How Do You Trim An Interior Door - Finish Carpentry - Contractor Talk
Old 05-09-2019, 12:25 AM   #1
SSremodeler's Avatar
I do a lot of finish work and I end up trimming a bunch of doors. Same motion every time, mark top corner reveals, pin left leg to jamb right leg to jam, fit header in between, nail off. After 10 doors today I’m wondering how everyone else does it. I’m going to try hanging the header first next chance and see if I like it. Let me hear what you got.
SSremodeler is offline
Old 05-09-2019, 12:40 AM   #2
rondon's Avatar
Trade: carpenter
Rewards Points: 92
Re: How Do You Trim An Interior Door
if the casing isn't pre-built I have always found it easier to to the heads first, it is a lot easier to adjust the sides to the head instead of the other way around
rondon is offline
Old 05-09-2019, 05:39 AM   #3
B.Johnson's Avatar
Trade: Builder
Rewards Points: 2,402
Yep, heads first.
As a side note, if you had just posted "How to trim an interior door" without a description of how you do it; you would having gotten hazed.
Welcome to the forum.
Home Designer Series Software
B.Johnson is online now
The Following 2 Users Say Thank You to B.Johnson For This Useful Post:
greg24k (05-09-2019), KAP (05-21-2019)
Old 05-09-2019, 06:28 AM   #4
TimNJ's Avatar
Rewards Points: 4,288
Originally Posted by SSremodeler View Post
I do a lot of finish work and I end up trimming a bunch of doors. Same motion every time, mark top corner reveals, pin left leg to jamb right leg to jam, fit header in between, nail off. After 10 doors today Im wondering how everyone else does it. Im going to try hanging the header first next chance and see if I like it. Let me hear what you got.
I do it your original way. Sides then head.
TimNJ is online now
Old 05-09-2019, 06:51 AM   #5
MarkJames's Avatar
Trade: Handyman Services
Rewards Points: 12,823
How do you folks mark the casing for your cuts? Do you hold it up to your reveal point, mark it (pencil or utility knife), or just take a measurement and go cut some stock?
Do you assume it's always square to the opposing side (after eyeballing it), and just cut 45's?
MarkJames is online now
Old 05-09-2019, 07:25 AM   #6
nickko's Avatar
Trade: remodeling-cabinet maker
Rewards Points: 781
I go left to right. Left side first,then top, then right side. That lets me tweak the top left miter to get it perfect before i cut the top right miter. Then i will have about a four foot piece that i do a miter cut on until i get it to fit perfect and then i will cut the right piece to length with the miter on it that i made on my practice piece. If there is carpet going on the floor i will not use the four foot practice piece. I will cut the right side to the floor and get my miter perfect and then cut it to length.
Hope that makes sense.
nicko
"Quality work for those who know the difference"
nickko is online now
The Following User Says Thank You to nickko For This Useful Post:
MarkJames (05-09-2019)
Old 05-09-2019, 08:48 AM   #7
Goin' Down in Flames....
Seven-Delta-FortyOne's Avatar
Trade: Highwayman
Rewards Points: 1,910
If the floor isn't level, you have to do the head first, otherwise it'll come out all crooked.
Yeah, I do a lot of remodel.
Get Off My Lawn.
"There are no big projects. There are only small machines". - R. G. LeTourneau
Old 05-09-2019, 08:49 AM   #8
Trade: Highwayman
If you hung your door level, and your head casing is level, you should have a 45.
Get Off My Lawn.
The Following 2 Users Say Thank You to Seven-Delta-FortyOne For This Useful Post:
Golden view (05-09-2019), hdavis (05-09-2019)
Old 05-09-2019, 09:02 AM   #9
dave_dj1's Avatar
Trade: general contractor
Rewards Points: 1,008
I just did 59 windows, 7 exterior doors and 24 interior doors in a new construction, I always do the sides first and then the tops. Of course it helps that I hung the doors and windows One other thing, all of the windows had 4.5" sills and some were triples and doubles. All were cased with 3.5" pre primed colonial casing.
