Framing Bulkheads? - Framing - Contractor Talk
Framing Bulkheads?
Old 01-22-2012, 10:09 AM   #1
Coombs Construction
Leafan's Avatar
Trade: Owner operator of Coombs Construction
Rewards Points: 150
Framing Bulkheads?
Hey guys. Brief history I am a young GC have done countless basement, bathroom, and kitchen renos. Been doing this stuff for 15 years now.
Recently I started a Big job a complete house gut, underpin, second floor addition. For me this is a huge job. I have been handling everything well. Job has been moving along smoothly. We are 95% framed pluming is in HVAC in electrical starting Monday
My question to you all is what is the best way to frame out my bulkheads? Quickest and easiest method.??
I have done plenty of bulkheads in basements but I always use steel L track and firing channel. I more often than not frame out my bulkheads last. After the ceilings and walls are boarded.
But I don't think I can go about it the same way. I think I should be framing out the bulkheads now? Am I correct?
Framing Bulkheads?-image-2835307917.jpg   Framing Bulkheads?-image-959296541.jpg
Leafan is offline
Old 01-22-2012, 10:58 AM   #2
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 254
Re: Framing Bulkheads?
Without knowing every nitty-gritty detail, it certainly seems to make sense to do framing while you're doing framing.
The only exception would be if your bulkheads are going to get in the way of, for instance, the plumber's access to certain areas. He'll be blessing you if he has to form 10' lengths of pipe into pretzels to work them into place.
Tinstaafl is online now
Old 01-22-2012, 11:05 AM   #3
jlyons's Avatar
Trade: capenter
Rewards Points: 219
in my living room i tried something i had never done before. i nailed a 2x2 to my ceiling after board and a 2x2 to the wall. hung the drywall off the ceiling 2x2 and then snapped a line across back at desired height. screwed a steel stud on the back. cut drywall flush with stud. screw on bottom drywall plumbing as you go. very little material pretty quick, easy for 1 guy. pretty nice straight bulkhead.
jlyons is offline
Old 01-22-2012, 11:38 AM   #4
Nail-Bender
Brutus's Avatar
Rewards Points: 2,020
This is one I did in my parents basement. I was trying to use up all the scrap material that would of made it to the garbage.... :
Originally Posted by 2ndGen
If you haven't bled while working once in your life, you haven't worked!
Brutus is offline
The Following 2 Users Say Thank You to Brutus For This Useful Post:
JustaFramer (01-22-2012), knucklehead (01-22-2012)
Old 01-22-2012, 11:50 AM   #5
Coombs Construction
Leafan's Avatar
Rewards Points: 150
That's very similar to how I do mine normally. I use a steel L track on the ceiling. Cut my drywall to the desired hight of bulk. Attach to L track on ceiling. Level back to wall. Slap another L track there cut a bottom. BAM Perfect bulkhead everytime. I do this after drywall is on both ceiling and wall.
Leafan is offline
Old 01-22-2012, 12:14 PM   #6
donerightwyo's Avatar
Trade: custom builder
Rewards Points: 52
We often use a 9.5" TJI, screwed through the top flange to the bottom of the joists. It is super fast and a monkey could do it.
donerightwyo is offline
Old 01-22-2012, 01:30 PM   #7
Coombs Construction
Leafan's Avatar
Rewards Points: 150
We have to keep them tighter than that. The windows are very tall. I think we only have 10" to the RO
Leafan is offline
Old 01-22-2012, 03:07 PM   #8
knucklehead's Avatar
Trade: Extraordinary Carpenter
Rewards Points: 2,728
There are alot of different ways to do it, and there are not all the same
knucklehead is offline
Old 01-22-2012, 04:43 PM   #9
Forming and Framing
FramingPro's Avatar
Trade: Shell builder
Rewards Points: 3,582
damn that place looks really good.
How did the framing go?
Im after fortune and frame
http://www.proicf.com
FramingPro is offline
Old 01-22-2012, 05:33 PM   #10
KemoSabe
loneframer's Avatar
Rewards Points: 12,218
Is New Jersey the only place that requires the bottom of the joists draft stopped inside a bulkhead/soffit?
I always either plywood or sheetrock the enclosed space first, then frame the soffit.
