Making Barn Beams - Finish Carpentry - Contractor Talk
Making Barn Beams
Old 06-27-2015, 02:54 PM   #1
Livin the dream...
Spencer's Avatar
Trade: Finish Carpentry
Rewards Points: 5,514
Making Barn Beams
Got the Festool planer with undulating head and made a sample up for HO and architect. They loved it. (Beauty is in the eye of the beholder.)
Mostly used the planet, RAS, chisel, and awl for holes.
I'm going to mill to size, set up the foreman and biscuit jointer, made the holes and slots, distress, assemble, distress corners/edges post assembly, and install.
Also talked them into letting me do three sections per 17' beam and cover the splice with iron strapping. That should make the job a lot easier.
Lewis Carpentry
Spencer is offline
The Following 4 Users Say Thank You to Spencer For This Useful Post:
kwunch (06-28-2015), mikeswoods (06-27-2015), pinwheel (06-28-2015), Tom Struble (06-27-2015)
Old 06-27-2015, 02:59 PM   #2
I like Green things
WarnerConstInc.'s Avatar
Rewards Points: 5,858
Re: Making Barn Beams
I wouldn't bother planing any of the lumber before gluing up wraps (if you have to).
Straps cover inconsistencies, the grooves look out of place.
Warner Mill Works
Facebook
YouTube
WarnerConstInc. is online now
Old 06-27-2015, 03:01 PM   #3
I like Green things
They could have just bought real beams. Place up here sells them cleaned up for pretty cheap.
Warner Mill Works
Facebook
YouTube
The Following 2 Users Say Thank You to WarnerConstInc. For This Useful Post:
CITY DECKS INC (06-28-2015), Metro M & L (07-02-2015)
Old 06-27-2015, 03:08 PM   #4
rrk's Avatar
Rewards Points: 5,370
I guess so, to me it looks very fake. Does not look aged.
Can the grooves. Needs to be power wire brushed.
When I get wood for fake beams cut they cut it on a horizontal band saw and increase feed rate and/or send it through a wire brush machine. Takes them 20 minutes to do 100 ft for my last order
rrk is online now
Old 06-27-2015, 03:19 PM   #5
Livin the dream...
Spencer's Avatar
The only piece I have to plane is the inside of the bottom piece to give something flat for the sides to fasten down to.
The grooves in the center picture are going to be chiseled to look like cracks.
There was no provision made to attach real beams. I barely have what I need to get fake ones up there.
I just roll with it and do the best with what they put in front of me.
Lewis Carpentry
Spencer is offline
Old 06-27-2015, 03:33 PM   #6
keith mathewson's Avatar
Trade: carpenter
Rewards Points: 426
Not to be negative but do you know the look of what it is that you're attempting to replicate.
www.seattlefinewoodworking.com
keith mathewson is offline
Old 06-27-2015, 03:34 PM   #7
Livin the dream...
Spencer's Avatar
Seems like you're talking about more of a rough sawn look. I'm going for more of an actual aged hand hewn beam. My cracks need some work but I feel they are important as the imitate the actual affects of an aged beam. Not sure how eliminating them makes it look more aged.
These picks are of the beams of the barn behind my house as of now. I think the inconsistent (not flat) texture, cracks, and hewn marks are the most important characteristics. And of coarse the bug holes.
This is a pice of sawn lumber on my barn. Not the look we're after.
I was thinking of using a wire brush attachment on a grinder to give more of a consistent texture but wasn't sure I needed the extra step and thought it would take a lot of time. I'll give it a shot. I assume you're talking about going with the grain with a 1" wide wheel?
Lewis Carpentry
Spencer is offline
Old 06-27-2015, 03:39 PM   #8
Livin the dream...
Spencer's Avatar
It's alright. I was fully aware when I started the thread and posted picks the critisism would begin. I'm all ears to what would make them better. But like I said, beauty is in the eye of the beholder and I can make it look as historically authentic as I want...if the HO and archy don't like it...it really doesn't matter.
