What Is The Best Way Of Attaching Slides To Cabinet Back Panel - Finish Carpentry - Contractor Talk
Old 05-30-2020, 05:48 AM   #1
tonyc56's Avatar
Trade: Window Treatments
Rewards Points: 3,884
In the following below video slide rear brackets are used to attach slides to the cabinet back panel. Would you recommend adding a cleat to the bottom of those rear brackets for additional support. Since the back panel is usually made up of thin material.
tonyc56 is offline
Old 05-30-2020, 05:52 AM   #2
Big Johnson's Avatar
Trade: Contractor Grunt
Rewards Points: 4,832
Re: What Is The Best Way Of Attaching Slides To Cabinet Back Panel
I wouldn’t recommend those slides or that install.
Big Johnson is online now
TheConstruct (05-30-2020)
Old 05-30-2020, 06:04 AM   #3
Focusing on solutions.
pinwheel's Avatar
Rewards Points: 504
What's wrong with the slides?
I've personally quit using back brackets because I don't like the flex that comes with using them.
pinwheel is online now
The Following 2 Users Say Thank You to pinwheel For This Useful Post:
rrk (05-30-2020), Texas Wax (05-30-2020)
Old 05-30-2020, 06:11 AM   #4
You’re right, I meant those back brackets.
Old 05-30-2020, 06:36 AM   #5
rrk's Avatar
Rewards Points: 5,414
Many times if I have to retrofit slides I will add 1/4 or 1/2" ply to the back just to stiffen it up. With those sidemount full extension slides I use the heavy duty brackets like the ones KV makes with a nut and bolt
rrk is online now
Old 05-30-2020, 06:37 AM   #6
tonyc56's Avatar
[QUOTE]
I've personally quit using back brackets because I don't like the flex that comes with using them./QUOTE]
Why would flex be issue. And how would youve installed those slides
differently.
tonyc56 is offline
Old 05-30-2020, 06:48 AM   #7
tjbnwi's Avatar
Rewards Points: 4,750
We use 1/2" backs on our cabinets. Except for the Blum HD under mounts or where a side aligns, they get the Blum rear bracket.
Blum does not make a rear bracket for the HD’s.
Never noticed any flex using the rear brackets.
tjbnwi is online now
Old 05-30-2020, 07:43 AM   #8
[quote=tonyc56;7781433]
differently.
There are other types of slides with back brackets that spread the load out better.
Old 05-30-2020, 07:56 AM   #9
This is the kind I like. The video doesn’t show it but the brackets have 2 ~1/4” tabs that fit into the cabinet backs so the screws aren’t really needed to support the load of the drawers.
Like these.
https://www.build.com/blum-295-6410/...6&displaypla=1
tonyc56 (05-30-2020)
Old 05-30-2020, 10:11 AM   #10
pinwheel's Avatar
Rewards Points: 504
Fully extended, pushing sideways on drawers you haven't had them flex more? I have, to the point of bending or popping out of the brackets. Caused more than one call back, which is why I quit using them. I'll block the side of the cabinet even with the face frame. Usually, I actually make 4 uprights that go all the way to the cabinet floor & drill them with line boring machine & use euro screws to hold them to the uprights. Then attatch the uprights to the cabinet side. The line bored holes make it quick & easy to install adjustable height pullouts.
I don't know if that made sense, I'll try to remember to take a picture of the uprights I make for this purpose when I go down to the shop.
Old 05-30-2020, 10:15 AM   #11
pinwheel's Avatar
Rewards Points: 504
Tab holes are actually 5mm.
Old 05-30-2020, 11:00 AM   #12
rrk's Avatar
the snap in brackets to come apart but the ones with a small nut and pan head bolt never come apart
rrk is online now
pinwheel (05-30-2020)
Old 05-30-2020, 11:44 AM   #13
tonyc56's Avatar
Who makes the small nut and pan head bolt brackets
tonyc56 is offline
Old 05-30-2020, 12:35 PM   #14
rrk's Avatar
I think KV (Knape Vogt )does
rrk is online now
Old 05-30-2020, 01:04 PM   #15
tjbnwi's Avatar
Which slide are you using. You’d have to snap the cabinet in half to get a Blum under mount to pop out of the rear bracket.
We use the steel rear brackets.
Old 05-30-2020, 01:07 PM   #16
rrk's Avatar
He’s using side mount full extensions from the picture
rrk is online now
Old 05-30-2020, 01:07 PM   #17
pinwheel's Avatar
Rewards Points: 504
Side mount bearing slides, KV. In the past it was cheap imports.
I don't even use the rear brackets on blum tandems anymore. Just feel I get a better build with the system I described above.
Old 06-07-2020, 03:48 AM   #18
Dirtywhiteboy's Avatar
Rewards Points: 5,164
I love reading theses threads,
Dirtywhiteboy is offline
Old 06-07-2020, 06:53 AM   #19
tab holes are actually 5mm.
~1/4”
Old 06-07-2020, 07:27 AM   #20
pinwheel's Avatar
Rewards Points: 504
~1/4”
Industry standards have gone to 5mm. Multi hole boring machines are set up in metric. Line boring machines are setup to 32mm on center. All the hardware I buy, is setup to accommodate these machines.
