FJP Studs? - Framing - Contractor Talk
FJP Studs?
Old 05-23-2010, 07:23 PM   #1
JT Wood's Avatar
Trade: carpenter
Rewards Points: 2,560
FJP Studs?
Anybody using them?
Likes?
dislikes?
comments?
One builder I work for started using Finger Joint studs.
I'm not sure what I think of them.
On first thought they seem to be half assed.
From an assembly perspective they do seem more straight.
Up here In a lift of FJP 2x6 9' precuts I can usually use 90 -95%
On standard spruce "premium studs" It's not unusual to cull 30%
The fj studs are more expensive than premium studs too.
One thing for sure,
VERTICAL USE ONLY.
JT Wood is offline
Old 05-23-2010, 08:46 PM   #2
Kent Whitten's Avatar
Rewards Points: 2,040
Re: FJP Studs?
If they are from Ainsworth...
We used them all the time when I lived in Seattle. For the most part, nice and straight. Sometimes the glue joint doesn't hold and one or two break at the glue joint. Definitely vertical use only. My house? Probably not.
SalmonFallsCabinetry.com
Kent Whitten is offline
Old 05-23-2010, 08:59 PM   #3
I like Green things
WarnerConstInc.'s Avatar
Rewards Points: 5,744
Re: FJP Studs?
I think they are nice for 9' and 10' walls.
Warner Mill Works
Facebook
YouTube
WarnerConstInc. is offline
Old 05-24-2010, 03:48 AM   #4
Kgmz's Avatar
Re: FJP Studs?
Same here, all we use for 9' and 10' walls.
They are straighter, resist warping better, and are actually made from a better grade than a premium stud because of the requirements for strength at the joints.
And as Framerman mentioned, you do run across a couple that just fall apart at a joint. So far we usually only get a couple of bad ones per house, so that would put us at 99%. And then those bad ones get used anyway for cripples, etc.
Kgmz is offline
Old 05-25-2010, 12:45 AM   #5
KennMacMoragh's Avatar
Trade: Repair/Remodel
Rewards Points: 3,364
Re: FJP Studs?
I usually hear that too, people claim they are straighter and that's why they are used. However, the framing company I worked for, BMC, used the worst kind you can buy. They were not straighter, they were far worse than non-finger jointed studs. we had to shim and shave 150 to 200 studs per house, all finger jointed studs.
It depends how the lumber company purchases their materials. BMC West would look at prices when they purchased from mills. Whichever was cheapest, that's what they would buy, so that's what they got was cheap.
KennMacMoragh is offline
Old 05-25-2010, 07:04 AM   #6
Box Builder
Morning Wood's Avatar
Rewards Points: 10,280
Re: FJP Studs?
FJP- Finger Jointed Pine. I don't think I'd use them for load bearing purposes unless they were made out of fir.
Morning Wood is online now
Old 05-25-2010, 09:48 AM   #7
Kgmz's Avatar
Re: FJP Studs?
Its been quite a few years since I have dealt with BMC West.
But I would have had them take them back and bring me good ones. No way I would take the time to do all that.
We have been dealing with Probuild formerly Lumbermens for quite a few years now, and Gray Lumber in Tacoma since I started 30+ years ago. And I have had very few problems like that with either of them. And if I do they are prompt and will do something about it.
Kgmz is offline
Old 05-25-2010, 10:22 AM   #8
JustaFramer's Avatar
Trade: Exiled For Life
Rewards Points: 2,000
Re: FJP Studs?
I wish there was a Gray's Lumber up by me.
JustaFramer is offline
Old 05-25-2010, 10:26 AM   #9
dprimc's Avatar
Rewards Points: 598
Re: FJP Studs?
I worked on a few jobs in Seattle where they were used. Onsite they never stayed dry and I definitely saw some problems when it got below freezing. Lots of glue joints falling apart.
They were nice and straight for tall walls, but I do my best to keep them dry even after the walls are up if I were going to use them.
dprimc is offline
Old 05-25-2010, 01:17 PM   #10
Re: FJP Studs?
You guys can keep your ProBuild,
I want my Carter-Lee back!
