Using Pvc Trim Boards - Finish Carpentry - Contractor Talk
Old 01-03-2011, 07:43 PM   #1
Icarus's Avatar
Trade: Handyman
Hey everybody. I thought I'd ask you trim pros your opinion on using pvc boards on an exterior project. I'm doing a full window install on an old brick home, and the homeowners have requested I use pvc trim (for the low-maintenance benfits). I'm casing the windows with 1 x 4 pvc boards, using butt joints, and dap (latex with silicone) caulk.
Any opinions on what size expansion/contraction gap is appropriate? I hate to sacrifice appearance for functionality, but am afraid the boards will buckle when it warms up in the summer. Has anybody had any success with this stuff? Thanks in advance. Ya'll have a lovely day
Icarus is offline
Old 01-03-2011, 07:46 PM   #2
Tom Struble's Avatar
Trade: siding
Rewards Points: 20
Re: Using Pvc Trim Boards
i like to pre fab window trim using pocket screws and pvc cement,give them an 1/8'' clearance all around
Tom Struble is offline
loneframer (01-03-2011)
Old 01-03-2011, 07:53 PM   #3
KemoSabe
loneframer's Avatar
Rewards Points: 12,218
I've done a little PVC.
You should definitely keep a minimum of 1/8" around the perimeter of the window, moreso if working with the material in warm weather, but a gap is advisable, always.
PVC will move substantially with temperature swing, especially in direct sunlight.
All joints should be glued, although long runs are prone to failure over time, especially if painted a darker color than white.
loneframer is offline
The Following User Says Thank You to loneframer For This Useful Post:
Tom Struble (01-03-2011)
Old 01-03-2011, 09:05 PM   #4
topsail's trimcat
woodworkbykirk's Avatar
Rewards Points: 384
riz by a little pvc work do you mean 5 pallets worth of azec
we use it on every house for cladding the decks mostly especially on teh front. on odd situations with door and window build outs we use it there as well
woodworkbykirk is offline
Old 01-03-2011, 09:09 PM   #5
KemoSabe
loneframer's Avatar
10 pallets would probably be more accurate, but I haven't been counting.
Old 01-03-2011, 09:15 PM   #6
Mark Siders's Avatar
Trade: Interior Trim/Stair builder
Rewards Points: 75
Anyone ever heat azek up for bending? I did a whole bunch of crown in some circular tray ceilings with it. Worked great.
Mark Siders is offline
Old 01-03-2011, 09:22 PM   #7
Uber-Member
jeffaah's Avatar
Trade: Carpenter...Deck Guy
Rewards Points: 250
Like others said....Glue joints tight and leave a gap agaist the window. Prefabing the trim is a great way to go and pocket screws work great for that process. Sometimes I use my Senco Senclamp for fast pre-fab. For PVC glue I LOVE Bond&Fill Structural slow cure or TrimBonder. Both make a structural bond and are white, sandable/scrapable, gapfilling, easy cleanup, etc. I also use the Azek glue with good results but I hate the dauber application.
I use Fastenmaster Cortex on any job that will not get painted. Painted jobs get SS nails and a few Cortex.
You mentioned Dap caulking... DON'T use the regular Alex's $2 a tube crap. It is not elastic enough. At least use the Dap Dynaflex or equivalent if you prefer water cleanup. I really like to use Duo-Sil sealant on all PVC work. There are alot of decent sealant options. Unfortunatly there are more choices that are NOT appropriate for PVC but people use them anyway.
jeffaah is offline
The Following User Says Thank You to jeffaah For This Useful Post:
Tom Struble (01-04-2011)
Old 01-03-2011, 09:28 PM   #8
KemoSabe
loneframer's Avatar
Only time I heated it was to make a 12" radius on the flat with 5/4x6. Worked great, but heat blankets would have been the bomb.
Most cases, I'll use a router and trammel and cut out of sheet goods.
using pvc trim boards-041-1.jpg   using pvc trim boards-004-1.jpg   using pvc trim boards-001-16.jpg   using pvc trim boards-008.jpg   using pvc trim boards-040.jpg
Old 01-03-2011, 10:07 PM   #9
Rewards Points: 75
What did you use to heat it up.
Old 01-03-2011, 11:06 PM   #10
Finish Carpenter
TBFGhost's Avatar
Trade: Finish Carpentry, Reno
Rewards Points: 2,760
How tight of a radius did you get from it? I need to crown a bathroom with some 3 5/8" col crown that has 12" radius corners...was thinking about using Azek.
