Walls Paneling With 1/4 Or 1/2" Plywood. - Finish Carpentry - Contractor Talk
Old 05-12-2016, 03:42 PM   #1
tipitop's Avatar
Trade: carpenter
Rewards Points: 3,741
Customer want me cover like 20 of walls with mahogany plywood instead of sheetrock to mach existing part of trim. It is minimalist style so I can not use L corners. I have to but 6 corners (plywood but in 3/4 by 4 mahogany) and meet 2 corners with 45 degree ripped plywood. Customer broth 1/4 plywood. I did a 2 wall with it but said to customer that I would do much better job if I would have 1/2 plywood and be capable nail 1 X directly to plywood at but end, and would be better for meet end to. I remember from my employment days we used 1/2 ply for wainscoting. Am I right?
Old walls are done with 1/4 but I said customer that they go 1/4 to save a few bucks.
tipitop is offline
Old 05-12-2016, 05:37 PM   #2
hdavis's Avatar
Rewards Points: 1,660
Re: Walls Paneling With 1/4 Or 1/2" Plywood.
If it's direct to the studs, then 1/2". 1/4" flexes too much.
hdavis is online now
Old 05-12-2016, 06:37 PM   #3
tipitop's Avatar
Trade: carpenter
Yes direct to studs. Now when think must be that old 1/4 ply was laid over 1/2 construction grade plywood.
Talked with customer before a few minutes. He said he can not return his 4X8. He is good guy. But when he ordered panels he never asked me. I did framing in October and forger about project. He evidently ordered that panels that cost 70$ each. My local lumber yard selling 5/8 mahogany panels for 30$ each. Now there are many kind of mahogany per word of lumber yard worker.
tipitop is offline
Old 05-12-2016, 06:43 PM   #4
slowsol's Avatar
Rewards Points: 2,248
Most of the paneling that was installed here was 1/4" with gyp board behind it.
-John
slowsol is offline
The Following User Says Thank You to slowsol For This Useful Post:
hdavis (05-12-2016)
Old 05-12-2016, 07:42 PM   #5
tipitop's Avatar
Trade: carpenter
I guess it is because gypsum board are perfectly straight. It make sense. Then when you have flat panels you can much easier dill with that 1/4.
tipitop is offline
Old 05-12-2016, 08:52 PM   #6
hdavis's Avatar
That's how most of it is here, too. I've also seen 1/4" direct to studs, 3/8" direct to studs, 1/2" direct to studs, and 3/4" direct to studs. 1/4" direct doesn't work out well at all. The old 3/8" wasn't too bad.
Old 05-18-2016, 09:24 PM   #7
tipitop's Avatar
Trade: carpenter
I figured out I can set 1X1 nailer 3/16 from edge of 1X4 mahogany. It will work.
tipitop is offline
Old 05-18-2016, 11:17 PM   #8
VinylHanger's Avatar
Rewards Points: 9,918
Luckily around here, most plywood paneling is set over 1x T&G. The perks of living in what was once the lumber capital of the world. I used 1/4 over one of our walls. I had them and they worked great. Of course it was over t&G AND gyp.
I would love to see some pics of the miters if you have them.
VinylHanger is offline
Old 05-18-2016, 11:49 PM   #9
tipitop's Avatar
Trade: carpenter
I will do it soon, will post photos of miters. Will use carbord or paper to shim up miter.
tipitop is offline
Old 05-19-2016, 01:54 AM   #10
m1911's Avatar
Trade: finish carpenter
Rewards Points: 15,632
Depends of where it's used, sometimes sheetrock is required for fire rating, not open partition walls of course.
Originally Posted by tipitop View Post
That guy in video have mental issues plus eat hole turtle from some reason
m1911 is offline
Tile on plywood wall paneling onmywayup General Discussion 5 04-04-2014 06:07 PM
FRP shower walls woodbutchr Remodeling 11 03-27-2013 06:09 PM
Insulating Walls - what if ???? power Insulation 6 03-08-2013 10:12 AM
Proper way to insulate block walls gnxtc2 Insulation 3 01-09-2011 10:23 PM
Sagging floors, over spanned joists, load bearing walls without support and more technique Remodeling 104 05-14-2010 04:16 AM
