Looking For No Bore Concealed Hinges On Face Frames - Finish Carpentry - Contractor Talk
Old 12-05-2009, 08:21 PM   #1
denverboz's Avatar
I'm looking for some no bore, concealed hinges that would go on cabinets with face frames. Thing is the doors are only 1/2" wider than the openings, so they overlay about 1/4" on each side with the present hinges.
I found some 3/8 overlay ones, which I assume means it overlays 3/8" on the hinge side.
If that's the case, that's cutting it pretty close.
Anyone know of any hinges that would work in this application.
I can't use Euro hinges because the edges of the raised panel doors are routed, so I don't have a full 3/4" there.
Any help is much appreciated.
denverboz is offline
Old 12-05-2009, 08:49 PM   #2
DaVinciRemodel's Avatar
Trade: Design/Build Remodeler
Rewards Points: 570
Re: Looking For No Bore Concealed Hinges On Face Frames
Try Rockler.com and check semi concealed hinges. Other than this - I can't think of an option without bore.
Good luck
I love what I do and I'm very good at it!
Da Vinci on the web or Da Vinci On Facebook
DaVinciRemodel is online now
The Following User Says Thank You to DaVinciRemodel For This Useful Post:
denverboz (12-05-2009)
Old 12-05-2009, 09:23 PM   #3
LRG WoodCrafting
Leo G's Avatar
Trade: Maker of Fine Sawdust
Rewards Points: 2,055
http://www.dlawlesshardware.com/nofafrcohilq.html
Sawdust Follows Me Everywhere
WWG1WGA
Carpenter by day.
Mad scientist by night.
http://lrgwood.com
Leo G is online now
Old 12-05-2009, 10:34 PM   #4
denverboz's Avatar
Originally Posted by Leo G View Post
Thanks Leo, I already found those online before.
But here's the thing I'm confused about, it says "Overlays for 1/2" to 3/8".
Does that mean it overlays the hinge side 3/8" to 1/2"?
Cuz like I said the doors are only 1/2" wider than the openings.
Wish they a 1/4" overlay.
Old 12-05-2009, 10:46 PM   #5
Maker of fine kindling
Gus Dering's Avatar
Trade: cabinet maker
Rewards Points: 12,490
A euro hinge needs a 35mill hole about 1/2" deep.
If you can bore a hole that deep within 3 mill of the edge of the door you can do this with a Blum hinge and a 6mill plate.
Gus Dering is offline
The Following User Says Thank You to Gus Dering For This Useful Post:
Old 12-05-2009, 10:51 PM   #6
denverboz's Avatar
Good luck
I really like Rockler, but they were pretty unhelpful and displayed a lot less knowlege on the subject that I would have expected. One guy on the phone last night and the first guy I talked to at the store today, were fairly ignorant about Blum hinges, but worse they were trying to BS me into thinking they knew what they were doing or talking about.
I mean don't get me wrong, we all have limits to our knowledge, no big deal.
But don't try and act like you are actually an expert on the subject when you can't answer basic questions I'm asking. And I'm no genius, so they weren't hard questions.
Finally another worker there, I suspect sensed my frustration and came over and was at least a little helpful. But when I asked about no bore concealed hinges, he didn't really have a clue just said, 'yeah I'm sure they have them, you just have to do some research'.
I was amazed I got out of there without spending any money, there's always something in there I see I want.
Old 12-05-2009, 10:58 PM   #7
Rewards Points: 570
You can go to the blum site and get tech info on all their products. You may then need to order from Louis & Co - Rockler doesn't sell all blumb products.
Old 12-05-2009, 11:01 PM   #8
denverboz's Avatar
Can't do it. The edges of the doors are shaped, it doesn't have the depth.
Even though I pretty much knew that already, that was one of the things I wanted the guys at Rockler to confirm for me.
Old 12-05-2009, 11:09 PM   #9
Gus Dering's Avatar
So then a standard face frame plate is out. They only go to 6 mill.
