Trade: Carpentry: Frame to Finish
Rewards Points: 96
DISCUSSION Sheathing Walls On The Deck Or After Standing?
So Im from the northeast and generally we square and sheath our walls on the deck and then stand them up and brace them. What do you all do? Give your location and how you do it. Im curious about different techniques
Warning: The topics covered on this site include activities in which there exists the potential for serious injury or death. ContractorTalk.com DOES NOT guarantee the accuracy or completeness of any information contained on this site. Always use proper safety precaution and reference reliable outside sources before attempting any construction or remodeling task! |
Advertisement |
Capra aegagrus
![]() ![]() Trade: Remodeler
Rewards Points: 76
Re: DISCUSSION Sheathing Walls On The Deck Or After Standing?
Pretty much the same here in PA. There are always exceptions; partial sheathing if doing the whole thing would make it too difficult to lift, for instance. Sustained high winds can make it a bit chancy, too.
All else being equal, it's a heckuva lot more efficient sheathing on the flat rather than vertical. Advertisement |
Trade: General contractor
Rewards Points: 422
Mixed bag out west. I see most residential framers sheathing after plumb and line. Could be a product of concrete quality of slab on grade or neglect in shimming joist/rim/sole plate of raised floor.
I grout all plates before framing and bolt the sole plate down, frame with a dead plate and shear all walls flat. Stack frame. A bit of work in the beginning but it pays dividends on commercial and multi story structures. But even then, at some point, have to get out there and install fillers, nail off flyers etc. can usually catch that when the skins are going up and tight schedule inspections to align with the completion. Sent from my iPhone using Tapatalk |
The Following 3 Users Say Thank You to BattleBornNV For This Useful Post: |
Sponsored Links | |||
Advertisement |
Trade: Contractor Grunt
Rewards Points: 252
That’s how I was taught but as a loner I have to sheet after the Wall is up, otherwise it’s too heavy.
I watch the production framers when there are new houses going up around me and even on 4 and 5 man crews they’re now sheathing after standing. Only thing I can think is the skill level is requiring it. Maybe the foreman thinks he can layout and slap up the walls then leave the sheathing for his low skilled help while he and his #1 guy move on???? |
#5 | |
Rewards Points: 422
Re: DISCUSSION Sheathing Walls On The Deck Or After Standing?Quote:
I think your on to something there. Framing out here is so compartmentalized maybe they leave it for the “Panel” guy. Who seems to be the same guy that sheaths decks and installs HD’s/floor to floor straps etc. Sent from my iPhone using Tapatalk |
#6 | ||
Hack
Rewards Points: 24
I'm still trying to convince the boss into letting us sheath AND wrap the walls, plus getting the gables sheathed and wrapped when they come off the truck... I hate sheathing gables off the ladder. Sent from my SM-G530W using Tapatalk
How to figure your pricing: http://goo.gl/Il8c2 L+M+O+P/ Pricing, Estimating, And Success Charging tree fiddy per lineal BOB ![]() |
#7 | |
Trade: carpenter
Rewards Points: 492
find a better outfit to work for... |
The Following User Says Thank You to 3bar For This Useful Post: |
asevereid (02-26-2018)
Rewards Points: 1,732
For the most part, we sheath on the deck. One exception is garage walls. For some reason they always seem to be messed up. For those, I stand them up, bare, then sheath them afterwards.
Regarding sheathing off an extension ladder. I've done it. Not happy about it. Sometimes you don't have the equipment to get it done, right. Have to go with what you've got. Of course that was in my younger years. We always use wall jacks. Don't have to worry about the weight. |
always building
Trade: general constructiion
Rewards Points: 2,224
you also have to consider "production" vs "custom"... different approaches with different manpower
"Building trust one job at a time." www.RDPontheWeb.com San Diego Contractor Deck and Patio Cover Builder |
Trade: Carpenter Contractor
Rewards Points: 452
On easy stuff, sheet and tyvek on the ground. It can be tricky to get the wall square to sheet, but it saves a lot of energy versus sheeting from a lift.
