Adding A Ledger Board To A Exterior Insulated Header Joist - Framing - Contractor Talk
Old 09-17-2008, 10:07 PM   #1
ryanh's Avatar
Trade: Home Construction/Reno
Rewards Points: 75
Hello.
My header/rim joists on a house i'm framing our moved in 1.5" all around the foundation to allow for exterior 1.5" R7 rigid insulation, The exterior osb on the walls will run down to a inch below the bottom of the headers. Can i still add a ledger board for my deck? I've attached them with lag bolts right through the sheathing into my header joist on the other side, but havent attempted a install where there is 1.5" of insulation between the ledger and the header joist.. Just drill through and use longer lag bolts and it should be ok?
looks somewhat like the diagram below but theres no insulation yet on the inside. SIDING> OSB> 1.5" POLYSTYRENE INSULATION > HEADER JOIST
ryanh is offline
Old 09-17-2008, 10:42 PM   #2
Snobnd's Avatar
Trade: Remodeling 30+ yrs
Rewards Points: 4,794
Re: Adding A Ledger Board To A Exterior Insulated Header Joist
The I joists will offer little support. Might I suggest adding Piers close to the house (free standing) or bolt it to the concrete wall.
Snobnd is offline
Old 09-17-2008, 10:49 PM   #3
Dan_Watson's Avatar
Rewards Points: 2,748
Header joist?
Dan_Watson is offline
Old 09-17-2008, 11:59 PM   #4
BuiltByMAC's Avatar
Trade: Deck guy
Rewards Points: 2,270
If your rim joist is just an engineered I-beam joist, that's not enough support for a deck ledger in and of itself, regardless of the insulation issue.
You'll want solid (2x12) blocking between your house I-beam joists (every other bay) w/ plywood fillers to fill out the gap between block and I-beam web. This goes on the inside of your house rim joist.
As to the insulation issue - myself, I'd have solid blocking behind your deck ledger board connection points all the way through to the interior blocking. That would mean plywood fillers on both sides of the rim joist (instead of insulation) where you were planning on bolting the deck ledger to the house (use through bolts instead of lags).
Having said that, I'm going to keep tabs on this thread myself 'cause others may have a more elegant solution.
Mac
BuiltByMAC is offline
Old 09-18-2008, 12:20 AM   #5
Kgmz's Avatar
Is your header/rim joist a I-joist?
You really did not clarify this and said it is similar to pic.
If it is you cannot hang anything from it.
Now did you know when this was framed that a deck was going to be installed?
And if you did, did you tell the I-joist supplier/engineer that a deck was going to be installed on this rim.
Normally if you tell them, they will spec a LVL for a rim joist. With a LVL you could then hang a deck off of it. And remember you cannot use normal framing lumber as a rim joist with I-joists, ie. 2x12 hem-fir, etc.
I always make sure when I am ordering the i-joist package that they know if a deck is going to be installed.
You can then install the deck ledger with Simpson SDS screws or a through bolt. I don't use lags because I just don't trust them in veneered lumber. And usually use through bolts with very larger washers, and spacers to keep the ledger away from the wall.
Kgmz is offline
Old 09-18-2008, 12:22 AM   #6
Kgmz's Avatar
Mac
Mac has a good solution here if you need to retrofit this.
But this will entail cutting and removing the exterior sheathing, etc.
And just reread your post. You said something about lagging into the header joist on the other side. I hope this was not a I-joist also, and why does the other side not have the insulation that this side has?
Kgmz is offline
Old 09-18-2008, 12:45 PM   #7
Kent Whitten's Avatar
Rewards Points: 2,040
I haven't seen a detail like that for awhile. It's the old school TJI rim method I'm not even sure they do this anymore.
But to put a ledger on that? No. You need meat. You'd need to replace that TJI with some type of approved rim board and would be better to double that sucker up so your lags really grab into it.
But to have 1.5" of ridgid insulation on top of that, it's not a good scenario. You are essentially floating your lags for 2" or so before you get to the meat part. I'd suggest putting a solid 2x there instead of the insul board and insulating inside the rim to make up for it.
SalmonFallsCabinetry.com
Kent Whitten is offline
Old 09-23-2008, 12:10 AM   #8
ryanh's Avatar
Rewards Points: 75
Not using LVL for joists, using 2x10's for all joists. rim joists had to be moved in 1.5 all around the house so that they would fit properly on the center beam so we added 1.5" insulation all around (pink stuff). Now they decided they want a deck spaning the front of the home(52' wide). We have 2" R10 rigid insulation on the backside of the rim joists also so I guess in the front we will take it off and add another 2x10 for a double rim joist and that should be good?
ryanh is offline
Old 09-23-2008, 12:21 AM   #9
BuiltByMAC's Avatar
Trade: Deck guy
Originally Posted by ryanh View Post
Not using LVL for joists, using 2x10's for all joists. ...in the front we will add another 2x10 for a double rim joist and that should be good?
As long as your rim joist is a solid 2x10 as well, that'd be good 'n solid. Mount your pt ledger, flash properly, run bolts through and you're good to go...
Mac
Old 09-23-2008, 02:39 PM   #10
ryanh's Avatar
Rewards Points: 75
It is solid, we just have that 1.5" insulation in front. I'll just remove it and add another 2x10 in there
ryanh is offline
Old 09-23-2008, 05:16 PM   #11
KennMacMoragh's Avatar
Trade: Repair/Remodel
Rewards Points: 3,364
Sounds good for your deck. But you plan on getting all this approved by your building department right? If your inspector sees a deck with nothing on the plans, he'll say, uhh what's this? Decks that I have framed always spec out what kind of lags to use, how far apart to space them, what size ledger/hangers, etc. That should all be approved first.
About removing your insulation board, you're in Canada so I have no idea what the codes are. But maybe that's required because of the cold weather. You might have to rip out the 2 x 10 you have in there and cut little squares of that foam to put between each joist. I would find out first.
Btw, some framing tips, do as much as you can on the ground. Generally the more you build on the ground, the faster. Before standing the walls, I would have had both top plates on, blocking for my osb seams in, the lower part of osb on, you can let it overhang the bottom of your wall while it's sitting on the ground. And when you build your deck, nail the joist hangers on your ledger while it's on the ground, not after you attach it to the building.
KennMacMoragh is offline
Old 09-23-2008, 06:45 PM   #12
Rewards Points: 2,000
Maybe your fir lumber lets you
get away with that.
With TYP there is too much variation
in the dimensions.
That's a prescription for a wavy
deck.
We set the joist by the top.
neolitic is offline
Old 09-23-2008, 08:53 PM   #13
get away with that.
in the dimensions.
deck.
Never seen anyone do that, but not a bad idea. Actually it is a problem sometimes with fir lumber. I shim up the low ones and notch out the high ones. But usually I don't have to do that, and even if the joists aren't perfectly in-line, the decking can cover it and come out straight.
ledger for pergola question soupdizzle Decks & Fencing 20 08-30-2008 10:30 PM
??? Whats the best way to spread the news about your company? jmgrahamjr Marketing & Sales 21 06-24-2008 03:46 AM
Window header 2x6 framing Atlantex Framing 20 11-06-2007 10:55 PM
bathroom subfloor:hardy board & joist reinforcement yule1111 Flooring 4 09-27-2007 09:18 PM
Ledger board flashing, inside corner mickeyco Decks & Fencing 3 12-12-2006 10:59 PM
