Differences In 3/4" OSB Subfloor - Framing - Contractor Talk
Old 08-07-2019, 12:26 PM   #1
CCCBuilder's Avatar
Rewards Points: 14
A local big box store (green one) sells 3/4" 4' x 8' T&G OSB in various brands. Their unbranded version is of course the cheapest and just called Sturd-I-Floor at $13.50, the next step up is PointSIX brand Sturd-I-Floor at $17.50.
Hoping someone has used both and can tell me what the differences were?
I have only used Advantec ($$$$$) and PointSIX ($$$$) but would like to use this cheaper stuff if it's all the same company just not getting branded and price increased from that. I was happy with both Advantec and PointSIX.
CCCBuilder is offline
Old 08-10-2019, 08:27 PM   #2
META's Avatar
Trade: General and Trades
Rewards Points: 5,646
Re: Differences In 3/4" OSB Subfloor
I am not sure of the differences, but look up their respective span loads, etc.
META is offline
The Following User Says Thank You to META For This Useful Post:
Rio (08-10-2019)
Old 08-10-2019, 11:31 PM   #3
Designer/Contractor
Rio's Avatar
Rewards Points: 314
Should be stamped right on the sheets.
Rio is offline
The Following 2 Users Say Thank You to Rio For This Useful Post:
Calidecks (08-11-2019), greg24k (08-11-2019)
Old 08-11-2019, 12:46 AM   #4
Fire up the BBQ
griz's Avatar
Rewards Points: 378
a prime place to go high quality material, glued and screwed install, over under spanned framing is the sub-floor.
virtually impossible to fix a poor quality material or a low budget install.
will eventually ruin you....
griz is online now
The Following 4 Users Say Thank You to griz For This Useful Post:
Bull Trout (08-11-2019), Fouthgeneration (12-09-2019), greg24k (08-11-2019), Joe Acevedo (12-09-2019)
Old 08-11-2019, 07:08 AM   #5
Big Johnson's Avatar
Trade: Contractor Grunt
Rewards Points: 574
The problem with the higher grade T&G OSB is when the edges swell they really really suck to sand. It’s almost like sanding concrete. If you do buy a top end sub floor, get one with a sand guarantee and be ready charge the manufacturer when you have to sand it.
Big Johnson is offline
Justin Rhoades (08-11-2019)
Old 08-11-2019, 10:45 AM   #6
Justin Rhoades's Avatar
Trade: framer
Rewards Points: 170
Advantech is pretty good (in my experience) about paying for decking that needs sanded.
Justin Rhoades is offline
Old 08-11-2019, 12:12 PM   #7
Focusing on solutions.
pinwheel's Avatar
Rewards Points: 94
I've yet to have to sand seams on advantech before laying hardwood over it.
pinwheel is online now
The Following 2 Users Say Thank You to pinwheel For This Useful Post:
402joel (12-11-2019), EricBrancard (08-11-2019)
Old 08-11-2019, 07:34 PM   #8
EricBrancard's Avatar
Trade: Builder/Renovator
Rewards Points: 532
Originally Posted by Big Johnson View Post
The problem with the higher grade T&G OSB is when the edges swell they really really suck to sand. Its almost like sanding concrete. If you do buy a top end sub floor, get one with a sand guarantee and be ready charge the manufacturer when you have to sand it.
Any commercial flooring sander will knock it down with zero effort. But with Advantech youd have to leave it exposed a long time for edges to swell.
EricBrancard is offline
The Following User Says Thank You to EricBrancard For This Useful Post:
pinwheel (08-11-2019)
Old 08-12-2019, 06:13 AM   #9
Rooster Cogburn's Avatar
Trade: Master carpenter
Rewards Points: 332
You can't beat advantech.
Rooster Cogburn is offline
Old 08-12-2019, 06:52 AM   #10
Rewards Points: 574
The one I rent must not be commercial then. It takes the regular grade down like butter, the no-sand warrantied osb not so much.
Old 12-09-2019, 08:54 PM   #11
Joe Acevedo's Avatar
Trade: Framing Contractor
Rewards Points: 20
X2
Joe Acevedo is offline
Old 12-09-2019, 09:53 PM   #12
Fouthgeneration's Avatar
Trade: Masonry
Rewards Points: 9,335
Unless you are in the entry level homes/shacks or cheap apartments, IMHO 1.25" OSB/plywood is a NO BRAINER for added quality at a tiny Sq. Ft. cost.
In a "cheap" apartment the thicker floor is going to provide quieter units, All other things being equal, and lower long term floor covering costs....
If you can use wood trusses at 19.2" or 24" centers, you save even more $ on MEP labor as fewer trusses = less drilling and easier venting....
Fouthgeneration is offline
