How Do You Trim An Interior Door - Page 3 - Finish Carpentry - Contractor Talk
Thread Tools
Old 05-13-2019, 08:55 AM
Goin' Down in Flames....
Seven-Delta-FortyOne's Avatar
Trade: Highwayman
Rewards Points: 2,186
Re: How Do You Trim An Interior Door
Originally Posted by hoser View Post
I hang my doors plumb not level, but it is INCREDIBLY rare to cut all miters at 45 and expect them to fit perfectly. They are almost always 45.5-45.9.
I hang doors plumb and level.
Otherwise, your reveals are all pkukt up.
Get Off My Lawn.
"There are no big projects. There are only small machines". - R. G. LeTourneau
Old 05-13-2019, 09:04 AM
John the Builder
SmallTownGuy's Avatar
Rewards Points: 7,820
So, I watch the trim carpies on my jobs do pre-assemble.
Measure, cut, glue, stack. Go back, hang and roll up cords after.
Main floors, mostly have been 8 ft doors.
Anyway, point is, the assemblies all fit. No problem getting an even reveal, or tight joints to the frame/wall.
IMO - ALL methods are good. Sticking to a method and practice seems to help.
SmallTownGuy is online now
Old 05-13-2019, 09:35 AM
Tom M's Avatar
Rewards Points: 3,476
Where is all of this pre asemble being clamped and stacked without opening legs? Stood up with collins type of claps?
Tom M is offline
Joasis (06-09-2019)
Old 05-13-2019, 05:35 PM
Artist and not a curator
Deckhead's Avatar
Trade: Carpentry,
Rewards Points: 13,770
Near the cut station I would always have a sheet of mdf on horses. I build, assemble, clamp and stack on the sheet of mdf. Do that till lunch, eat lunch and then hang it all.
Works well for me and I know no matter what all mites are staying closed.
The reason I hate split jambs is I never build anything but solid core doors. I do not trust casing to hold a 120 lbs door even if it's only for a minute. Not to mention nailing behind the stop isn't an option. Even if I didn't build a lot of the doors I hang, i wouldn't use split jambs.
[signature removed by admin]
Deckhead is online now
The Following 2 Users Say Thank You to Deckhead For This Useful Post:
SmallTownGuy (05-13-2019), Tom M (05-13-2019)
Old 05-13-2019, 05:51 PM
Tom M's Avatar
I often set the heads then join the legs with a side nail and clamps with the bottom 6' unnailed for a while to set up
Tom M is offline
B.Johnson (05-22-2019)
Old 05-21-2019, 08:36 PM
hoser's Avatar
Trade: General, Finish Carpentry, Cabinet Builder
Rewards Points: 122
That means you have to have a square door slab, that seems to be hard to find nowadays lol.
hoser is offline
The Following User Says Thank You to hoser For This Useful Post:
Seven-Delta-FortyOne (05-21-2019)
Old 05-27-2019, 09:58 PM
Justin Huisenga's Avatar
Trade: Finish carpenter
Rewards Points: 1,736
I have preassembled casing many times and Ive gone back. But I do it when I can, usually on thin, narrow trim.
Pre-assemble 3/4 thick by 4 1/4 wide casing. Now lets say you have a door that you had to tweak in the opening to get it to hit the stop properly and its behind or in front of drywall an 1/8 at the head jamb, give or take, you will never get that casing tight to the jamb or drywall. You cant tweak it.
You can get it tight with a hooped set if the miter is biscuited and clamped the with the correct pressure. 1/8" is nothing. You can pull 1/4"-5/16" tight to the jamb and rock with a clamp without popping the miter. If I have rock proud of the jamb i cut it out with a small low RPM circular saw to leaving on about 1/4"-3/16" for the back edge of the casing to land on. I worked out a deal with the drywaller to not glue the rock to the king and jack so it just peels out once cut. Saw is faster and neater than tenderizing with a hammer. With the low rpm the dust just drops straight down.
