'Must Have' Tools For Finish Carpentry? - Page 4 - Finish Carpentry - Contractor Talk
Old 11-10-2014, 07:51 PM   #61
J.C.'s Avatar
Rewards Points: 178
Re: 'Must Have' Tools For Finish Carpentry?
6" Steel Rule
I do not prize the word "cheap." It is not a badge of honor...it is a symbol of despair. Cheap prices make for cheap goods; cheap goods make for cheap men; and cheap men make for a cheap country. ~ William McKinley
J.C. is offline
Old 11-10-2014, 11:14 PM   #62
StrongTower's Avatar
Trade: Finish Carpenter
Rewards Points: 1,260
In addition to a lot of things mentioned already, I'm a fan of a 4" combo square, cordless circular saw, cordless jig, power planer, biscuit jointer, and a 5 in one (or as I call it 1000 in one).
I value the most is a great miter saw stand with a stop system and continous support.
StrongTower is offline
The Following 3 Users Say Thank You to StrongTower For This Useful Post:
Spencer (11-11-2014), tenon0774 (11-11-2014), Tom Struble (11-11-2014)
Old 11-10-2014, 11:49 PM   #63
needs glasses's Avatar
Trade: Renovator
Rewards Points: 300
Originally Posted by Xtrememtnbiker View Post
I have the fast cap scribe and never had anything else so I can't say for sure how it compares. It works, it's a little awkward I guess but I don't take the pencil out that much.
RAS for coping or scribing anything. Just got it, much nicer than an angle grinder with sandpaper. The RAS isn't dustless but it's much better.
Tracksaw is for back cutting for a scribe to remove as much as you can. Or anything else you want to use it for. Lol. We do everything pretty much so I don't know what the typical finish carpenter is doing. I use it for building cabinets, cutting flooring, trim, whatever I need to use it on.
Quality with the RAS, first time I've seen it.
https://www.youtube.com/watch?v=pPT4zaLpSHw
needs glasses is offline
The Following User Says Thank You to needs glasses For This Useful Post:
CarpenterSFO (11-11-2014)
Old 11-11-2014, 02:33 AM   #64
mgb's Avatar
Trade: Finishing Carpenter
Rewards Points: 1,116
I agree with strongtower,
Adding continuous support to my miter stand, and extra length has made so much difference in productivity. Measurements are faster/more accurate, cut's go faster when I'm not worrying about dropping the offcut. Plus it can give you a work surface for jigsawing/routing/sanding/scribing/joining. I've used my extensions as a router table and even a makeshift jointer at one point.
Getting a good miter saw setup is without a doubt the most important thing IMO. Having dust collection is a great addition keeping bevel/miter gauges clear to read.
I went many years without a multimaster/tracksaw/23 gauge. As great as they are you can make do without them.
mgb is offline
The Following User Says Thank You to mgb For This Useful Post:
StrongTower (11-11-2014)
Old 11-11-2014, 03:30 AM   #65
stacker of sticks
jlsconstruction's Avatar
Rewards Points: 590
Am I hack cause all I have is a 6' Blue Empire for setting doors? Don't worry, the Stabila is on the tool purchase list. I'm going in baby steps though (or not so baby...)
That's all I use.
But I never understood buying a level that costs 3x as much that's accuracy is the same. I've actually used 3 stabilas that were off. 3 different peoples.
jlsconstruction is offline
The Following User Says Thank You to jlsconstruction For This Useful Post:
SmallTownGuy (11-11-2014)
Old 11-11-2014, 03:50 AM   #66
jb4211's Avatar
Rewards Points: 2,306
Originally Posted by jlsconstruction View Post
That's all I use.
I don't think it matters what you use. As long as the door is plumb and operates properly you could use anything that works.
High priced or high quality tools do not make up for lack of skill.
Jon
jb4211 is offline
The Following 2 Users Say Thank You to jb4211 For This Useful Post:
jlsconstruction (11-11-2014), SmallTownGuy (11-11-2014)
Old 11-11-2014, 07:26 AM   #67
Livin the dream...
Spencer's Avatar
Trade: Finish Carpentry
Rewards Points: 5,514
That's all I use.
Its the name. I have never used a stabila that was off. When I buy a level there is to much at stake to go cheap. Stabila has had a great name for a long time. That is why they are the only level I buy. They have never let me down. If they are taken care of I believe they are a lifetime tool and also have a lifetime warranty if I'm not mistaken.
Spencer is offline
Old 11-11-2014, 07:28 AM   #68
Livin the dream...
Spencer's Avatar
What is your setup there? Midi vac? What stand and hood?
