How-to: Tapered Square Leg? - Finish Carpentry - Contractor Talk
Old 05-11-2010, 08:58 PM   #1
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 1,357
A good repeating client of mine (retired) is an ex-deck builder and cabinetry hobbyist. He emailed me with this tonight, and I gave him my solution(s), but thought I'd check here for something really elegant.
I am building a bar high table and the legs are 36" long and 3" in diameter. I want to taper them on all 4 sides so that the top is 3"x3" for the first 6" down and then the taper starts. The bottom should end up as a 2"x2" diameter leg. So that means I have to take 1/2" off each side, at the bottom. A conventional tapering jig won't work because once I cut the first two sides, the taper will be against the fence and the remaining sides will have a different taper. And even if I could hold the 6" straight edge against the jig, by the time I get to the bottom of the leg, the jig will be out past my rip fence, so I will have nothing to guide it against.
So how do I cut 1/2" angled cut on a 3" square leg, on all four sides?
Tinstaafl is online now
Old 05-11-2010, 09:25 PM   #2
J.C.'s Avatar
Rewards Points: 162
Re: How-to: Tapered Square Leg?
I've always used a jointer to cut tapered legs. Just tape a shim block at the top of the leg so the leg doesn't cut for the first 6" and set the jointer for 1/2" depth of cut. If he doesn't have a jointer that will cut that deep, he'll have to do it in several passes and adjust the shim block. He could also draw the taper and cut to the line with a power plane if he doesn't have a jointer. He might also want to leave the line and finish it off with a belt sander.
J.C. is offline
Old 05-11-2010, 09:38 PM   #3
Working
Cole82's Avatar
Rewards Points: 2,276
I use a clamping sled for the table saw.
Similar to this one.
The boss of awesome
Cole82 is offline
Old 05-11-2010, 09:47 PM   #4
Wood Butcher
bhock's Avatar
Trade: Remodels/Custom Cabinets/Granite Countertops
what he^ said.
bhock is offline
Old 05-11-2010, 09:55 PM   #5
Fence's Avatar
Trade: Fences
Rewards Points: 75
table saw.
modify the above jig- to support the cut off and a block at the front.
Deck Builder In Oakville
Fence is offline
Old 05-11-2010, 09:58 PM   #6
Wood Butcher
bhock's Avatar
why would you need to do that...all you need to do is adjust the jig .
bhock is offline
Old 05-11-2010, 09:58 PM   #7
KemoSabe
loneframer's Avatar
Rewards Points: 12,218
After you rip the first 2 tapers with the jig, pin the cutoffs back on, then make your next 2 cuts. Remove the cutoffs, viola, 4 equal tapers.
loneframer is offline
The Following 2 Users Say Thank You to loneframer For This Useful Post:
pinwheel (05-12-2010), tcholdren (05-12-2010)
Old 05-11-2010, 10:01 PM   #8
Working
Cole82's Avatar
To make it perfect wouldn't you have to shim for kurf?
Cole
The boss of awesome
Cole82 is offline
Old 05-11-2010, 10:07 PM   #9
Trim40's Avatar
Trade: Guy who plays with wood
Rewards Points: 550
Cole
You slide the cut off up the leg before you pin it back on.
Trim40 is offline
The Following User Says Thank You to Trim40 For This Useful Post:
loneframer (05-12-2010)
Old 05-11-2010, 10:08 PM   #10
Working
Cole82's Avatar
Gotcha thanks
never used that method before.
Cole
The boss of awesome
Cole82 is offline
Old 05-11-2010, 11:34 PM   #11
Cjeff's Avatar
Trade: Renovations
If you do not want very small pin holes use double sided tape.
Cjeff is offline
Old 05-12-2010, 05:21 PM   #12
Capra aegagrus
Tinstaafl's Avatar
First thing I thought of.
But he wouldn't want the pin holes, so I suggested applying them to the jig instead.
Thanks for the ideas, guys. I'll post an update when I hear what he wound up doing, and how it worked.
Old 05-12-2010, 05:34 PM   #13
Dan
ApgarNJ's Avatar
Rewards Points: 2,000
as someone who never has to do this type of thing. I'm always curious how it's done. I know about tapering jigs but never bought one because I don't build tables or furniture with tapers on them. I should practice one some scrap wood so I know how to do them correctly. thanks for the post Tins
ApgarNJ is offline
The Following User Says Thank You to ApgarNJ For This Useful Post:
Tinstaafl (05-12-2010)
Old 05-12-2010, 08:05 PM   #14
flyjaysun's Avatar
Trade: little bit of this and that
Rewards Points: 75
Norm would have not cut all the way thru last bit of the taper then flipped leg.
flyjaysun is offline
Old 05-14-2010, 06:35 PM   #15
Jeremy E's Avatar
Trade: carpentry
Rewards Points: 150
After I saw this video...
http://www.popularwoodworking.com/ar...to_taper_legs/
...I started doing them this way. Good results and fun to do...
Jeremy E is offline
The Following 2 Users Say Thank You to Jeremy E For This Useful Post:
flyjaysun (05-15-2010), Tinstaafl (05-14-2010)
Old 05-14-2010, 06:51 PM   #16
Capra aegagrus
Tinstaafl's Avatar
Don't get no better'n that. If you have a jointer.
Thanks!
Old 05-14-2010, 07:51 PM   #17
J.C.'s Avatar
Rewards Points: 162
The jointer is the way to go. However, there is no reason to mark every leg and make two cuts per taper. You just need to make an L-shaped shim block to rest the top of the leg on to stop it from cutting until you get to your start point. Just set the jointer to the depth of the taper, mark the start point on your first leg (better yet, test leg made out of scrap), hold the bottom of the leg down on the infeed table and the top of the leg on cutter where it will start cutting and measure the distance between the top of the outfeed table and the bottom of the top of the leg. Cut your L-shaped shim block to rest the top of the leg on, make a test cut, adjust the thickness of your shim block by cutting it down or adding tape as necessary. Once you have it perfect, there is no reason to mark any of the other legs and now you can hold down on both the top and the bottom of the leg instead of having the top of the leg bouncing around as you try to push it through the jointer.
J.C. is offline
Price per Square Foot for Framing Contractors in Dallas / Fort Worth? Habit Framing 1 02-08-2010 07:26 AM
Miter box out of square oldhouseluvr Tools & Equipment 3 04-15-2009 02:11 AM
Drywall tapered edge question. roo Drywall 10 03-18-2009 06:38 AM
Help! How much a square? Sliverbush General Discussion 260 02-05-2009 09:17 PM
Square Tapered Columns ApgarNJ Finish Carpentry 30 01-29-2008 01:25 PM
