Straight Line Ripping Jig ? - Finish Carpentry - Contractor Talk
Old 12-14-2009, 08:17 AM   #1
Steve
BACKWOODS's Avatar
Trade: Remodeling and Custom Cabinets
Rewards Points: 256
I was working with some 4/4 Cherry I bought a few years back. When I bought this I did not have my supplier Straight Line Rip one side for me.
I used double sided tape and a straight piece of cypress to make my own jig.
I had to use new tape on each board. Anyone have any other jigs to create a straight edge. My boards are 10' long in this example.
BACKWOODS is offline
Old 12-14-2009, 08:25 AM   #2
Focusing on solutions.
pinwheel's Avatar
Rewards Points: 590
Re: Straight Line Ripping Jig ?
Sure like my long bed jointer for the task at hand.
If that's not available, clamping the straight edge to your stock works well. Lot easier than double sided tape.
A few screws through your straightedge into the back of your stock works well too.
pinwheel is online now
Old 12-14-2009, 09:13 AM   #3
Cjeff's Avatar
Trade: Renovations
a strip of plywood .
Air brad nail it to the piece of wood overhanging it on the edge that will go against the saw fence. Keep the nails where they will be ripped off on your next tablesaw rip cut.
This gives a straight edge on one side of your wood to ride against your fence. When you rip it you have a straight cut. Then pull off the plywood and rip the other side straight and to width.
That is the quick easy method.
You could make a jig. A 'sled' to hold the board with built on clamps. The straight sled rides against the fence of the saw. The board is clamped to it.
Cjeff is offline
Old 12-14-2009, 09:14 AM   #4
Shawn Prentice's Avatar
Trade: carpenter/remodeler
Rewards Points: 250
http://www.woodweb.com/knowledge_bas...ipping_on.html
Shawn Prentice is offline
Old 12-14-2009, 09:25 AM   #5
Maker of fine kindling
Gus Dering's Avatar
Trade: cabinet maker
Rewards Points: 12,490
The fastest , and possibly easiest, way is to use a nice straight stick as long as the board being straightened as your guide. Crown the board away from the straight edge and set the fence to the sum total of the two less what ever is needed to get your edge.
Push both pieces through side by side paying close attention to how you are applying pressure to the two boards so they stay nice and snug to the fence all the way through.
Takes a couple passes worth of practice and you'll have it down pretty good. Low tech, but quick and effective.
Now if you had a slider with a ten foot stroke then....
Gus Dering is offline
Old 12-15-2009, 12:23 AM   #6
President of the world
world llc's Avatar
Trade: general contractor
Rewards Points: 2,001
you can do it like the old old timers...
use the festool!!
world llc is offline
Old 12-15-2009, 03:39 AM   #7
Cletus's Avatar
Trade: Tube Installer
Rewards Points: 150
I use a 20' piece of 2"x3" aluminum tube to make a long fence for the unisaw. With infeed/outfeed tables I can push a stack of boards through pretty quick with excellent results. I do have to be somewhat careful not to side load the fence because it will deflect if I bully it.
Cletus is offline
Old 12-15-2009, 06:19 PM   #8
john5mt's Avatar
Rewards Points: 1,500
Use a TS-55 makes it real easy
Remodelling Fool
Helena Siding Windows
https://helenasiding.com/
john5mt is offline
Old 12-15-2009, 06:34 PM   #9
I like Green things
WarnerConstInc.'s Avatar
Rewards Points: 5,860
That makes it too easy
Don't be giving away all our secrets, how will be able to set ourselve's apart from the regular crowd?
Warner Mill Works
Facebook
YouTube
WarnerConstInc. is offline
Old 12-15-2009, 07:32 PM   #10
jeffatsquan's Avatar
Trade: builder/renovator,Squam Lake NH
Rewards Points: 250
Straight line rip all the time with mill-run white pine 1x 12",14", 16",18".
What I do is take a good flat board usually from the stock I'm working with snap a line at say 3-1/2" then take
1/4 ply and attach it to the line taking the time to check it with my 6'
straight edge.Than take my worm drive and run it down the edge of the ply making the board straight than take this board and clamp it on top of each board that needs to be straightened you can run through a good size pile pretty quick with this method.At this point you have a pile of boards that are ready to be sized at the table saw
jeffatsquan is offline
Old 12-15-2009, 08:49 PM   #11
Gus Dering's Avatar
What kinda clamp?
Old 12-16-2009, 06:14 AM   #12
Rewards Points: 250
Originally Posted by Gus Dering View Post
What kinda clamp?
Deep throated Bessie's or vice grip C-clamps
Usually this stock is longer 16' or so we use 2 men one on each end take the straighting board set on top of board to be straightened line it up so you take any wane or other defect clamp, one guy runs the saw the other manges the cord and scarp, repeat...
Old 12-16-2009, 07:40 AM   #13
Working
Cole82's Avatar
Rewards Points: 2,276
I second this.
I use a 1"x4" aluminum tube that is 12' long cost $50 at the local metal yard. Straight as an arrow.
The boss of awesome
Cole82 is offline
Old 12-16-2009, 09:22 AM   #14
Motorboatin' son of a ...
BKFranks's Avatar
That's what a jointer is for.
BKFranks is offline
Old 12-16-2009, 10:20 AM   #15
mics_54's Avatar
Trade: contractor
yeah a jointer! then after 5 or 6 passes you can break for lunch and finish it when you get back!
make a straightline jig..it's not rocket surgery.
mics_54 is offline
Old 12-16-2009, 10:19 PM   #16
jhark123's Avatar
Trade: Pro Cat Herder
Rewards Points: 1,766
jhark123 is offline
Shingles Nailed Above Nail Line.. Help!! Unregistered Roofing 24 04-20-2011 08:14 PM
Adding Chalk line chalk to touch up mud AARC Drywall Drywall 20 04-12-2009 06:12 PM
septic line replacement cdub Excavation & Site Work 3 04-11-2009 11:35 AM
Thermador Freedom line Waffle Face General Discussion 0 09-09-2008 06:45 PM
