'Must Have' Tools For Finish Carpentry? - Page 3 - Finish Carpentry - Contractor Talk
Old 11-09-2014, 10:15 AM   #41
Lanya LaPunta's Avatar
Rewards Points: 565
Re: 'Must Have' Tools For Finish Carpentry?
Originally Posted by Rich D. View Post
I have my eye on the new 16 ga bostich. Very cool tip.
How does everyone like the fast cap scribe? I have one and I think they could of done a better job with how the pencil is held in.
And what's everyone using the Festool Sanders for when installing trim? I'm guessing the ras is for copping?
And what about track saws for trim? Where you guys using them? If im ripping alot when trimming i use the small dewalt table saw with a combo blade.
Normally, I use my track saw (I have both the cordless and corded Dewalt), it's for breaking down sheet goods. We do some built-ins and it's substantially easier than wrestling 3/4 stock to the table saw. They're used for lots of other sundries, however, that's our primary use.
I know a lot of people that cope with a jig saw ... some with a sander, one guy I know uses a Dremel. However, I seem to be faster than any of them, some by far, using a simple coping saw. I don't know, I have used a Colin's coping foot with a barrel jigsaw ... and I may be somewhat faster with that ...
I am not nearly as fast with a coping saw as others that I have seen. I mean some of those guys are ... clamp,start, unclamp and next ... about as fast as I typed this.
I have the FastCap scribe. It serves its purpose but it's not (at least in my opinion) the neatest thing since sliced bread.
I believe the reason that people are typing a larger laundry list as they are thinking of "finish carpentry", not just trim work.
Lanya LaPunta is offline
Old 11-09-2014, 10:24 AM   #42
Repair & Renovation
Rich D.'s Avatar
Trade: R. Damato Construction
Rewards Points: 2,584
I think they are also thinking finish carpentry.
I just don't see the need for a track saw in trim work..
If I had to back cut an extension or scribe I would pick the table saw over clamping and track to a 2-4" piece of stock.... Which is pretty much impossible anyway.
I've cut down probably hundreds of sheet goods and wide boards with my track saw. It's my favorite tool. Just not for trim!
“The bitterness of poor quality is remembered long after the sweetness of low price has faded from memory.” - Aldo Gucci
Rich D. is offline
Old 11-09-2014, 10:26 AM   #43
Repair & Renovation
Rich D.'s Avatar
How is the ras compared to a grinder?
Same thing pretty much?
I've had my eye on one.
Rich D. is offline
Old 11-09-2014, 10:31 AM   #44
pappagor's Avatar
Trade: general contractor
Rewards Points: 32
when you get to about 300 lbs you will have all you will need to trim a new home.
don"t be fooled it will not fit in one box
pappagor is offline
Old 11-09-2014, 11:08 AM   #45
aaron_a's Avatar
Trade: Remodeling and fine carpentry
Rewards Points: 2,238
http://www.leevalley.com/US/wood/page.aspx?p=71776
Probably not a must have, but is really LIKE to have...
aaron_a is offline
Old 11-09-2014, 01:45 PM   #46
aaron_a's Avatar
Clamps. Lots and lots of clamps. Then probably some more clamps
aaron_a is offline
The Following User Says Thank You to aaron_a For This Useful Post:
chris klee (11-09-2014)
Old 11-09-2014, 01:52 PM   #47
Repair & Renovation
Rich D.'s Avatar
No, not one but maybe several!!!
Rich D. is offline
Old 11-09-2014, 02:42 PM   #48
CarpenterSFO's Avatar
Rewards Points: 2,044
I use the track saw to cut tiny strips and corner pieces all the time, usually without clamping anything. Tapered jamb extensions are much easier with the track saw than with any other system.
That being said, I wouldn't consider it to be must-have for crown, base, and casings.
I also wouldn't consider an RAS or the like as must-have for coping. Nice, but coping saw, files, and sandpaper work fine.
You can do without a laser level at first, though they speed things up a lot.
- Bob
CarpenterSFO is offline
The Following User Says Thank You to CarpenterSFO For This Useful Post:
MDjim (11-09-2014)
Old 11-09-2014, 03:15 PM   #49
pappagor's Avatar
Rewards Points: 32
it is like what tool has made your job easier. what job what day what week what year
pappagor is offline
The Following User Says Thank You to pappagor For This Useful Post:
hdavis (11-09-2014)
Old 11-09-2014, 03:18 PM   #50
Ciaos mitigator
chris klee's Avatar
Rewards Points: 1,290
I guess if your doing new construction track home trim you won't need a track saw.
