Continuous Jacks/trimmers Or Notch Sill Into Them - Framing - Contractor Talk
Old 04-01-2018, 08:36 PM   #1
youngcarpenter's Avatar
Trade: Carpentry: Frame to Finish
Rewards Points: 96
What do ya'll do for window framing on exterior load bearing walls.
Do you run the trimmer/jack from the bottom plate all the way up the bottom of the header or do you run a small cripple from the bottom plate put your sill or double sill in on top of the small cripples and then your trimmer/jack sits on the sill?
I was taught to do it the second way I mentioned and we do double sills.
I learned how to frame in New England. I don't know if its a code requirement up there but we all do it like that.
How do you all do it and where are you from?
youngcarpenter is offline
Old 04-01-2018, 08:50 PM   #2
jacob95's Avatar
Re: Continuous Jacks/trimmers Or Notch Sill Into Them
I run my king stud, jack stud from bottom plate to bottom of my header and then I put a cripple under my sill and from sill to my header at my rough opening size. It makes it easy if you ever need to adjust your RO size because your sill isnít sandwiched in between studs.
jacob95 is offline
The Following User Says Thank You to jacob95 For This Useful Post:
jlhaslip (04-02-2018)
Old 04-01-2018, 08:56 PM   #3
mrcat's Avatar
Trade: Pole Barns, Residential Framing
Rewards Points: 60
I was taught to do it the same as you, but now do full length and put a trimmer under the sill.
I was told the full length jack makes for a stiffer wall, which makes sense.
Sent from my SM-G900V using Tapatalk
mrcat is offline
Old 04-01-2018, 09:00 PM   #4
Texas Wax's Avatar
Rewards Points: 2,286
All in all the the split shoulder (second method) generally is a tighter way to frame. Not quite as fast as the traditional slam the sill between jacks method.
Having set and trimmed windows in both methods ... Split shoulder also keeps the wall thickness growth to a minimum. Less drywall abuse to get casing to touch the jamb.
...as the page loads, so go the days of our lives, at CT
Texas Wax is offline
Old 04-02-2018, 12:25 AM   #5
diplomat
Golden view's Avatar
Rewards Points: 1,550
split jacks/trimmers are weaker to wind loads unless you add extra kings.
Window sills are almost never a weak point in the wall. No need to support it on ends as long as cripples are on layout.
Golden view is offline
Old 04-02-2018, 12:36 AM   #6
Sure, I can do that...
jlhaslip's Avatar
Trade: carpentry/renovations
Rewards Points: 196
Splitting the Jack will fail code here.
Resting on the Jack on the sill allows for shrinkage and is weaker as per above.
Add Sill Jacks under each end to support the sill.
jlhaslip is offline
Old 04-02-2018, 12:51 AM   #7
TheConstruct's Avatar
Trade: Renovations & Carpentry
Rewards Points: 1,890
Jack needs to be continuous by code here.
TheConstruct is online now
Old 04-02-2018, 08:10 AM   #8
Big Johnson's Avatar
Trade: Contractor Grunt
Rewards Points: 66
http://www.jlconline.com/how-to/framing/split-jacks_o
I’d think 2x6 framing would be more forgiving but if you’re doing 2x4 you might want to get pickier. Also depends on where you’re building. Hurricanes, earthquakes, tsunamis, typhoons, global warming, fracking quakes, etc, etc, etc.
Big Johnson is offline
Old 04-02-2018, 10:10 AM   #9
RyMar Builders's Avatar
Rewards Points: 50
King stud on each side of the beam, two trimmers supporting the beam on each side, cripples on the layoutmarks with scrap pieces nailed to the trimmers on each side to support the sill plate along with the cripples, and of course cripples over the beam. This passes code on my location.
RyMar Builders is offline
Old 04-02-2018, 10:20 AM   #10
txgencon's Avatar
Rewards Points: 468
Continuous jacks. Green (as in energy efficient - not inexperienced) building inspectors/certifiers want to see Simpson brackets for the sill to jack connection. If the sill to plate distance is 24" or less, no cripples.
I guess you could also use a couple of dominoes for that joint or maybe just a couple of TimberLok lag screws (maybe need to pre-drill).
I used to think a lot of the people I encountered were stupid - then I realized how much I was overestimating them.
txgencon is offline
Speed square with scribing notch at 3/4" Steve_C Tools & Equipment 3 02-12-2015 02:53 PM
Rotten Sill Plate/Bottom Plate/Header Joist/Rimboards Peco2014 General Discussion 7 10-25-2014 10:25 PM
Rotted sill plate and broken joist repair netlinks Framing 0 07-18-2012 10:24 PM
thermatru sill problem AustinDB Windows, Siding and Doors 16 06-20-2012 07:19 PM
Sill Band/plate joist cavity insulation. jongig Insulation 6 01-22-2010 12:12 PM
