How Long Does It Take You To Install Crown - Finish Carpentry - Contractor Talk
Old 07-13-2012, 11:06 PM   #1
President of the world
world llc's Avatar
Trade: general contractor
Rewards Points: 2,001
I was talking to TBFGohst yesterday about set rates for single rooms of crown, rooms smaller than 16 x 16 with 4 inside corners and not difficult to access to hang and a place to set up and work. i wanted to know how it was working for him...
Tom brags he can be pulling out the driveway in 1 hour flat with caulking and hole filling. That sounds impressive, figure almost 2 hours for me for the same scope.
so is tom exceptionally motivated, or am i just a slacker!
world llc is offline
Old 07-13-2012, 11:08 PM   #2
world llc's Avatar
Re: How Long Does It Take You To Install Crown
oh, and we are talking 4 5/8 or maybe 5 5/8 primed FJ or even MDF either OG or unique (UC)
Old 07-13-2012, 11:10 PM   #3
I like Green things
WarnerConstInc.'s Avatar
Rewards Points: 5,824
I think an hour is pushing it. The crown install is the quick part, I could have all 4 measurements, sticks cut and coped in under 20 minutes. The thing that eats up time is getting stuff out, cleaning up and loading up.
Even if it took two hours, 250 bucks an hour is something I can live with.
Warner Mill Works
Facebook
YouTube
WarnerConstInc. is offline
Old 07-13-2012, 11:17 PM   #4
world llc's Avatar
set up and clean up are my 2 biggest time eaters aswell
laser distance meter is the time saver
The Following 2 Users Say Thank You to world llc For This Useful Post:
hdavis (07-14-2012), We Fix Houses (07-14-2012)
Old 07-14-2012, 07:43 AM   #5
Trim40's Avatar
Trade: Guy who plays with wood
Rewards Points: 550
I might be able to pull it off in an hour.
4 cuts, not much clean up.
Use the CO2 bottle instead of the compressor, shorter set up time, less hose.
$250 sounds good
Trim40 is offline
Old 07-14-2012, 07:45 AM   #6
master hacker of wood
FRAME2FINISH's Avatar
Trade: restoration carpentry
Rewards Points: 1,730
You lost me at caulk sorry
FRAME2FINISH is offline
The Following 2 Users Say Thank You to FRAME2FINISH For This Useful Post:
hdavis (07-14-2012), joethepainter (12-05-2012)
Old 07-14-2012, 07:52 AM   #7
Finish Carpenter
TBFGhost's Avatar
Trade: Finish Carpentry, Reno
Rewards Points: 2,760
Exactly, you need a simple set-up. I think we all install the same way. Four measurements, eight cuts, four copes.
My set-up goes like this normally.
Pull in knock on door and say hello (this is where you can lose most of your time),
find the nearest door to the exterior relative to where you can get power and where the shortest trip to the truck is (normally I know this already from my first visit to scope out of the work),
Go to truck, grab bin full of 4x12 drop cloths and lay them out.
Get ladder and laser measure,
Take measurements,
Pull out saw and grinder, run cord, cut and cope,
Install crown, use a Crown Clip if needed, Paslode for nailing
Fill nail holes with painters putty as you go
Back out to truck, load up un-needed tools, pull out caulk gun and a wet rag, caulk.
Load up rest of un-needed tools.
Get client, say good bye.
One hour.
I am going to do a small powder room later today....I will time myself. Its a 4 1/2" PFJ Colonial crown. Its small, but its five walls with crappy tape job on the 45 degree corners.
EDIT: I wasn't bragging Matt, you mentioned the cheap price I did single rooms of crown for, I was just trying to explain how I did it that cheap.
http://www.punchlistcarpentry.com/in...es/Page405.htm
TBFGhost is offline
Old 07-14-2012, 07:57 AM   #8
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 5,076
Take measurements,
One hour.
Most importantly when you knock on the door have your drop sheets under your left arm, tool bag in your left hand and your right hand free to shake the client's. No wasted trips.
Inner10 is offline
Old 07-14-2012, 08:50 AM   #9
world llc's Avatar
i know, it just makes for a better story
i think i am going to steal, i mean be inspired by, your promotion
Old 07-14-2012, 09:07 AM   #10
hdavis's Avatar
Rewards Points: 1,126
Am I the only person here that keeps templates for copes?? This is only 2 straight cuts and 4 copes, don't even need a miter saw if I have the template for the molding. I agree about the compressor set-up, I'll use my small one (working by myself). Paslodes are convenient and would save that time.
