2x10 Joists - Framing - Contractor Talk
2x10 Joists
Old 05-09-2009, 07:55 AM   #1
Plumber / Carpenter
Bill's Avatar
Trade: Virginia Building and plumbing contractor
Rewards Points: 1,014
2x10 Joists
What is the max span allowable for a 2x10 set @ 16" o.c.?
I need to add a room upstairs and the joists will be 16'. I dont have an updated code book. I could even install the 2x10's 12" o.c. if need be. I just dont want to have to use 2x12's because the roof lines will not line up then with the additional 2".
Is it beer thirty yet
Virginia Department of Licensing
Virginia Plumbing Codes
Bill is offline
Old 05-09-2009, 07:58 AM   #2
genecarp's Avatar
Rewards Points: 2,000
Re: 2x10 Joists
Here you go, the credit for this site goes to Mac, G
http://www.awc.org/calculators/span/...rcalcstyle.asp
genecarp is offline
Old 05-09-2009, 08:52 AM   #3
Kent Whitten's Avatar
Rewards Points: 2,040
Re: 2x10 Joists
When I click on that link, my browser window keeps restoring down. Anyone else getting this also? Even when I hit a drop down arrow, same thing.
Nice find though.
SalmonFallsCabinetry.com
Kent Whitten is offline
Old 05-09-2009, 09:02 AM   #4
Dave from Macatawa
macatawacab's Avatar
Trade: GC, cabinet maker and remodeler
Rewards Points: 250
Re: 2x10 Joists
The simple answer is yes a 2x10 @ 16" oc will work but then...
what is the wood species and what is the grade?
A # 1 or # 2 Southern Pine or Doug Fir will work but some other species don't. That is from the MI building code so check VA code but for planning purposes it would work. Check TJI pricing and sizing too.
macatawacab is offline
Old 05-09-2009, 09:03 AM   #5
ticktock's Avatar
Trade: Pipe Fitter
Rewards Points: 25
Re: 2x10 Joists
framerman - it's working ok with firefox
ticktock is offline
Old 05-09-2009, 09:23 AM   #6
Re: 2x10 Joists
That is maximum allowable.
They won't fail, but even with
double bridging, they will be bouncy,
and they will sag.
I don't like to go over 14'
with YP 2X10.
Just my take.
neolitic is offline
Old 05-09-2009, 09:35 AM   #7
Joe Carola's Avatar
Trade: Framing Contractor
Rewards Points: 1,012
Re: 2x10 Joists
2x10 Doug fir can span 16' no problem with bouncing or sagging. That's all we use around here. As mentioned different species might not span 16'.
Joe Carola
Joe Carola is offline
I Joists roofing/blocking? ApgarNJ Framing 22 01-02-2009 11:13 PM
Blocking I joists Morning Wood General Discussion 8 12-10-2008 07:08 PM
Replacing joists in rowhouse Philly Dude Framing 3 10-16-2008 05:24 PM
Dealing with Floor Joists dcapone Low Voltage 0 08-18-2008 01:45 AM
Framing Roof Joists for Addition when top Plate is not Level personalt Framing 3 07-20-2007 05:52 AM
