Framer Put 24 O.c Instead Of 16 O.c On Most Exterior Walls - Page 2 - Framing - Contractor Talk
Old 04-25-2012, 06:18 PM   #21
Randy Bush's Avatar
Trade: Exterior Remodeling
Rewards Points: 1,204
Re: Framer Put 24 O.c Instead Of 16 O.c On Most Exterior Walls
Originally Posted by Kent Whitten View Post
Can't trust framers at all
No comment
Randy Bush is online now
Old 04-25-2012, 06:42 PM   #22
topsail's trimcat
woodworkbykirk's Avatar
Rewards Points: 384
i personally like 6 " o.c.. more to nail baseboard, crown and chair rail to without using glue to the wall.
plus i love the look on the insulators face when they realize they gotta cut 2 million strips at 4.5 "
woodworkbykirk is offline
The Following 3 Users Say Thank You to woodworkbykirk For This Useful Post:
donerightwyo (06-03-2012), Metro M & L (06-04-2012), RobertCDF (04-25-2012)
Old 04-26-2012, 01:45 AM   #23
3bar's Avatar
Trade: carpenter
Rewards Points: 492
if its a 2x6 wall, i would go 24 personally. as for a 2x4 wall, it'd be ok too. just make sure to use 5/8 drywall.
3bar is offline
The Following User Says Thank You to 3bar For This Useful Post:
CanningCustom (06-04-2012)
Old 04-26-2012, 02:29 AM   #24
Dirtywhiteboy's Avatar
Rewards Points: 10,102
If you have a crew with no reputation they must be watched over by a highly qualified person, we all know there are a lot of fly by nights, bang to bang, slam her and run hacks out there
Dirtywhiteboy is offline
Old 04-26-2012, 07:09 AM   #25
Railman's Avatar
Trade: Railing
Rewards Points: 585
If the inspectors won't do a variance to allow it, putting a flat 2x4 between the 2' cntrs, on the interior side might allow it to pass. If not, it's jack up the roof, & put new walls under it!
Joe
Railman is offline
Old 04-27-2012, 12:33 PM   #26
Shingler extraordinaire
A&E Exteriors's Avatar
Trade: Roofing, Framing, siding, decks
Rewards Points: 13,540
Joe
I love that kind of work.
A&E Exteriors is offline
Old 06-03-2012, 09:35 PM   #27
VAviaCo's Avatar
Rewards Points: 250
Contractor I subbed from told a customer we'd put his garden shed up with a stud every 12". Because someone was concerned that the hardiplank on the outside would show waves at 16" oc. (with 7/16 osb too! What wave?). But he forgot to tell me. I framed it 16 oc. He bought more studs and told me to add one in every bay. That guy has a garden shed built 8" oc. I didn't have enough siding nails, so I only nailed the Hardi plank to every other stud. Looks fine from the outside. Looks like solid wood from the inside.
VAviaCo is offline
Old 06-03-2012, 10:07 PM   #28
otislilly's Avatar
Trade: general
Rewards Points: 75
deleted
otislilly is offline
Old 06-23-2012, 01:26 AM   #29
SoCalWoodWork's Avatar
Love the comment. 6" oc, thats a riot!
SoCalWoodWork is offline
You Know That You're A Framer When... WallMonkey Framing 549 06-18-2019 12:53 AM
I need a FRAMER, please help bigbaby Framing 65 08-18-2010 11:13 PM
Solo Framer MSBOY Construction 9 11-03-2009 10:40 PM
NC Framer JCI New Member Introductions 1 04-02-2009 07:33 PM
My Framer Needs a WELDER genecarp Framing 3 08-31-2008 12:28 PM
