Framing Bell Shaped Roof - Framing - Contractor Talk
Old 08-01-2014, 03:09 PM   #1
gbruzze1's Avatar
Rewards Points: 2,608
Down in Long Beach Island, New Jersey for vacation this week. A ton of work going on down here. I saw this roof and was wondering how is it done? Haven't had a chance to get close enough to see what they used, but was wondering what any of you may have used in the past. 2x12s bolted together with a mending plate? 14 or 16" LVL? Also, how do you figure out the curve, measure the dimension, etc. Just curious and impressed.
gbruzze1 is offline
Old 08-01-2014, 03:18 PM   #2
water re-locater
NYgutterguy's Avatar
Trade: Gutter installer
Rewards Points: 1,512
Re: Framing Bell Shaped Roof
Make sure you hit the chicken or the egg restaurant in beach haven. Awesome wings and cheesesteaks Sorry dont know much about framing.
NYgutterguy is offline
Old 08-01-2014, 04:23 PM   #3
Fire up the BBQ
griz's Avatar
Rewards Points: 46
Rafters pre-cut in the shop out of whatever stock is spec'd.
Sounds like you're in Loneframer country, maybe his job...
griz is online now
Old 08-01-2014, 04:31 PM   #4
gbruzze1's Avatar
Griz,
Regardless of what is spec'd, what would be the preferred method? I was thinking a sheet of 3/4" plywood sandwiched with 2x12's in a manner that would allow the rafter to be say, 18" wide or whatever was needed. So the plywood would be, say 18" and the 2x12s carriage bolted through. But would this be strong enough?
gbruzze1 is offline
Old 08-01-2014, 04:39 PM   #5
Fire up the BBQ
griz's Avatar
Rewards Points: 46
Originally Posted by gbruzze1 View Post
Griz,
That is precisely why we have & use Engineers.
griz is online now
Old 08-01-2014, 04:53 PM   #6
gbruzze1's Avatar
Ok. I was just wondering how guys have done it in the past.
gbruzze1 is offline
Old 08-01-2014, 06:01 PM   #7
Geometrist
Warren's Avatar
Trade: framing/remodeling
Rewards Points: 2
My profile pic is of a bell shaped roof. The long main rafters go first, these are the steep ones. The tails are just kick outs and the peak is usually very shallow and just rests on top of the others.
Warren is online now
The Following User Says Thank You to Warren For This Useful Post:
gbruzze1 (08-01-2014)
Old 08-01-2014, 06:09 PM   #8
KemoSabe
loneframer's Avatar
Rewards Points: 12,218
Not a bell, but the same principle. In this case, as is the same with the bells I've seen, the rafters are two plies of 3/4" plywood. They are glued and stapled together.
The architect has specifications on the plan concerning radii, center points, etc.
loneframer is offline
The Following User Says Thank You to loneframer For This Useful Post:
Old 08-04-2014, 03:49 PM   #9
GCTony's Avatar
Rewards Points: 506
Our shop just did a bunch of these but much bigger for a shopping center remodel and shipped them to FL. The architect generated and gave us the pattern, specified the plywood, epoxy adhesive and screws and screw locations. The plywood was 4 x 12 marine grade doug fir. We didn't do the install.
GCTony is offline
Old 08-04-2014, 05:36 PM   #10
Easyfier of Complexitries
digiconsoo's Avatar
Trade: Framing Components
Rewards Points: 1,552
Originally Posted by hdavis View Post
It's probably better you write about something where you aren't functionally ignorant, you're just embarrassing yourself.
Originally Posted by tipitop View Post
Trump is lucky he didn't mess with me.
http://www.digiconsoo.com
Last edited by digiconsoo; 08-04-2014 at 05:38 PM. Reason: Can't upload pics.......still.
digiconsoo is offline
Old 08-04-2014, 05:40 PM   #11
Geometrist
Warren's Avatar
Rewards Points: 2
Originally Posted by digiconsoo View Post
I think you need at least 10 posts to post pics.
digiconsoo (08-04-2014)
Old 08-04-2014, 05:53 PM   #12
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 14
No the links are there. Dropbox doesn't cooperate well with the forum software. Something like Photobucket would work.
Tinstaafl is online now
Old 08-04-2014, 06:00 PM   #13
Geometrist
Warren's Avatar
Rewards Points: 2
From dropbox
Old 08-04-2014, 07:33 PM   #14
muskoka guy's Avatar
Trade: framer/builder
Rewards Points: 558
We build round stuff all the time. We generally use 3/4 inch plywood. We set up a router on a radius jig we make ourselves in a large open area of the subfloor. We router the radius pcs then glue and screw the rafters or trusses together. Sometimes if the roof is wider that 8 feet we will have maybe three sheets getting routered to make one ply of the truss. Then we change the layout of the next sheets to create staggered joints. Some of the trusses we make are six layers per truss. Kind of sucks turning radius' for days on end to create the arch trusses. We do a lot of eyebrow dormers and radius edged roofs.
muskoka guy is offline
Old 12-22-2014, 07:29 PM   #15
digiconsoo's Avatar
We do it in a very similar manner, but cut the plywood on the CNC, then create modular sections that are delivered to the site, bolted together and then lifted as a unit.
Here's some pictures of a job we did a year ago for a fellow CT member.
This was a "reciprocal" design that allowed for the bell shape to be maintained on the interior, without interruption by collar ties or ceiling joists.
We actually prefabbed a lot on this job, including the front entry in the last picture.
The idea is to shorten the construction schedule by prefabbing some of the complex (curved) stuff that usually slows the job to a grind.
Framing bell shaped roof-imageuploadedbycontractortalk1419293883.835306.jpgFraming bell shaped roof-imageuploadedbycontractortalk1419293923.422560.jpgFraming bell shaped roof-imageuploadedbycontractortalk1419293959.906451.jpgFraming bell shaped roof-imageuploadedbycontractortalk1419294011.922778.jpgFraming bell shaped roof-imageuploadedbycontractortalk1419294070.472220.jpgFraming bell shaped roof-imageuploadedbycontractortalk1419294110.865665.jpgFraming bell shaped roof-imageuploadedbycontractortalk1419294152.867141.jpg
The Following 12 Users Say Thank You to digiconsoo For This Useful Post:
asevereid (12-22-2014), carpenter uk (12-23-2014), Derry (01-18-2015), Ed Michnick (12-22-2014), hdavis (12-22-2014), MattK (05-22-2015), muskoka guy (12-22-2014), overanalyze (12-22-2014), rmcivil (01-18-2015), SBE Builders (12-23-2014), Timuhler (12-22-2014), VinylHanger (01-16-2015)
Old 01-16-2015, 06:48 PM   #16
I prefer carpenter
marklo154's Avatar
Rewards Points: 81
That bell roof is very interesting. Not to much framing peaks my interest anymore.
marklo154 is offline
Roof Framer's Bible Framing A Bay Window Roof sbebuilders Framing 25 06-28-2015 08:28 PM
Framing addition - Matching existing roof plane ncornilsen Framing 18 01-11-2013 12:47 PM
Revised OSHA Reg's for Fall Prevention Roofmaster417 Roofing 19 03-16-2011 03:26 PM
Roof framing question snuddenstang Framing 37 01-31-2010 07:19 PM
Do You Need A New Roof ??? Perfect Roofing Roofing 0 02-10-2005 02:46 AM
