17-2019)
Ancient Knowledge Tour of Roof Framing SBE Builders Framing 17 11-14-2017 05:16 PM
Wood blocking with metal framing question dj90423 Commercial Construction 24 05-12-2016 02:20 PM
Chappell Framing Square Kent Whitten Tools & Equipment 122 05-31-2012 02:48 PM
Top 10 framing errors - and how to prevent them (From a Professional Builder Email) wallmaxx Framing 9 02-20-2012 07:57 PM
Help Wanted: Roof Framing Job near Charlotte, North Carolina modfab Help Wanted or Looking For Work 0 01-22-2012 06:23 AM