On single story or garages, it’s not too bad to sheet after the walls are up. I have some wall jacks, I’ve ever used em though, the gradall does a better job. The biggest I’ve built were 16’ tall and 32’ long for a 120’ shop, framed, sheeted, and papered on the ground then lifted them with the gradall, got to put your straps apart enough to keep from racking the wall, but it worked out pretty slick. Sent from my iPhone using Tapatalk
Professional wood welder |
Rewards Points: 5,244
Re: DISCUSSION Sheathing Walls On The Deck Or After Standing?![]() For a treehouse, it's definitely better to sheet before standing. Sent from my iPhone using Tapatalk |
The Following User Says Thank You to Mordekyle For This Useful Post: |
andyroof1979 (06-20-2018)
GC/carpenter
![]() Trade: Decking, Railing, Carpenter/General Contractor
Rewards Points: 1,340
It's very rare to sheath walls when they are on the ground here. Yes because the slabs are never perfect.
Mike. _______________ ![]() ![]() |
GC/carpenter
I came from several hundred home tracts as a lead. There are many times the whole wall doesn't get shear. Stucco doesn't require it. However, we had a snapline plate and detail crew, sheeting crew, a hardware crew, a beam crew, stackers. Plumb and line crew, Etc. We were framing a complete house a day. It has everything to do with speed.
Trade: Handyman
Rewards Points: 366
We found it much faster to sheathe everything on the ground if at all possible. less time consuming.
As far as the rest of your crews that are specialized, we just sent the laborers back to nail the hardware. Then again we would seldom build more that one house in a subdivision at a time. We were all over the area framing. |
The Following User Says Thank You to Framer53 For This Useful Post: |
fjn (04-07-2018)
Rewards Points: 50
Ever since we purchased Wall jacks we’ve been sheathing everything on the slab before standing. Make sure the stem is level, square the wall and shear it. Saves us a ton of time. Two of us just finished framing a 1700 sq.ft. house with 9’ walls. With wall jacks we were able to build 25’ walls with full shear.
There is such a shortage of framers here we’ve had to frame the last four houses ourselves just to maintain a schedule. |
Goin' Down in Flames....
Trade: Highwayman
Rewards Points: 754
All you guys talking about wrapping on the deck....
No nailing inspections? Delta |
#17 | |
Hack
Rewards Points: 24
Unless there has been a specific nail pattern called out on the plans, then the paper is left off. Sent from my SM-G530W using Tapatalk
#18 | |
GC/carpenter
Nailing inspections here are critical. The hardware we use is crazy as well. It's all for siesmic. Our inspectors walk every wall to make sure no nails are too deep and properly spaced. Each wall can have different nailing schedules. It just depends on the engineering. Mike. _______________ ![]() ![]() |
The Following 2 Users Say Thank You to Calidecks For This Useful Post: |
asevereid (04-06-2018),
Seven-Delta-FortyOne (04-06-2018)
#19 | |
Trade: Highwayman
Rewards Points: 754
And the inspectors are very strict on depth. Overdriven nails will get called every time. Delta |
The Following User Says Thank You to Seven-Delta-FortyOne For This Useful Post: |
Calidecks (04-06-2018)
#20 |
Trade: Handyman
Rewards Points: 366
You California guys have to go through so much just to build a house.
No nailing inspections here. Most of the country does not have the codes you have to work with. Advertisement |
Idothat (06-21-2018)
Display Modes | Rate This Thread |
Thread | Thread Starter | Forum | Replies | Last Post |
Free standing deck posts | builder2345 | Decks & Fencing | 7 | 10-29-2013 05:57 AM |
Deck and porch framed | maleko | Decks & Fencing | 179 | 09-19-2012 09:16 PM |
cedar fence and small historic deck | swartzj81 | Decks & Fencing | 2 | 09-02-2012 03:01 PM |
Removing 3 layers of asphalt shingles and deck sheathing at one time? | realelectrician | Roofing | 21 | 07-12-2012 09:07 PM |
Trex Deck damage ?'s | Celtic | General Discussion | 15 | 11-02-2009 07:45 PM |
Go to Page... |