Lewis Carpentry
Spencer is offline
The Following User Says Thank You to Spencer For This Useful Post:
Old 06-27-2015, 03:49 PM   #9
Trade: carpenter
Rewards Points: 426
The pictures that you showed of the beams behind your house shows two different styles of doing a beam. Of the style that your are tempting to replicate you will notice that there is a system that was used when they made it. There is consistency in the manner of which they approached the work. While the beam behind your house was done with an axe what you're attempting to show with something that would have been done with an adz. You may wish to look at some pictures online of projects that have been done with an adz and attempt to have more consistent pattern.
Old 06-27-2015, 04:09 PM   #10
Eaglei's Avatar
Trade: carpenter & Masonry
Rewards Points: 1,510
The pictures of the inside of your barn are really neat .................I'm a city boy but always loved the barn look .That look is really taking off in my area and so are the prices . Good luck with your project .
Eaglei is offline
The Following User Says Thank You to Eaglei For This Useful Post:
Old 06-27-2015, 04:10 PM   #11
fourcornerhome's Avatar
Trade: home improvement contractor
Rewards Points: 596
The texture with the scallops looks good. The fake cracks will always look fake, especially when natural cracks form. I would skip them and add some random chop marks and some scallop chip outs.
fourcornerhome is online now
Old 06-27-2015, 04:14 PM   #12
Eaglei's Avatar
rrk can you recommend the yard that you use for your beams .
Eaglei is offline
Old 06-27-2015, 04:15 PM   #13
Livin the dream...
Spencer's Avatar
Ehhh.....the more I look at the "cracks" that I put in with the RAS...the more I blush. Those need some work. I think I'll skip the RAS and use the chisel. I think they look much more real with the chisel.
One other thing was that they had told me beforehand that they didn't want "deep" chisel marks (awle/axe), so I couldn't get to carried away with making it look like what I showed from my barn. They also didn't want anything that was to consistent.
Spencer is offline
rrk (06-28-2015)
Old 06-27-2015, 04:39 PM   #14
I like Green things
Just use the planer, keep it simple.
Warner Mill Works
Facebook
YouTube
rrk (06-28-2015)
Old 06-28-2015, 05:20 PM   #15
rrk's Avatar
It is much easier to duplicate simple, especially when there are many pieces to duplicate. Otherwise the first one does not look like the last one.
rrk is online now
Old 06-28-2015, 06:27 PM   #16
SuperiorHIP's Avatar
Trade: Home Improvement Contractor
Rewards Points: 1,450
I like the first and last picture, needs a little work but for fake aged beams I think they look pretty good (middle picture I think looks overdone). Hard to fake a crack, would have to see it a little bit further in the works.
SuperiorHIP is offline
Old 06-28-2015, 07:03 PM   #17
Focusing on solutions.
pinwheel's Avatar
Rewards Points: 488
Those are the only opinions that really matter. Please them & tell everyone else to phuck off.
I think your on the right line, keep after it.
pinwheel is online now
The Following 3 Users Say Thank You to pinwheel For This Useful Post:
brhokel606 (06-29-2015), CarpenterSFO (06-29-2015), Deckhead (06-30-2015)
Old 06-28-2015, 07:42 PM   #18
rrk's Avatar
Then don't ask for opinions
rrk is online now
Old 06-28-2015, 09:24 PM   #19
kwunch's Avatar
Rewards Points: 596
I think the grooves running across the grain look pretty decent, so long as they're nice and mellow and used sparingly. The "bug holes" are a nice touch, and the work with the planer looks pretty good. I don't like the grooves running with the grain though, they look a little out of place and over done imo.
kwunch is offline
Old 06-29-2015, 06:34 PM   #20
Trade: carpenter
Rewards Points: 426
It's one thing for the homeowner not to know anything, that's why they hired you. They assume that you and the architect know something. In this case I wonder about the architect.
Should i be making more money? nickcarlile56 General Discussion 42 07-21-2014 07:17 PM
Questions about installing 100 amp sub-panel in new pole barn garage? PoleBarnsNY Electrical 16 04-15-2014 05:25 PM
Info on taking down a post and beam barn 4 seasons lawn& Carpentry 27 08-09-2013 04:40 PM
garage addition: part pole barn lewisthepilgrim Framing 6 04-11-2013 09:03 AM
Saw an ad for free Barn Beams Aggie67 Construction 0 04-21-2009 08:44 AM
