Scarf Joint On Long Crown Molding - Finish Carpentry - Contractor Talk
Old 04-29-2019, 07:00 PM   #1
nickko's Avatar
Trade: remodeling-cabinet maker
Rewards Points: 789
I have a crown molding job i need to start tomorrow on short notice. It is 4 1/2 inch oak that i am going to clear coat with polyurethane. I have two runs of 26 feet. I am thinking of doing the scarf joint in my shop and sanding it out then finish with poly. Has anyone ever done a scarf joint of this length and then hauled it to the job? i figure i could put a 40 foot ladder on my racks and tie it down. I could defiantly get a nicer joint in my shop than on the job. I work alone but would probably have to have help getting into the job and held in place.
thanks......nicko
"Quality work for those who know the difference"
nickko is offline
Old 04-29-2019, 07:16 PM   #2
MarkJames's Avatar
Trade: Handyman Services
Rewards Points: 15,677
Re: Scarf Joint On Long Crown Molding
Are you actually saying that you would connect, haul, and install one piece?
Is there an OCD hotline?
MarkJames is online now
Old 04-29-2019, 07:34 PM   #3
Mordekyle's Avatar
Rewards Points: 5,140
Will it fit in the door and around the corner?
Mordekyle is offline
Old 04-29-2019, 07:40 PM   #4
Box Builder
Morning Wood's Avatar
Rewards Points: 9,978
If it will fit Iíd do it. It will look so much better that way.
Morning Wood is online now
The Following User Says Thank You to Morning Wood For This Useful Post:
Calidecks (04-29-2019)
Old 04-29-2019, 07:56 PM   #5
nickko's Avatar
Rewards Points: 789
Thats funny! Yes i am little OCD.
I am going to go to the house in the morning and see if i can get it into the house and in the room i need it to be in. I think i can but i am going to check it out. It will be a nicer joint and ill save a lot of time on the job trying to get a nice joint.
thanks...nicko
nickko is offline
The Following User Says Thank You to nickko For This Useful Post:
MarkJames (04-29-2019)
Old 04-29-2019, 08:24 PM   #6
rrk's Avatar
Rewards Points: 2,544
I have done it already, I used a pc of 5/4x3 Saran wrapped to the crown and cut it off after it was lifted onto supports just below its position
rrk is online now
hdavis (04-29-2019)
Old 04-29-2019, 08:50 PM   #7
hdavis's Avatar
Rewards Points: 334
If you don't want to ding it up or possibly crack it, you'll do it like tri. The only difference I do is using moving wrap instead of saran wrap.
Personally I'd prep the two pieces as a butt joint and assemble on site. I mostly use scarf joints in boatbuilding joining plywood, but it's more like a 1 in 12 angle.
hdavis is offline
Old 04-29-2019, 11:47 PM   #8
GC/carpenter
Calidecks's Avatar
Rewards Points: 702
thanks...nicko
Mike.
_______________
Calidecks is offline
The Following 2 Users Say Thank You to Calidecks For This Useful Post:
hdavis (04-30-2019), MarkJames (04-30-2019)
Old 04-30-2019, 03:09 PM   #9
nickko's Avatar
Rewards Points: 789
I scarfed an 18' piece and it went together well. I glued a strip of 1/4" plywood to the back and stapled it with 3/4" narrow crow staples and then sanded it. It looked good but its hard to move around without the joint opening. As long as its laying flat it looks good. I didn't put a biscuit in it but i don't think it would have helped much. So i am going to just scarf the 26 footers on the wall. Its a dimly lit bedroom so that should help
nicko
nickko is offline
hdavis (04-30-2019)
Old 04-30-2019, 06:24 PM   #10
Box Builder
If itís thick enough you could pocket screw it using a butt joint. With a scarf joint there would be no way to biscuit it really
Old 04-30-2019, 07:03 PM   #11
MarkJames's Avatar
Depending on light, etc. I might break it up using two scarf joints, each far from the center.
SmallTownGuy (05-01-2019)
Old 04-30-2019, 10:08 PM   #12
Mordekyle's Avatar
nicko
I prefer to change out the light bulbs for dimmer on my finish work.
The Following User Says Thank You to Mordekyle For This Useful Post:
TheConstruct (04-30-2019)
Old 04-30-2019, 11:36 PM   #13
LRG WoodCrafting
Leo G's Avatar
Trade: Maker of Fine Sawdust
Rewards Points: 21,213
I don't do scarf joints for something like that. A butt joint and a biscuit work better as long as it will fit. At 26 feet I'd glue and screw or staple a pc of 1/4" to the backside to help it with stiffness at the joint.
Now if you could do a true scarf joint that is 8-10" long then you'd have more than enough surface area for glue to not worry about it.
Sawdust Follows Me Everywhere
WWG1WGA
Carpenter by day.
Mad scientist by night.
http://lrgwood.com
Leo G is offline
hdavis (05-01-2019)
Old 05-09-2019, 11:19 AM   #14
hoser's Avatar
Trade: General, Finish Carpentry, Cabinet Builder
Rewards Points: 122
I would do the scarf joint on site. Take your time, fit it properly and it will turn out well. Plus a lot less effort, frustration, worry, time, and no need to pay someone to help you.
hoser is offline
Old 05-09-2019, 11:22 AM   #15
LRG WoodCrafting
Leo G's Avatar
Not in prefinished.
WWG1WGA
Carpenter by day.
http://lrgwood.com
Leo G is offline
Old 05-09-2019, 11:24 AM   #16
hoser's Avatar
Rewards Points: 122
Why not? I’ve never had a problem with it. Sometimes it’s difficult, but definitely possible, especially if it’s stain-grade.
hoser is offline
Old 05-09-2019, 11:29 AM   #17
John the Builder
SmallTownGuy's Avatar
Rewards Points: 5,332
thanks......nicko
How did it turn out? Pictures?
SmallTownGuy is online now
Old 05-09-2019, 11:29 AM   #18
LRG WoodCrafting
Leo G's Avatar
When you walk away it might look beautiful. When the seasons change it's going to open up. If you make the pc in the shop and clamp it up so it becomes one, then it won't move.
You will get better results from stain grade than prefinished pigmented. And when the stain grade moves you can colorize it with markers or crayons to make it disappear. It's harder to do that with a pigmented cabinet finish, and I avoid it at all costs.
Can you do it and make it look OK, yep. Will it last, likely not, but possible if it's really put together well. Stain can be hidden after the fact and it's much tougher to hide pigmented after the fact.
If it's a brush on paint then go for it, easily hidden later on.
WWG1WGA
Carpenter by day.
http://lrgwood.com
Leo G is offline
greg24k (05-09-2019)
Scarf joint or butt joint Chicofish Finish Carpentry 30 12-13-2017 08:47 AM
help with crown molding bid carpenter123 Finish Carpentry 27 12-15-2014 06:32 PM
calculating crown spring angle Mrmac204 Finish Carpentry 12 12-26-2012 08:08 AM
Festool 494369 crown stops for kapex BCConstruction Contractor Swap 4 10-02-2012 09:37 AM
joint cracked twice in a week r4r&r Drywall 9 06-29-2012 09:08 PM
