Has Anyone Used Thermatru Fiberglass Exterior Doors? - Page 2 - Finish Carpentry - Contractor Talk
Old 05-09-2013, 10:07 PM   #21
Millar's Avatar
Trade: carpentry
Rewards Points: 85
Re: Has Anyone Used Thermatru Fiberglass Exterior Doors?
Have only installed two doors with pvc jambs , I found they needed to be shimmed more to staighten both the hinge and latch sides because the jamb seemed wavy . Not sure if any one else has noticed this .
Millar is offline
Old 02-02-2014, 03:54 AM   #22
CLong's Avatar
Trade: general contractor
Compliation of reviews from builders, designers, and homeowners. They seem well reviewed across the board for safety, energy efficiency, and appearance. Please share additional comments.
http://inbound.fiderio.com/blog/bid/...nd-Patio-Doors
CLong is offline
Old 02-02-2014, 11:51 AM   #23
VinylHanger's Avatar
Rewards Points: 12,872
I think you are right. I've only installed three myself, but I had to shim right behind the bottom hinges to lift it up. It just didn't want to sit right, even on a plumb hinge side.
VinylHanger is online now
Old 02-02-2014, 11:56 AM   #24
CITY DECKS INC's Avatar
Trade: DECK BUILDER. RESIDENTIAL. COMMERCIAL
Rewards Points: 4,608
There nice. We install30-40 per yr. Full fiberglass norot jambs argon low e glass. Oak threshold. I order them From lumber yard with all the bells and whistles. the jeld wen are the exact same thing. Again you have to be clear to get all the extras if not you might as well pick it off the rack at hd. I also installed a lot the full composit jams and pvc brick mold. Always get the PVC brick mold. If the jam is no rot I still grace tape bottom about4-6" the up the sides about6".
CITY DECKS INC is offline
Old 02-02-2014, 12:03 PM   #25
Originally Posted by NINZAN STUDIO View Post
For whatever reason, our supplier doesn't sell the PVC jambs.
They sell them. Just lazy sales rep. Call him and break his balls. I did till they got it right
Old 02-02-2014, 05:23 PM   #26
designer + carpenter
NINZAN STUDIO's Avatar
Trade: carpentry
Rewards Points: 510
They do come with first 4-6" made out of composite (PVC) material. It's pine from there up. I imagine a full PVC frame would run more money, probably why they push the pine frames.
NINZAN STUDIO is offline
Old 02-02-2014, 06:52 PM   #27
Waltwood's Avatar
Rewards Points: 171
Thanks for the responses but this is from June of last year!
Waltwood is offline
Installing grab bars in fiberglass tub shelf guy Kitchens & Baths 26 09-22-2015 01:42 AM
Fiberglass Pickup Caps RonMiller Contractor Swap 0 01-29-2013 01:46 PM
Fiberglass vs. aluminum clad ltlredwagon Windows, Siding and Doors 1 11-24-2009 09:55 PM
