Stickley has a new table model out, introduced in fall of 2012, and the dining table, 40 x 78 when closed, slides open at center to be fitted with its two 18" extension leaves. The Highlands Trestle Table.
The mechanism is a set of ball bearing slides and cables, to work such that pulling one side out makes the other side slide away equally. Smooth as silk. The setup requires a little height, and there is a pocket with floor between the aprons and mechanism, for storage of the extensions.
Anybody know where the slide mechanism can be purchased?