You can use a 6mill bore and a euro 9 mill plate. Can you get your 1/2" deep hole at 6mill from the edge?
Got any pics of this door?
Old 12-05-2009, 11:21 PM   #10
LRG WoodCrafting
Leo G's Avatar
Grass makes a compact hinge that only needs a 3/8" deep hole
http://www.grassusa.com/faceframe2.html
WWG1WGA
Carpenter by day.
http://lrgwood.com
Leo G is online now
Old 12-05-2009, 11:36 PM   #11
Gus Dering's Avatar
Oh yeah
Blum has a mini hinge we use for narrow stiles. Takes a slightly larger that 1" hole. Not too sure how deep. But I bet it is around 3/8".
If you can get 3/8" deep at 3mill you can use a 6mill frame plate. You need to confirm the bore depth though.
Old 12-05-2009, 11:40 PM   #12
LRG WoodCrafting
Leo G's Avatar
Would that be a 26mm hole Gus?
WWG1WGA
Carpenter by day.
http://lrgwood.com
Leo G is online now
Old 12-05-2009, 11:48 PM   #13
Gus Dering's Avatar
Yeah, like I said a bch more that 1"
Bad news on the clip top mini hinge though. Need a 12.5 mill deep hole. Is that 1/2" Leo?
Old 12-05-2009, 11:50 PM   #14
LRG WoodCrafting
Leo G's Avatar
That's close enough to 1/2" for me Gus. Looks like if he is forced to use bored hinges he will have to go with the Grass.
It is all I use.
WWG1WGA
Carpenter by day.
http://lrgwood.com
Leo G is online now
Old 12-06-2009, 12:16 AM   #15
Jeremy E's Avatar
Trade: carpentry
Rewards Points: 150
Check out these from Lee Valley...
http://www.leevalley.com/hardware/pa...80&cat=3,41241
Edit: Oops. Nevermind. Forgot about the face frame...
Last edited by Jeremy E; 12-06-2009 at 12:19 AM. Reason: Momentary lapse of intelligence
Jeremy E is offline
Old 12-06-2009, 12:51 PM   #16
denverboz's Avatar
Bump.
Anyone else want to try?
Again, I'm looking for a no bore, 1/4" overlay concealed hinge on face frame cabs.
I found this one here: http://www.dlawlesshardware.com/nofafrcohilq.html
not yet sure if I could get it to work for the 1/4" overlay I need.
Gonna give them a call tomorrow.
But that's along the lines of what I need.
Thanks for all the input guys.
Old 12-06-2009, 03:26 PM   #17
crovello's Avatar
Trade: General contractor
Rewards Points: 150
I would think you could use those if you had to. Just put a block behind the hinge to give you somehting to mount to that is even with the face frame.
crovello is offline
Old 12-07-2009, 03:25 PM   #18
Jeremy E's Avatar
Trade: carpentry
Rewards Points: 150
I thought so too, but that's rather inelegant. I guess if there is nothing else out there, I'd do it.
Jeremy E is offline
Old 12-07-2009, 07:50 PM   #19
newbuilder's Avatar
Trade: builder/remodeler
I don't know if this helps but woodworker supply has some, they are a bit more expensive though
woodworker.com/fce-mnt-hng-for-58-mat-mssu-942-491.asp
sorry I can't post url's yet
newbuilder is offline
Do I market on the internet or face to face? constructonomics General Discussion 4 08-13-2009 07:28 AM
Face frame hinging basics Gus Dering Finish Carpentry 5 04-07-2009 07:38 PM
Help with Dor-o-matic hinges ZiggysMCS General Discussion 4 03-29-2009 03:20 PM
Painting commercial window frames. ALCbuilding Painting & Finish Work 3 02-05-2009 09:51 AM
Hollow metal welded frames welded into structual steel detroit687 Commercial Construction 1 09-11-2008 10:18 PM