Spencer is offline
Old 11-11-2014, 08:45 AM   #69
Rosseau stand and wings with integrated stop system. Fastcap hood and my old CT 22. Rosseau also makes a sweet saw hood.
The Following 2 Users Say Thank You to StrongTower For This Useful Post:
needs glasses (11-11-2014), Spencer (11-11-2014)
Old 11-11-2014, 08:50 AM   #70
As for levels, I believe that you should use the longest length that fits the application to achieve the most accurate results. I used a 6ft level on 6-8 doors for a couple years then switched to a 78, so nice to be able to set it on the floor and get above the top hinge. Same is to be said on setting an 8 footer with a 8 foot level. As long as the level is on the money it really doesn't matter what the color is. Even though all mine are yellow...
The Following User Says Thank You to StrongTower For This Useful Post:
Sabagley (11-20-2014)
Old 11-11-2014, 02:31 PM   #71
Trade: Renovator
Rewards Points: 300
Thanks, I'd never seen these before.
http://www.amazon.com/Rousseau-5000-...rousseau+stand
Old 11-11-2014, 03:19 PM   #72
Originally Posted by needs glasses
Thanks, I'd never seen these before. http://www.amazon.com/Rousseau-5000-...rousseau+stand
Rosseau is an awesome company, makes solid stands (they aren't light weight). All made in USA, and lucky for me just 3 hrs south of me. You can actually order right from Rosseau, but if you're a ways away shipping might be costly, and Amazon might be a better option for ordering. They are located in Clarkston, WA.
Old 11-11-2014, 07:38 PM   #73
JAH's Avatar
Trade: carpenter
Rewards Points: 1,910
A 2' step ladder.
JAH is offline
Old 11-11-2014, 07:43 PM   #74
aaron_a's Avatar
Trade: Remodeling and fine carpentry
Rewards Points: 2,238
That rosseau stuff looks pretty nice. And its got a pretty decent price on it too. I had my eye on the fast cap stand for a while, but I'm having a hard time justifying the price tag. How small does it break down?
aaron_a is offline
Old 11-11-2014, 09:39 PM   #75
alboston's Avatar
Rewards Points: 686
I have 2 of the rousseau table saw setups and a router table. Table saw systems are the best. Don't love the router table.
alboston is offline
Old 11-11-2014, 10:38 PM   #76
Willin's Avatar
Trade: Retired
Rewards Points: 498
30" two-sided wide stepladder.
Slickplanes. One for rounding edges, the other for chamfering them.
A baker rack on rollers for sitting all the tools, nails, glue, etc. off the floor and easy to get and move around to where you are.
Willin is offline
Old 11-11-2014, 10:44 PM   #77
The main stand turns into a hand truck, all supports stow. Stands about 3 ft tall, 20" deep with saw attached. Extension wings are 12" deep ladder frames, 60" long, I put 16" wide 1/2 prefin ply on them. It's a heavy stand with a saw on it, I wouldn't want the setup if I had to load into a pickup. Enclosed trailer it works awesome. All powder coated steel. For the stand, extension tables and stop system, I've got around 600 in the setup. Thing I liked about it is that the stop system had an outrigger that you can have a stop all the way out to around 10'. I'm rolling into new construction all the time so it's setup in a garage or a big great room. Rolls awesome.
For smaller easier setup they offer a stand similar to what the saw helper had for saw support, one of my friends has one.
Old 11-11-2014, 11:05 PM   #78
Willin's Avatar
Trade: Retired
Rewards Points: 498
I have my excellent SawHelper stand and fence and stop for sale. 8'4 on the L and 5'0 on the R.
Willin is offline
Old 11-16-2014, 01:23 PM   #79
Jspike's Avatar
Trade: carpenter
Rewards Points: 47
For doors I love my stabila plate to plate levels. I can adjust them to whatever height I need for the different size doors we put in. The two little standoff nobs allow me to make the top and bottom perfectly level. Then I can flip the level around and use the straight edge to shim the rest of the door straight.
Jspike is offline
Old 11-17-2014, 04:29 AM   #80
pappagor's Avatar
Trade: general contractor
Rewards Points: 32
it thought i was the only one that used them for doors. very good unit
pappagor is offline
Went looking for tools and thought i found a cool tool store! BCConstruction Tools & Equipment 3 04-05-2013 05:42 PM
stolen tools & identifying tools SeasideCA Painting & Finish Work 2 02-10-2012 05:07 PM
Hilti Fleet Program for TOOLS s_k_i_ General Discussion 3 04-26-2009 07:18 PM
Is anybody using SHEETROCK Tools? Big Bison Tools Drywall 1 11-01-2007 06:47 PM
