How Can You Tell If A Level Is Level? - Page 2 - Finish Carpentry - Contractor Talk
Old 07-06-2010, 05:25 PM   #21
jjhomes's Avatar
Trade: Builder
Re: How Can You Tell If A Level Is Level?
Hold it up to the horizon.
I get a lot of guys with this one.
jjhomes is offline
Old 07-06-2010, 05:51 PM   #22
General Contractor
Willie T's Avatar
Location: St. Petersburg, FL Minds of moderate caliber ordinarily condemn everything which is beyond their range.
Rewards Points: 12
Originally Posted by 480sparky View Post
I generally spin it 180° and see if I have the same bubble.
I tend to do this all the time... on any reading. I guess it's just a habit I got into.
"True eloquence consists in saying all that is necessary, and only that which is."
François Duc de La Rochefoucauld
Bill Everett - St. Petersburg, FL
Willie T is offline
Old 07-06-2010, 05:51 PM   #23
jomama's Avatar
Trade: Concrete & masonry
Rewards Points: 170
Originally Posted by stuart45 View Post
I flip my level round all the time when building a lead, that way I can usually find one of the bubbles reading plumb.
LMAO, It's probably the "painted on" bubble that's reading plumb then......
As others have said, flip the thing around every way possible.
jomama is offline
Old 07-06-2010, 06:36 PM   #24
Pompass Ass
bwalley's Avatar
Rewards Points: 1,000
Originally Posted by Jordy3738 View Post
I recently was on a job where I was checking the soffit to install a long run of cabinets on. The soffit was one inch out of level in about ten feet.
When I mentioned it to the contractor, he was very upset, even to the point of threatening to fire someone.
He later told me that someones level was not right.
This brought me to wonder about mine.
"Have I been installing cupboards for the past five years uneven?"
So how can you test to see if your level is level?
How could him or his guys not see it was that far out of level?
I can look at steel framing in my commercial job and tell if it is 1/8" out in 10'.
bwalley is offline
Old 07-06-2010, 07:41 PM   #25
General Contractor
Willie T's Avatar
Rewards Points: 12
Maverick,
I'd say that is an inculcated skill that probably 90% of us just take for granted. But I know some pretty experienced contractors, as well as tradesmen, who honestly can't see those things without relying on mechanical aids. Strange, but true.
Willie T is offline
Old 07-06-2010, 07:43 PM   #26
keith mathewson's Avatar
Trade: carpenter
Rewards Points: 426
If you install a full kitchen worth of cabinets and only use a level, even if you checked it every hour, you may be surprised at the variations if checked against a laser.
keith mathewson is offline
Old 07-06-2010, 07:55 PM   #27
LRG WoodCrafting
Leo G's Avatar
Trade: Maker of Fine Sawdust
Rewards Points: 12,793
Who says your laser is level?
Sawdust Follows Me Everywhere
WWG1WGA
Carpenter by day.
Mad scientist by night.
http://lrgwood.com
Leo G is online now
Willie T (07-07-2010)
Old 07-06-2010, 07:57 PM   #28
Rewards Points: 2,000
Just look at how screwed up
those pyramids are.
If the poor bastards only had
lasers, they might have
got it right.....
neolitic is offline
Old 07-06-2010, 08:10 PM   #29
Cjeff's Avatar
Trade: Renovations
ALways check your levels, especially before you buy one.
I was in the store buying a cheap level for one time use as I was away from home and needed one and did not want to spend a lot. Grabbed one and checked it out using the flip it over method. Way out
Needless to say I bought a different one.
Cjeff is offline
Old 07-06-2010, 08:15 PM   #30
Handle It!
MALCO.New.York's Avatar
When near a Black Hole?
Ultimate Wisdom---------
MALCO.New.York is offline
Old 07-06-2010, 08:22 PM   #31
LRG WoodCrafting
Leo G's Avatar
A laser level is a delicate pc of electromechanical hardware. One good whack could make it a laser unlevel.
How do you check a laser level?
WWG1WGA
Carpenter by day.
http://lrgwood.com
Leo G is online now
Old 07-06-2010, 08:23 PM   #32
Trade: carpenter
Rewards Points: 426
those pyramids are.
got it right.....
If I remember correctly the pyramids are thought to have been built using a form of a water trough to establish level. A water level is very accurate but not a fast to use as a laser.
Old 07-06-2010, 08:24 PM   #33
Artisan Carpentry
basswood's Avatar
Trade: trim carpenter
Rewards Points: 1,030
Duh? See if it has the word "level" printed on the case!
basswood is offline
Old 07-06-2010, 08:30 PM   #34
KemoSabe
loneframer's Avatar
Rewards Points: 12,218
Ohhhhh, bass is in rare form this evening.
loneframer is offline
Old 07-06-2010, 08:34 PM   #35
Rustbucket's Avatar
Trade: Remodel/Deck
Rewards Points: 1,754
Pretty much the same way. In a rectangular room, place the level against one wall and project across to the other side. A horizontal line will project a ways up the side walls, so mark one spot on each of those walls. Move the level to the opposite wall, and again project back the the first wall you projected from. Your new line should project equal distance from the marks you made on each side. Or, you can adjust the height of the level to hit both of the original marks.
For a dot laser, place the laser in the middle of the room, mark the dots, and flip the level 180 degrees and see if both sides hit the same dots.
Hope all this makes sense. The ramblings in my mind seem a lot clearer than the ramblings I write.
Rustbucket is offline
Old 07-06-2010, 08:38 PM   #36
knucklehead's Avatar
Trade: Extraordinary Carpenter
Rewards Points: 2,728
I usually just stand back and look at it.
knucklehead is offline
Old 07-06-2010, 08:50 PM   #37
Artisan Carpentry
basswood's Avatar
Hey, believe it or not, I'm just drinking milk tonight.
Actually my Ex just hauled off her crap over the weekend and left... and I'm now over being pissed off (mostly)... in the "good riddance" phase now. Much mo bedda.
basswood is offline
The Following User Says Thank You to basswood For This Useful Post:
dkillianjr (07-06-2010)
Old 07-06-2010, 08:52 PM   #38
LRG WoodCrafting
Leo G's Avatar
OK, everyone ante up. We need to buy Bass a good time, lets call her Samantha.....
WWG1WGA
Carpenter by day.
http://lrgwood.com
Leo G is online now
Old 07-06-2010, 08:53 PM   #39
My mind sometimes has a mind of its own
Old 07-06-2010, 09:15 PM   #40
chief pencil holder
Scribbles's Avatar
Trade: Custom Cabinet Maker, Handrail
i got 23.50 to donate
Originally Posted by Greg Di View Post
Nothing you do as a professional should be for free. It's just a silly way of groveling for business if you think about it..
http://sacramentomillworks.com
Scribbles is offline
Taking business to next level SMA14 Business 7 05-07-2010 09:06 PM
Slope a deck or a level deck? wallmaxx Decks & Fencing 28 08-13-2009 12:36 AM
IS the ridge out of level? forsmant Framing 16 06-13-2009 10:12 AM
Entry level blower Philly Dude Insulation 6 03-21-2009 11:43 PM
Drywall Scratches - Level 5 Smoothwall HUNG BY FOOT Drywall 15 03-10-2009 05:19 AM