TBFGhost is offline
Old 01-03-2011, 11:16 PM   #11
TRADE CRAFTSMAN.
SAW.co's Avatar
Trade: general contractor
I've only used PVC trim once. I installed a dental work under eves of a new home built in a 1850 farm house style I thought it was a little hard to work with but man did it look cool & a whole lot faster than fabricating my own.
SAW.co is offline
The Following User Says Thank You to SAW.co For This Useful Post:
Andy_Gauvin (06-02-2017)
Old 01-03-2011, 11:19 PM   #12
Working
Cole82's Avatar
Rewards Points: 2,276
On the note of failing glue joints on long runs. They are jagged edge, not a smooth break. SO on long runs I don't glue one joint.
Cole
The boss of awesome
Cole82 is offline
The Following User Says Thank You to Cole82 For This Useful Post:
Old 01-04-2011, 12:52 AM   #13
Rewards Points: 75
The tightest radius I did was about 5ft. 12" might be pushing it but I think it would work. I used 5 1/2" crown so 3 5/8 should be even better. What I did is used cone geometry witch takes in to account the angle of the crown from the wall and the radius of the wall and gives you a radius to bend the crown when laying flat on the ground witch is much less of a radius than the wall it self. So then you make a jig to bend the crown to, witch would just be a piece of 3/4 mdf with the radius cut/routered out like you would if laminating a casing blank. Your radius might end up as much as 3 or 4ft. Heat up your casing and bend it to your jig laying flat on its back and let cool for about 10 min. and your good. Give it a shot I think it would work great.
Old 01-04-2011, 02:24 AM   #14
topsail's trimcat
Rewards Points: 384
our biggest azec project was on a 1.2 million dollar complete reno a couple years back, all new cedar pre finished cedar shingles and all exterior trim in azec, roughly $40,000 of azec alone i believe
Old 01-04-2011, 06:26 AM   #15
KemoSabe
loneframer's Avatar
I used a heat gun and wrapped it around a form. It was very slow and hard to get it heated uniformly. Without even heat it doesn't like to bend neatly and tries to "egg" out.
Old 01-04-2011, 11:07 AM   #16
topsail's trimcat
Rewards Points: 384
good to know riz, on that big one we simply tried slowly bending it by driving ss screws every foot or so. we had a couple pieces snap.there was a few turret windows and a large round room for which we had to put fascia up on as the radius was also on the outside
Old 01-04-2011, 02:30 PM   #17
Rewards Points: 75
I was heating up 18' lengths so I used 12" metal ductwork pipes about 20' long. Made a wood grill plank to lay the crown on and slide in and out of the duct. Then I used a large torpedo heater to blow through the duct from about 2' away so as not to start a fire (learned that the hard way) To heat it evenly I swapped the heat from one end to the other half way through the heating time. Worked really well.
The Following 2 Users Say Thank You to Mark Siders For This Useful Post:
jhark123 (01-07-2011), loneframer (01-04-2011)
Old 01-07-2011, 03:21 AM   #18
I eat sawdust.
Winchester's Avatar
Trade: Deck Design/Build
Rewards Points: 2,000
I used some vinyl trim and bent it around this with a little heat persuasion from a hairdryer
Winchester is offline
The Following User Says Thank You to Winchester For This Useful Post:
stp57 (01-07-2011)
Old 01-07-2011, 01:21 PM   #19
jhark123's Avatar
Trade: Pro Cat Herder
Rewards Points: 1,766
How do you like the senclamp? have you used a corragated (sp) fastener tool also? Which one works better?
jhark123 is offline
Old 01-07-2011, 02:54 PM   #20
Trade: siding
Rewards Points: 20
Di hipped me to these
http://www.raptornails.com/
Tags
expansion , pvc , using vinyl boards , window trim
Water table, drip cap, corner boards UpNorth Windows, Siding and Doors 4 10-16-2010 04:11 PM
Funny Craigslist ad for paint work... Splinter Painting & Finish Work 14 06-10-2009 05:43 AM
Preference in the Way your Decking Boards Turn jcalvin Decks & Fencing 25 03-12-2009 01:01 PM
Trim Painted, Sealed, Glazed, Sealed Bentz34 Painting & Finish Work 9 03-01-2009 11:17 PM
Paint/Glaze trim Bentz34 General Discussion 0 02-25-2009 10:27 PM