But almost every job I have done trim on I had to cut a door down a little, cut some shelving, make some built in shelving, ect.
On old stone houses most of the time the old window jambs are not even so the extension jambs end up all crooked and are made way easier on the track saw.
CK Carpentry
chris klee is offline
The Following 2 Users Say Thank You to chris klee For This Useful Post:
CarpenterSFO (11-11-2014), MDjim (11-09-2014)
Old 11-09-2014, 03:27 PM   #51
Tom M's Avatar
Rewards Points: 3,444
I do a variety of carpentry trim but when I think of finish work, I thinkof built ins or spray finishing so I would go in that direction.
I also have a couple of routers but I don't use them to their potential. So I think a router table is valuable to a straight up finish carpenter.
Tom M is offline
Old 11-09-2014, 03:37 PM   #52
Always Learning
overanalyze's Avatar
Trade: Builder/Remodeler
Rewards Points: 702
Most everyone has listed good stuff. I like to make sure we have the Kreg jig and plenty of pockets screws on hand too.
overanalyze is offline
The Following 3 Users Say Thank You to overanalyze For This Useful Post:
alboston (11-11-2014), mikeswoods (11-09-2014), needs glasses (11-11-2014)
Old 11-10-2014, 07:14 AM   #53
Livin the dream...
Spencer's Avatar
Trade: Finish Carpentry
Rewards Points: 5,514
I also love my veto. I've had it for a few months now and took a few things out that I don't use often enough. I reorganized it the other day.
Lewis Carpentry
Spencer is offline
The Following 3 Users Say Thank You to Spencer For This Useful Post:
hdavis (11-10-2014), needs glasses (11-10-2014), Xtrememtnbiker (11-10-2014)
Old 11-10-2014, 07:18 AM   #54
Livin the dream...
Spencer's Avatar
Another good tool to have is a drywall knife. When I have to remove trim I often put one between the flat bar and the wall to prevent damage to the drywall.
Spencer is offline
The Following User Says Thank You to Spencer For This Useful Post:
dkillianjr (12-21-2014)
Old 11-10-2014, 07:24 AM   #55
mikeswoods's Avatar
Trade: interior remodeling
Rewards Points: 2,664
I use a painters tool for removing trim---cut the caulk--drive in the painters tool and pry back a bit--
mikeswoods is offline
The Following User Says Thank You to mikeswoods For This Useful Post:
Spencer (11-10-2014)
Old 11-10-2014, 09:55 AM   #56
colevalleytim's Avatar
Rewards Points: 390
I like using a stripping bar for removing trim
colevalleytim is offline
The Following User Says Thank You to colevalleytim For This Useful Post:
RiverBG (02-28-2015)
Old 11-10-2014, 10:07 AM   #57
Rewards Points: 390
I read through this list, two things I didn't see:
Multimaster
Tool Tote/Bench
mikeswoods (11-12-2014)
Old 11-10-2014, 12:20 PM   #58
needs glasses's Avatar
Trade: Renovator
Rewards Points: 300
Nice 4.5" grinder with a 40 grit sanding disc for copes.
You do cope right?
yep, I cope the inside corners on crowns. Not so much on baseboards.
needs glasses is offline
Old 11-10-2014, 03:49 PM   #59
John the Builder
SmallTownGuy's Avatar
Rewards Points: 7,800
That right there - the fellas always asked to borrow my "drinkin' buddy".
Never been without one - NEVER.
SmallTownGuy is offline
Old 11-10-2014, 07:46 PM   #60
hdavis's Avatar
Rewards Points: 2,848
Pulling trim without damaging it can be tricky. I use everything from stripping bar to flat bar to cats paw to 3" stiff angle bladed putty knife. I'll throw in a deck of cards, just to round it out (thanks, Bass).
hdavis is online now
asevereid (11-10-2014)
Went looking for tools and thought i found a cool tool store! BCConstruction Tools & Equipment 3 04-05-2013 05:42 PM
stolen tools & identifying tools SeasideCA Painting & Finish Work 2 02-10-2012 05:07 PM
Hilti Fleet Program for TOOLS s_k_i_ General Discussion 3 04-26-2009 07:18 PM
Is anybody using SHEETROCK Tools? Big Bison Tools Drywall 1 11-01-2007 06:47 PM