I make a square block out of 1x stock about 1.5" then rabbet all four sides to a quarter inch for my reveal, I find it easier than using my combination square. The last block I made lasted about 20 years and then suddenly disappeared.
dave_dj1 is offline
Old 05-09-2019, 09:22 AM   #10
MarkJames's Avatar
Genius!
Old 05-09-2019, 09:41 AM   #11
VinylHanger's Avatar
Rewards Points: 9,642
Head first, the the sides.
I just mark the reveals with my baby combo square or run it down the sides as I nail.
VinylHanger is offline
Old 05-09-2019, 11:12 AM   #12
hoser's Avatar
Trade: General, Finish Carpentry, Cabinet Builder
Rewards Points: 120
I also do heads first then the legs. It’s much easier to fit one miter than two, especially with large architectural moldings. And I don’t use a gauge block, just train your eye for whatever your intended reveal is, sometimes it’s 3/16”, sometimes it’s 1/4” depending on the design. But if you train your eye you won’t be wasting time marking jambs with a gauge block.
hoser is offline
Old 05-09-2019, 11:15 AM   #13
hoser's Avatar
Rewards Points: 120
I hang my doors plumb not level, but it is INCREDIBLY rare to cut all miters at 45 and expect them to fit perfectly. They are almost always 45.5-45.9.
hoser is offline
Old 05-09-2019, 11:57 AM   #14
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 3,716
No one pre-assembles?
Inner10 is offline
The Following 5 Users Say Thank You to Inner10 For This Useful Post:
Caleb1989 (05-10-2019), overanalyze (05-12-2019), pinwheel (05-12-2019), SmallTownGuy (05-09-2019), SouthonBeach (05-10-2019)
Old 05-09-2019, 12:01 PM   #15
hoser's Avatar
Rewards Points: 120
For me it’s pretty rare that I can pre-assemble casing. On 7/16” x 2 1/4” casing sure, it’s a great option because it will flex enough that you can get it tight to drywall and the jamb. But on 3/4” thick x 4-5” casing it’s usually not an option because you can’t get it tight to the jamb and drywall.
hoser is offline
Old 05-09-2019, 08:22 PM   #16
Stunt Carpenter's Avatar
Rewards Points: 1,616
I made a similar block. I think my first one ended up in the garbage cleaning up one day. Painted the second one yellow so its easier to not lose.
Stunt Carpenter is offline
Old 05-10-2019, 12:25 AM   #17
TheConstruct's Avatar
Rewards Points: 870
How do you do that? 45.9 cuts make a 91.8 angle. With the head jamb being level the bottom of the leg would be 2 1/2" out over 80". . If your jamb is plumb AND level 45 Will be perfect.
TheConstruct is offline
Old 05-10-2019, 06:20 AM   #18
MarkJames's Avatar
Seems like a good method.
Old 05-10-2019, 06:48 AM   #19
General Contractor
greg24k's Avatar
Rewards Points: 7,990
Did so many of them I don't even remember the pattern
But when doing a whole house, I would mark all the reveals (been using this Kreg's multi-purpose marking and measuring tool for years, the best thing when working with trim, highly recommend for the finish carpentry trade people)...
Mark all the legs and tack them on all doors but still allow play for adjustments...
Get top measurements from the top edges of all legs end to end and for the most part there is no need for another trip to the saw, except a few minor adjustments here and there... but you bang out the entire house fairly quickly and everything is nice and tight, glued miters, etc
greg24k is offline
MarkJames (05-10-2019)
Old 05-10-2019, 07:14 AM   #20
rrk's Avatar
Rewards Points: 1,360
that is at least 3 trips to the saw for each side of the door, way too many trips
rrk is online now
Unusual trim style? Jonbuild Finish Carpentry 7 10-25-2016 01:53 PM
Looking for a fresh idea to trim out entry door AustinDB Finish Carpentry 17 02-01-2013 03:12 AM
how should I trim out the window siding?? lewisthepilgrim Windows, Siding and Doors 24 12-02-2012 11:46 AM
Paslode Angle Trim Nailer Problem. MF Custom Tools & Equipment 3 07-16-2012 10:19 PM
Proposals...... AAPaint Painting & Finish Work 3 08-25-2007 08:47 AM