I have never actually seen a FJP stud.
neolitic is offline
Old 05-25-2010, 04:48 PM   #11
hurtlocker
nailkiller1's Avatar
Trade: homebuilder remodeler carpenter
Re: FJP Studs?
I have not used them in a while 10 years?
The only place I would use them
is on non load bearing walls 9' or shorter(they would have to be less expensive than a standard stud to even consider it)
The problem is the glue
when I build a house the frame should last a couple hundred years
If maintained properly
How long will the glue last 10 yrs 100 yrs?
nailkiller1 is offline
Old 05-25-2010, 06:18 PM   #12
Taylor8's Avatar
Trade: Insulation
Rewards Points: 75
Re: FJP Studs?
I've seen very few homes built with finger joint studs, and they are less expensive than premium studs here. I'm no framer, but I see no reason not to use them for non-load bearing.
200 years ago when homes were being built with first cut, full dimensional lumber, I'd expect a well framed house to last a few centuries. Today I doubt even the most well framed house, built with second cut lumber would last more than one century. Just my 2 cents..
Taylor8 is offline
Old 05-25-2010, 06:27 PM   #13
Framer53's Avatar
Trade: Handyman
Rewards Points: 366
Re: FJP Studs?
Well won't you be surprised in 2120!
Framer53 is offline
Old 05-25-2010, 06:40 PM   #14
Re: FJP Studs?
Just to clarify, I'm not bustin' on you or anything. The pine out west is different than what we get here. Not quite sure what it is, but we framed many homes with pine whether it was FJ or not. I think it may be lodgepole pine, but not quite 100% sure.
Structurally and stability wise, much better than the white pine we get here.
Old 05-25-2010, 06:40 PM   #15
Resident Pain
CanningCustom's Avatar
Rewards Points: 1,730
Re: FJP Studs?
We actually had were using then about 2yrs ago, in Ontario and them were deemed not fit for load points so we actually had fj stud's with actual 4x4 or 6x6 post's for all loads. As was said in earlier posts not in my house.
CanningCustom is offline
Old 05-25-2010, 08:02 PM   #16
Taylor8's Avatar
Trade: Insulation
Rewards Points: 75
Re: FJP Studs?
If in 2120, you find an average home built in 2010, that is still structurally sound, pm me and I will acknowledge your greater foresight.
Taylor8 is offline
Old 05-25-2010, 08:54 PM   #17
Dan
ApgarNJ's Avatar
Re: FJP Studs?
OSB that all these houses are built with won't last that long. houses will have to get resheathed, rebuilt etc. not even sure plywood will last more than a century. glad i don't use OSB.
ApgarNJ is offline
Old 05-25-2010, 11:59 PM   #18
Re: FJP Studs?
They didn't have good ones. They were a lumber supplier and a framing company so they sold the lumber to themselves. Yeah, they weren't smart enough to fix the problem, sure enough they went bankrupt.
Old 05-26-2010, 05:04 AM   #19
AtlRemodeling's Avatar
Trade: Residential Remodeling
Rewards Points: 250
Re: FJP Studs?
I have not seen FJ studs in 10-12 years in Atlanta. When they were first introduced, Georgia Pacific invited a group of us to there facility here and they showed test after test on the strength of FJ vs standard studs. The FJ studs won every time!
I was very impressed and we used them for a while but then the suppliers began phasing them out. I asked why and could never get a straight answer. Makes you wonder???
AtlRemodeling is offline
Old 05-26-2010, 08:22 PM   #20
galla35's Avatar
Rewards Points: 250
Re: FJP Studs?
The FJ studs we get suck i can rip them in two..
In the 80's we had Reagan in office, Bob Hope, and Johnny Cash. Now, we have President Obama, no hope and no cash
galla35 is offline
Removing studs from a load bearing wall. Russ25nys Framing 36 06-13-2009 08:52 PM
Extending 4" studs to 5 1/2" Danno6102 Carpentry 18 05-29-2009 06:38 PM
Attaching wood studs to metal studs AlSmith Framing 13 05-16-2009 10:58 PM
Grab bars - studs and spec hollow wall anchors jmfrederick Plumbing 5 12-13-2008 01:12 PM
Replacing balloon framed studs Danno6102 Framing 10 08-19-2008 05:24 AM
