Solid Foam Walls - Finish Carpentry - Contractor Talk
Solid Foam Walls
Old 02-06-2019, 07:38 PM   #1
JFM constr's Avatar
Trade: remodel,finish&trim
Rewards Points: 2,362
Solid Foam Walls
hanging wine racks . using toggle bolts .though when i got to the exterior wall the toggle bolts were not opening in the solid foam wall . time to leave anyhow but i need a plan for when i return . does anyone have a good way to handle this .
JFM constr is offline
Old 02-06-2019, 07:58 PM   #2
diplomat
Golden view's Avatar
Rewards Points: 1,550
Re: Solid Foam Walls
If it's SIPS then you can probably just screw into the OSB.
Foam right behind drywall? Seems like you should be able to dig out the foam manually through your ~1/2" hole. Might be a pain but should be doable.
Golden view is offline
Old 02-06-2019, 08:49 PM   #3
dsconstructs's Avatar
Trade: Remodel Contractor
Rewards Points: 872
Allen wrench in your drill. Slip it into the hole diagonally, they straighten the drill back up and spin the allen wrench to create enough of a void for the toggle to open up behind the sheetrock. disclaimer: I've never done it but I'd definitely try it if I ran into that.
dsconstructs is offline
The Following 4 Users Say Thank You to dsconstructs For This Useful Post:
AustinDB (02-19-2019), Golden view (02-06-2019), onmywayup (02-06-2019), Xtrememtnbiker (02-08-2019)
Old 02-06-2019, 08:53 PM   #4
90%-er
onmywayup's Avatar
Rewards Points: 2,436
That's what I had in mind. Easy way to clean out they area just enough for a toggle to pop open
onmywayup is online now
Old 02-06-2019, 08:59 PM   #5
Idothat's Avatar
Trade: Home improvement of all types
Rewards Points: 1,042
Use the expansion type anchors instead of toggles, the ones that collapse.
Idothat is offline
Old 02-08-2019, 11:33 AM   #6
JFM constr's Avatar
the allen wrench idea was great .also those other fasteners would be fine if i had not already drilled for toggles . going back today with a clear head to finish up .
it is a wine room , imagine small sealed closet .client had a lot going on in the house so i kept the dr closed mostly .realized to late that the lack of air was messing me up . dr will be open today for sure .
thankyou for the help
The Following User Says Thank You to JFM constr For This Useful Post:
dsconstructs (02-08-2019)
Old 02-19-2019, 09:56 AM   #7
AustinDB's Avatar
Rewards Points: 1,538
If itís a metal toggle, heat it up with a torch just before inserting.
Never tried it but sounds like something I would do lol
AustinDB is offline
Old 02-19-2019, 10:57 AM   #8
JFM constr's Avatar
but imagine the stink.
turned out to be way way easier .i shoved a screwdriver with the end bent 90 degrees into the hole and removed a little foam .a piece of wire would work .
Paint or Solid color stain? kenmorgen Painting & Finish Work 8 04-27-2013 12:03 AM
2x4 Basement Stud Walls On a Three Story Home WITH NO FOOTER Baltimore Carpentry 13 08-16-2012 07:02 PM
What is the max distance for load baring walls in a residence? kgcaddesign Architecture & Design 13 06-03-2012 02:35 PM
here's a painting price list...... Jer44 General Discussion 9 02-17-2009 08:30 AM
