DISCUSSION Sheathing Walls On The Deck Or After Standing? - Page 2 - Framing - Contractor Talk
Old 04-06-2018, 08:20 PM   #21
GC/carpenter
Calidecks's Avatar
Rewards Points: 10,248
Re: DISCUSSION Sheathing Walls On The Deck Or After Standing?
We were still framing one complete home per day.
Mike.
_______________
Calidecks is offline
Old 04-07-2018, 02:17 PM   #22
mstrat's Avatar
Trade: New Construction & Remodeling
Rewards Points: 1,526
Yeah, around here rough structure inspection can be done after all roofing and siding/cladding is done...
mstrat is offline
Old 04-08-2018, 09:14 AM   #23
youngcarpenter's Avatar
Trade: Carpentry: Frame to Finish
Rewards Points: 96
Same here the inspector usually doesn't make it out on site till the house is at least half sided. The roofer are usually out within 4-6 hours of the roof decking being done. Schedules are tight!
"Far and away the best prize life has to offer is the chance to work hard at work worth doing" -TR
youngcarpenter is offline
Old 04-08-2018, 01:05 PM   #24
GC/carpenter
Calidecks's Avatar
We call framing, electrical, and plumbing all at the same time. We can get framing unless the roof is stacked.
Mike.
_______________
Old 04-08-2018, 04:44 PM   #25
402joel's Avatar
Trade: carpenter
Rewards Points: 413
Electrical, plumbing, HVAC must be inspected and passed, roof shingled complete, then framing here
NRA Life Benefactor
SAF Life
402joel is offline
Old 04-08-2018, 05:17 PM   #26
txgencon's Avatar
Rewards Points: 468
Originally Posted by BattleBornNV View Post
Mixed bag out west. I see most residential framers sheathing after plumb and line. Could be a product of concrete quality of slab on grade or neglect in shimming joist/rim/sole plate of raised floor.
I grout all plates before framing and bolt the sole plate down, frame with a dead plate and shear all walls flat. Stack frame. A bit of work in the beginning but it pays dividends on commercial and multi story structures.
But even then, at some point, have to get out there and install fillers, nail off flyers etc. can usually catch that when the skins are going up and tight schedule inspections to align with the completion.
Not familiar with the term "dead plate".
Does the dead plate stay or is it removed once the wall is up?
I used to think a lot of the people I encountered were stupid - then I realized how much I was overestimating them.
txgencon is offline
Old 04-08-2018, 05:44 PM   #27
BattleBornNV's Avatar
Trade: General contractor
Rewards Points: 422
Iíll detail the slab with the snap and then plate with 3 plates. I havenít framed myself in many years but itís how I was taught in the union and what Iíve passed down. Mostly working with 3x or 4x sole plate.
So Iíll plate with 3. Sole plate, dead plate, frame plate.
When the wall is framed, can bump the dead plate on layout and short nail the framing members. Square it and shear it flat, without nailing off the dead plate.
Raise the wall, knock off the dead plate, land it, toe nail framing members to sole plate, nail off shear panel to sole plate.
If itís a 2x sole plate, which I havenít seen on a project in 10 years for bearing walls, could grout it then pull it and frame with it. Could do with 3x as well I guess, if guys felt like banging 20ís, which they often do not.
Interior non bearing partition walls I just frame after all the bearing walls are up and the floor/roof structure is completed. Easier to maneuver in the building (or unit) without them.
BattleBornNV is offline
The Following User Says Thank You to BattleBornNV For This Useful Post:
txgencon (04-08-2018)
Old 04-08-2018, 10:52 PM   #28
Fire up the BBQ
griz's Avatar
Rewards Points: 2,462
Mike.
_______________
WTF....you guy work half days????....
griz is offline
Calidecks (04-08-2018)
Old 06-18-2018, 10:12 PM   #29
Lee j c's Avatar
Sheathing the walls after they're up is much more difficult in my experience. Doing them flat on the deck presents it's own difficulties I guess but with a few hands on the extra weight is usually do-able.
We're in North West Ohio.
Lee j c is offline
Old 07-27-2018, 04:31 PM   #30
META's Avatar
Trade: General and Trades
Rewards Points: 7,580
I frame, sheet, housewrap, add rakes to gables, etc..to everything I can on the ground. There are tricks to sheeting walls on deck to mitigate out of square walls.
MI, low wind area with no wall sheathing inspections.
META is online now
Free standing deck posts builder2345 Decks & Fencing 7 10-29-2013 05:57 AM
Deck and porch framed maleko Decks & Fencing 179 09-19-2012 09:16 PM
cedar fence and small historic deck swartzj81 Decks & Fencing 2 09-02-2012 03:01 PM
Removing 3 layers of asphalt shingles and deck sheathing at one time? realelectrician Roofing 21 07-12-2012 09:07 PM
Trex Deck damage ?'s Celtic General Discussion 15 11-02-2009 07:45 PM