I've done it a few different ways, but 2x2 on the ceiling, 2x2 on the wall and a 2x2 at the corner with 1/2" plywood to wrap it is fast, easy, uses up waste material and gives solid fastening for drywall/cornerbead.
loneframer is offline
The Following User Says Thank You to loneframer For This Useful Post:
We Fix Houses (02-02-2012)
Old 01-22-2012, 05:54 PM   #11
JustaFramer's Avatar
Trade: Exiled For Life
Rewards Points: 2,000
No. It is required here. Though the other day I seen a rough stair case that had final frame and no blocking. So things could have changed here.
I don't frame much anymore for a career.
JustaFramer is offline
Old 01-22-2012, 05:55 PM   #12
Coombs Construction
Leafan's Avatar
Rewards Points: 150
The framing went pretty smoothly. Was a tricky one though. The front trusses were fab'ed wrong and we ended up hand framing the gable. All and all it went good. There was a hell of a lot of detail on that roof every room on the top floor has coffered ceilings too.
Leafan is offline
Old 01-22-2012, 06:25 PM   #13
jb4211's Avatar
Rewards Points: 2,306
Is it just me, when I hear the term "bulkhead" I think of something to keep water back...like the ocean.
But in reading some of the posts, is bulkhead and soffit the same thing? Like, it's called a bulkhead in Canada and soffit hear. Or does everyone call it a bulkhead but me and I'm just wrong?
It wouldn't be the first time that's for sure?
Jon
jb4211 is offline
The Following 3 Users Say Thank You to jb4211 For This Useful Post:
davitk (01-22-2012), loneframer (01-22-2012), Mud Master (01-26-2012)
Old 01-22-2012, 06:37 PM   #14
davitk's Avatar
Trade: Perfessional Contracter
Rewards Points: 502
Originally Posted by jb4211 View Post
Is it just me, when I hear the team "bulkhead" I think of something to keep water back...like the ocean.
We got cable for the first time this fall, and the family has been watching these crazy Canadians on HGTV who keep saying "bulkhead" and using blue wood?
In WI it's "soffit".
davitk is offline
Old 01-22-2012, 06:44 PM   #15
topsail's trimcat
woodworkbykirk's Avatar
Rewards Points: 384
we typically try to keep them as small and light weight as possible, for bigger jobs where he hire the same drywall guy who hangs and tapes his own work. he will build bulkheads with steel stud.
on smaller jobs we frame them either with 2x, steel stud or just box things in with mdf
woodworkbykirk is offline
Old 01-22-2012, 07:30 PM   #16
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 254
I learned it as "bulkhead". Soffit is under the eaves of a house. The one that's perfectly descriptive but always gives me a "huh?" moment is "eavestroughs".
Old 01-22-2012, 07:31 PM   #17
JT Wood's Avatar
Trade: carpenter
Rewards Points: 2,560
I do the same, imo it is the fastest and best way.
I rip the plywood on my tablesaw, and it guarantees a perfect result.
Except it's better if the mechanicals are installed first
Airdrie AB Renovation Contractor | Kitchen Renovations | Basement Developments | Facebook
JT Wood Construction Serves Airdrie, Cochrane, Olds, Mountainview, Rockyview and Crossfield, Alberta.
JT Wood is offline
Old 01-22-2012, 08:49 PM   #18
Ciaos mitigator
chris klee's Avatar
Rewards Points: 1,290
we have to do it here too
CK Carpentry
chris klee is offline
Old 01-22-2012, 08:54 PM   #19
JT Wood's Avatar
Trade: carpenter
around here an eavestrough is a 5" aluminum channel
JT Wood is offline
The Following User Says Thank You to JT Wood For This Useful Post:
Brutus (01-22-2012)
Old 01-22-2012, 09:23 PM   #20
KemoSabe
loneframer's Avatar
Well along the coast, a bulkhead holds the land from slipping into the water and runs around 1000 bucks a foot, to start.
You tell a HO they need a bulkhead, they start to have convulsions.
Chappell Framing Square Kent Whitten Tools & Equipment 122 05-31-2012 02:48 PM
Help Wanted: Roof Framing Job near Charlotte, North Carolina modfab Help Wanted or Looking For Work 0 01-22-2012 06:23 AM
Framing Documents To Die For NC2X4 Framing 33 09-17-2010 10:45 AM
Framing Safety Safety Guy Tools & Equipment 3 08-13-2009 08:46 PM
Commercial wood framing mckellarman Commercial Construction 2 05-06-2009 05:11 PM
