What Angle For Splicing Long Runs? - Finish Carpentry - Contractor Talk
Old 05-03-2009, 06:44 PM   #1
Master Baiter
FowlOne's Avatar
Trade: Commercial/Residential Subcontractor
Rewards Points: 75
Just a general question, do most of you guys use 45 degrees for your scarf(think that's the proper term) joints in long runs in your trim work, lately i've been reducing my angle to around 30 - 35 degrees seems a little easier to keep the splice from opening up. Your thoughts?
Government exists to protect us from each other. Where government has gone beyond its limits is in deciding to protect us from ourselves. - Ronald Reagan
FowlOne is offline
Old 05-03-2009, 06:48 PM   #2
KemoSabe
loneframer's Avatar
Rewards Points: 12,218
Re: What Angle For Splicing Long Runs?
It depends on the rest of the job. If there are mostly 45s, I'll go with that. If there are more 22.5s, that is my choice. It just eliminates alot of bevel changes on the saw.
loneframer is offline
Old 05-03-2009, 06:52 PM   #3
genecarp's Avatar
Rewards Points: 2,000
Depends on the specific material and application, as a rule however a 45DEG feathers nicely and lets you sand to an invisible edge, as you decrease the angle, more meat exists at the joint line. G
genecarp is offline
Old 05-03-2009, 07:00 PM   #4
katoman's Avatar
Trade: carpenter
I try to locate the spice joint over a stud to get good nailing, and always glue the joint.
katoman is offline
Old 05-03-2009, 07:01 PM   #5
Artisan Carpentry
basswood's Avatar
Trade: trim carpenter
Rewards Points: 1,030
I use a 45* scarf. My reasoning is that it provides a larger area for the glue bond and the larger the degree of the scarf the less end-grain is involved in the glue-up. Done well, a 45* scarf is better able to blend the two pieces together and fool the eye.
That said, the smaller the degree of the scarf, the less an error in cutting effects the straightness of the run (get a 45* scarf off by a little, and it can dogleg).
Some even prefer to butt cut and biscuit long runs (or use a plywood backer).
basswood is offline
Old 05-03-2009, 07:11 PM   #6
I use 45º for trim, but usually
30º for decking.
The squarer cut ends seem to
resist splintering better there.
JMHO
neolitic is offline
Old 05-03-2009, 07:22 PM   #7
Certified Remodeler
silvertree's Avatar
Trade: Kitchen bath remodeler
I use 22.5, 30 and 45 degree. No rhyme or reason, if the saw is set at 45 then I'll leave it and do 45's. I don't generally look to nail on a stud, but will start with another piece that's longer or shorter if there is a bow in the wall by the scarf joint.
silvertree is offline
Old 05-03-2009, 07:33 PM   #8
Tom Struble's Avatar
Trade: siding
Rewards Points: 20
i think i do a bicuted butt joint better so that's what i do,i can cut it tite so it kind of snaps in,working alone a scarf is a little beyond my skills to get consistently good results
Tom Struble is offline
Morning Wood (08-27-2015)
Old 05-03-2009, 07:39 PM   #9
Mark
mhillc's Avatar
Trade: carpenter
Rewards Points: 150
On all my crown molding i straight cut the two ends and but them together with a block of wood behind them and glue and nail them they will never open up and very little sanding. I don't like to 45 them because if there off alittle its to much sanding and feathering in .(paint grade) just the way i do it.
" DO IT RIGHT THE FIRST TIME "
mhillc is offline
Old 05-03-2009, 07:54 PM   #10
Quiglag's Avatar
Trade: Finish Carpentry
Rewards Points: 150
I like to use the bevel stop that is around 30 degrees, but because everyone else on the job uses 45 degrees, I have to do the same.
Quiglag is offline
Old 05-03-2009, 07:58 PM   #11
solar guy
naptown CR's Avatar
Trade: solar contracting
Rewards Points: 1,000
I will use a 45 to join. however if it is crown i hold the back of the crown up against the fence as it makes the jiont smaller and less conspicuous. A true scarf joint that is intended to lengthen a board as in boat building is always done at a 10 or 12 to one angle. This means if the boards that you are joining are 1" thick (Not nominal but actual thickness) then the length of the joint is 10" or 12" long.
naptown CR is offline
Old 05-03-2009, 09:11 PM   #12
I like Green things
WarnerConstInc.'s Avatar
Rewards Points: 5,620
I usually butt, but somtimes scarf. My scarf angles are as random as my thougths. I will say I see and fix more 45's tan anything else. I really think butts are best. Hold your thoughts 'gentlemen'.
WarnerConstInc. is online now
Old 05-03-2009, 09:13 PM   #13
john5mt's Avatar
Rewards Points: 1,496
22.5's and then pressure fit them 45's usually the top one slides off a little
Remodelling Fool
Helena Siding Windows
https://helenasiding.com/
john5mt is offline
Old 05-03-2009, 09:27 PM   #14
Originally Posted by WarnerConstInc. View Post
I usually butt, but somtimes scarf. My scarf angles are as random as my thougths. I will say I see and fix more 45's than anything else. I really think butts are best. Hold your thoughts 'gentlemen'.
Finesse boys, finesse.
It's all in the wrist.
neolitic is offline
Old 05-03-2009, 10:20 PM   #15
Remodeler Extraordinare
A.W.Davis's Avatar
Rewards Points: 510
We do a 50 degree bevel on our crown splices, and 45 degree splice on baseboard and all other trim.
We found that 50 degrees works very very well on the crown splices. A good practice is to nail on a backer block on the backside of the crown moulding.
A.W. Davis Construction Co.
http://www.awdavisremodel.com/
Your friendly remodeling contractor
A.W.Davis is offline
Old 05-03-2009, 10:49 PM   #16
President of the world
world llc's Avatar
Trade: general contractor
Rewards Points: 2,001
45 always
world llc is offline
Old 05-04-2009, 12:00 AM   #17
Finish Carpenter
TBFGhost's Avatar
Trade: Finish Carpentry, Reno
Rewards Points: 2,760
Large Crown gets a butt with two biscuts and a 1/4" MDF backer...used to do 45 and 22.5 everywhere but once I tried it this way I was hooked. Smaller stuff gets 22.5.
TBFGhost is offline
Old 05-04-2009, 12:55 AM   #18
Trimguy
CVGFir's Avatar
Rewards Points: 25
Whatever indent I feel like hitting on my miter saw at the time.
CVGFir is offline
Old 05-04-2009, 07:31 AM   #19
Carpenter
RizzoMaryland's Avatar
I like to take my time with my joints. Sit back, dim the lights, and enjoy.
No need to rush and scarf them down regardless of the temperature degree.
"An idea is salvation by imagination"
Frank LLoyd Wright
RizzoMaryland is offline
The Following 2 Users Say Thank You to RizzoMaryland For This Useful Post:
BuiltByMAC (06-10-2009), genecarp (05-04-2009)
Old 05-04-2009, 08:20 AM   #20
Certified Remodeler
silvertree's Avatar
I want to add, I like using backer pieces regardless of how I cut.
Roofer vs. Roofer (Just a long winded hypothetical) Thunder1 Roofing 13 12-20-2014 07:17 AM
It's a long way to the top loneframer Windows, Siding and Doors 8 02-21-2009 06:19 PM
Long time listener, first time caller BakersDozen New Member Introductions 15 02-17-2009 09:56 PM
How long do you expect to live? davitk General Discussion 70 02-13-2009 06:53 PM
Looking for a piling Co. on Long Island NY ASAP NYBuilder Help Wanted or Looking For Work 0 02-12-2009 10:43 AM
