How Do You Guys Fasten Your Faceframe Wall Angle Cabs? - Finish Carpentry - Contractor Talk
Old 11-29-2016, 01:16 PM   #1
saynever's Avatar
Trade: electrical
Rewards Points: 229
This will seem silly to veterans. I haven't hung any wall angle cabs up until this point.
When you have a 12" wall angle cab at the end of a run, there is only about 1/4" worth of meat in the face frame if installing the screw from the adjoining cabinet.
Do you just put filler in and screw the boxes together or do you run a 1 3/4" (1 1/2" face frames) and hope/pray?
saynever is offline
Old 11-29-2016, 01:25 PM   #2
Railman's Avatar
Trade: Railing
Rewards Points: 587
Re: How Do You Guys Fasten Your Faceframe Wall Angle Cabs?
Basically....
It's lay out for screw location ( watch out for interior steel brackets) in angle cab, drill outside to inside, install short screw from inside of angle cab to adjoining cab, or filler. If I remember right, about a 1 1/4 to 1 1/2 #6 dw screw worked well. Any bigger is overkill.
Railman is offline
Old 11-29-2016, 01:53 PM   #3
saynever's Avatar
Trade: electrical
Rewards Points: 229
Specifically these are 1/2 ply boxes dovetailed to the faceframes so no metal in the 45 degree joint.
I think I gotcha. Instead of running the screw through the adjoining cab stile I should predrill from the wall angle side and select a fastener that won't blow through the face of the adjoining stile.
Am I understanding correctly?
saynever is offline
Old 12-05-2016, 01:37 AM   #4
jhark123's Avatar
Trade: Pro Cat Herder
Rewards Points: 1,710
That's correct
jhark123 is offline
Old 12-05-2016, 07:41 PM   #5
B.Johnson's Avatar
Trade: Builder
Rewards Points: 2,652
I put the screw behind the frame of the straight cabinet and into the frame of the angled cabinet. You still need to watch your screw length.
B.Johnson is offline
Old 12-13-2016, 09:12 PM   #6
philcav7's Avatar
Trade: Residential Remodeling
Rewards Points: 1,185
I just did one this week. It seems ever time these are spec'd, they have no doors or glass doors. Fasteners are not pretty to look at so I always keep that in mind when securing cabinets
Most cabinets I work with have a ~3/16" reveal from the edge of the face frame to the side of the box. I fill this empty space with ripped down stock and secure the cabs together from the sides of the boxes, rather than the frames. If bows in the stud wall cause the front edge of the 45 to not mate up with frame beside it, I can play with the width of the stock between the cabs to line it up tight. I use short screws that don't penetrate though the finished interior. Typically use 3 screws right behind the face frame and 2 along the back.
It adds a little bit of time to the install, and is a detail that I look for when preparing the bid.
philcav7 is offline
Roof Framer's Bible Framing A Bay Window Roof sbebuilders Framing 25 06-28-2015 08:28 PM
Shaft Wall for Rowhouse raycgl Construction 7 07-21-2013 07:16 PM
What you guys rate this work? astor Tiling 46 06-11-2013 11:09 AM
Exterior wall covering options? bob_cntrctr Construction 8 02-25-2013 08:05 AM
A Job With A View Timuhler Framing 117 03-02-2011 09:30 PM