Hand cutting (handsaw and a coping or jigsaw), I can haul everything I need in 2-3 trips, use buckets in the room for my cutting station, and put some plastic under to catch the sawdust. Laser measure and mark the walls, mark the molding on the floor, two straight cuts, 4 copes, nail up, fill nail holes, wrap up plastic and small pieces and put it in a bucket, load out in 2-3 trips.
This doesn't take very long at all as long as the corners aren't all goofed up and I don't have to wait 2 weeks for the trim to adjust to site conditions...
hdavis is offline
Old 07-14-2012, 09:17 AM   #11
Finish Carpenter
TBFGhost's Avatar
Yeah, you just keep your work up there in North East Jersey and we won't have a problem
I will be honest, I don't let the crown acclimate on all of the jobs, sometimes if I get a chance I will get it before hand and let it acclimate inside my own home, but that is only about 50% of the time...the crown I am about to do today didn't have a chance to acclimate.
TBFGhost is offline
Old 07-14-2012, 09:50 AM   #12
Tom Struble's Avatar
Trade: siding
Rewards Points: 20
i bet i can wrap it in aluminum faster then he can install it
Tom Struble is offline
The Following 3 Users Say Thank You to Tom Struble For This Useful Post:
hdavis (07-14-2012), WarriorWithWood (08-31-2012), WilsonRMDL (07-14-2012)
Old 07-14-2012, 09:51 AM   #13
Trade: siding
Rewards Points: 20
fast and cheap.. what a world
The Following 2 Users Say Thank You to Tom Struble For This Useful Post:
KnottyWoodwork (07-15-2012), William James (07-14-2012)
Old 07-14-2012, 09:58 AM   #14
world llc's Avatar
What a hack! Lol
Ill miter and cope one side the day before if I have a few rooms and the time. I'm out in an hour when I do that, 4 cuts I can use my cordless circular saw on... A passload would save some set and cleanup time too
Old 07-14-2012, 10:31 AM   #15
hdavis's Avatar
I think the promotion is a good sales and marketing idea. Like anything, quality can wind up being good or not so good - depends on the installer. The actual work is the least of concerns in a small job like this - travel, talking, setup, cleanup, etc all take as much time as if it was a bigger job.
hdavis is offline
Tom Struble (07-14-2012)
Old 07-14-2012, 11:19 AM   #16
Working
Cole82's Avatar
Rewards Points: 2,276
KnottyWoodWork did 36 corners basically 9 rooms in 10hours that is with setup and tear down of equipment.
Cole
The boss of awesome
Cole82 is offline
The Following 2 Users Say Thank You to Cole82 For This Useful Post:
chris klee (07-18-2012), KnottyWoodwork (07-15-2012)
Old 07-14-2012, 12:39 PM   #17
Trade: siding
Rewards Points: 20
i vote for slacker by the way
world llc (07-15-2012)
Old 07-14-2012, 07:17 PM   #18
239STAIRS's Avatar
Trade: STATE LICENSED GENERAL CONTRACTOR
Rewards Points: 75
MDF Crown is bull**** use FJP. If you filling nail hole your probably painting. Most carpenters don't fill nail holes and calk. Think about it when the last time you seen a good carpenter with painting ****. I guess you could pre- paint install then fill nail holes then repaint should get about $475.00 for about 6hrs work. In Marco Island we trimmed some high rise condos on the gulf in sable mahogany the job was located on the 17th floor and access to saw was down stairs. We measured the entire condo and made our cut at the shop. I guess if you want to get it done in 1hr do that. If not painting or prep work $275 is about right including material that about $215.00 profit The fastest (ME & ANOTHER EXPERIENCED CARPENTER) installed was 1LNF PER MINUTE ON 8FT CEILINGS 8FT BY 10FT ROOM OR LARGER 5.25 INCH FJP PAINT GRADE CROWN (HIGH QUALITY WORK).
239STAIRS is offline
Old 07-14-2012, 07:27 PM   #19
Trade: siding
Rewards Points: 20
well there goes the no pricing policy
TBFGhost (07-15-2012)
Old 07-14-2012, 09:07 PM   #20
Carolina Surface Prep
Rob1954's Avatar
Trade: Media blasting and residential restoration
Rewards Points: 202
$215 profit?
Rob1954 is offline
A question for you "Lone Ranger" crown jockeys Dan V. Finish Carpentry 49 12-07-2010 08:06 AM
Gutter Apron Install Advice Gladiatorx Roofing 2 08-13-2010 02:36 PM
How Long......... wireless General Discussion 24 07-08-2010 06:24 PM
plaster crown molding install prices... CREATE NYC Finish Carpentry 21 01-27-2010 05:28 PM
plaster crown molding install prices... CREATE NYC Painting & Finish Work 2 01-19-2009 06:43 AM