For the guys talking about reveal blocks this is mine. Piece of 1/16" aluminum angle screwed to a piece of scrap with a light 1/4" reveal. The advantage over a rabbeted block is you can mark with the door closed and still hanging.
How do you trim an interior door-gb2.jpeg   How do you trim an interior door-gb1.jpeg
Justin Huisenga is offline
The Following 7 Users Say Thank You to Justin Huisenga For This Useful Post:
asevereid (05-28-2019), EricBrancard (06-03-2019), hdavis (06-02-2019), M.F Custom (06-01-2019), TheConstruct (Today), Tom M (05-30-2019), WildIris (06-18-2019)
Old 06-01-2019, 09:24 PM
Pro something
M.F Custom's Avatar
Trade: Construction
Rewards Points: 724
Great idea with the reveal block! I like my reveals a tad smaller 3/16" max...
M.F Custom is online now
Old 06-08-2019, 10:27 PM
Not a people person
Chris Doom's Avatar
Trade: Remodel/landscaping/irrigation
Rewards Points: 279
Funny how difficult the concept of plumb and level is to some people
Chris Doom is offline
Old 06-08-2019, 10:35 PM
Not a people person
Chris Doom's Avatar
Rewards Points: 279
If I hung the door then I know it's plumb and level, if not I check it first, then measure, mark for my reveal which I always eyeball unless there's some overriding reason I need to measure that out. Then measure my legs and cut them both at once on the chop, holding them back to back with the outside of the cases pressed against the fence and holding the two pieces horizontal, then I tack a couple of nails into the upper parts of the legs then measure and cut the top.
Old 06-10-2019, 04:30 PM
VinylHanger's Avatar
Rewards Points: 10,272
Originally Posted by Chris Doom View Post
If I hung the door then I know it's plumb and level, .
That's what I always say, but it isn't always the case.
VinylHanger is online now
Old 06-10-2019, 07:03 PM
JFM constr's Avatar
Trade: remodel,finish&trim
Rewards Points: 1,930
ditto .just saw one i did years ago .friggen reveal is off .did one leg grow ? how many times have i walked away thinking it was perfect only to return and find it off .
JFM constr is online now
Old 06-10-2019, 08:20 PM
Pro something
M.F Custom's Avatar
Trade: Construction
Rewards Points: 724
Damn little kids hanging off the door like it's a swing...
Old 06-10-2019, 11:45 PM
Not a people person
Chris Doom's Avatar
Rewards Points: 279
Plumb Gremlins
Old Today, 10:23 AM
don't be a crapenter.
5280carpenter's Avatar
Trade: Finish Carpentry / Cabinets
Rewards Points: 134
Mark reveals for the whole house, rough cut legs for the whole house, distribute them to each opening, mark in place and label, measure the heads and write them down, cut the whole house. If any doors are proud of drywall, I make a note of it and cut those miters compound by 1/2-1 degree (tilt and bevel). Preassemble with hi-pur or titebond and clam clamps. French door casings get stitched with short, wide crown staples from behind for added strength while I’m carrying it to the opening. Production speed and custom quality. If I have any gapping, the casing gets clamped to the jamb.
5280carpenter is online now
Old Today, 10:37 AM
TheConstruct's Avatar
Rewards Points: 1,008
I trim an interior door the same way I put on my pants. Left leg first, then right leg, head last.
I am bad at getting dressed.
TheConstruct is online now
The Following User Says Thank You to TheConstruct For This Useful Post:
hdavis (Today)
Thread Tools
Rate This Thread
Unusual trim style? Jonbuild Finish Carpentry 7 10-25-2016 01:53 PM
Looking for a fresh idea to trim out entry door AustinDB Finish Carpentry 17 02-01-2013 03:12 AM
how should I trim out the window siding?? lewisthepilgrim Windows, Siding and Doors 24 12-02-2012 11:46 AM
Paslode Angle Trim Nailer Problem. MF Custom Tools & Equipment 3 07-16-2012 10:19 PM
Proposals...... AAPaint Painting & Finish Work 3 08-25-2007 08:47 AM
