Gluing Trim - Finish Carpentry - Contractor Talk
Gluing Trim
Old 06-03-2017, 08:06 PM   #1
Big Johnson's Avatar
Trade: Contractor Grunt
Rewards Points: 910
Gluing Trim
Do you guys glue and nail or just nail?
Big Johnson is online now
Old 06-03-2017, 08:26 PM   #2
Lettusbee's Avatar
Rewards Points: 1,228
Re: Gluing Trim
Are you referring to miter joints in casing? Or are you referring to gluing baseboard to the wall?
Lettusbee is online now
Old 06-03-2017, 08:27 PM   #3
tjbnwi's Avatar
Rewards Points: 1,848
Re: Gluing Trim
You'll need to expound on the question.
tjbnwi is online now
Old 06-03-2017, 09:21 PM   #4
Rewards Points: 910
Re: Gluing Trim
Glueing all surfaces. To walls, door/window jambs. mitres. Everything. Built up baseboards, 3 piece crowns.
Old 06-03-2017, 10:11 PM   #5
MarkJames's Avatar
Trade: Handyman Services
Rewards Points: 17,037
Re: Gluing Trim
outside corners & scarfs, yes.
MarkJames is offline
Old 06-03-2017, 11:51 PM   #6
hdavis's Avatar
Rewards Points: 2,370
Re: Gluing Trim
Glue joints, maybe.
Never glue or nail back band to the trim.
If it's nailed to the wall, it isn't glued.
hdavis is online now
Old 06-04-2017, 08:49 AM   #7
LRG WoodCrafting
Leo G's Avatar
Trade: Maker of Fine Sawdust
Rewards Points: 1,419
Re: Gluing Trim
All joints are glued. On occasion I glue to the wall due to irregularities or curved walls.
I have a pass through window frame that I did a cabinet grade paint job on. Since you can't repair the nail holes it will be glued to the wall. Stuff like that is rare, but happens.
Sawdust Follows Me Everywhere
WWG1WGA
Carpenter by day.
Mad scientist by night.
http://lrgwood.com
Leo G is online now
hdavis (06-04-2017)
Old 06-04-2017, 09:20 AM   #8
hdavis's Avatar
Re: Gluing Trim
One builder around here uses only glue for all stained trim. Finish off site, and then glue install.
Old 06-04-2017, 01:49 PM   #9
Want to play a game?
CrpntrFrk's Avatar
Trade: I do that too!
Rewards Points: 4,196
Re: Gluing Trim
Glue all joints especially miters.
https://youtu.be/aeaCjE2Y0ZQ
CrpntrFrk is offline
Old 06-04-2017, 02:47 PM   #10
CrpntrFrk's Avatar
Re: Gluing Trim
...and pin nail....
The Following User Says Thank You to CrpntrFrk For This Useful Post:
goneshootin88 (06-05-2017)
Old 06-05-2017, 01:18 AM   #11
hdavis's Avatar
Re: Gluing Trim
I don't glue coped joints. Butt and miter, yes.
Old 06-05-2017, 09:28 AM   #12
KAP's Avatar
Trade: Custom
Rewards Points: 36,964
Re: Gluing Trim
Technically, a coped joint is a butt joint...
Or maybe a new name... place and press joint...
KAP is offline
The Following User Says Thank You to KAP For This Useful Post:
hdavis (06-05-2017)
Old 06-05-2017, 09:55 AM   #13
hdavis's Avatar
Re: Gluing Trim
Technically, if the pieces aren't joined, it isn't a joint.
Old 06-05-2017, 11:15 AM   #14
KAP's Avatar
Trade: Custom
Re: Gluing Trim
Are you saying a coped joint or a butt joint aren't joints?...
Well I guess if your coped joints are held in place by nothing but pressure/friction that technically could be true but...
Joints are simply two pieces of wood. etc. attached to each other, using something outside the joint (i.e. - nails, screws, glue, biscuits, interlocking, etc. or a combination of those factors for reinforcement) for strength.
KAP is offline
Old 06-05-2017, 04:06 PM   #15
guidojoe's Avatar
Trade: Cabinet installer/ Finish carpenter
Rewards Points: 42
Re: Gluing Trim
i glue all my outside mitres and scarfs, copes no glue, but ill put a small bead of caulk in a cope if its paint grade. i use outside mitre clamps so i rarely pin my mitres, unless its a really chunky molding.
guidojoe is offline
Old 06-05-2017, 10:14 PM   #16
hdavis's Avatar
Re: Gluing Trim
I don't fasten copes or inside butts to each other at all. Just nail to the wall, and let it move some if it needs to.
Old 06-06-2017, 06:47 AM   #17
KAP's Avatar
Trade: Custom
Re: Gluing Trim
Uhm....
KAP is offline
Old 06-29-2017, 06:18 AM   #18
skill77's Avatar
Rewards Points: 72
Re: Gluing Trim
I glue base up when it passes over a pocket door or when a wall has a ton of plumbing or other things that dont get along with nails.
skill77 is offline
Old 06-29-2017, 04:44 PM   #19
tsbrewers's Avatar
Trade: Finish Carpentry
Rewards Points: 122
Re: Gluing Trim
Why are you mitering base molding like that? Also, seeing your thumb there while nailing made me cringe.
tsbrewers is offline
Old 06-29-2017, 05:38 PM   #20
gbruzze1's Avatar
Rewards Points: 2,608
Re: Gluing Trim
You guys usually glue one side or both? I've always glued both sides if for nothing else but to just seal both ends.
Sent from my iPad using Tapatalk
gbruzze1 is offline
Unusual trim style? Jonbuild Finish Carpentry 7 10-25-2016 01:53 PM
Looking for a fresh idea to trim out entry door AustinDB Finish Carpentry 17 02-01-2013 03:12 AM
how should I trim out the window siding?? lewisthepilgrim Windows, Siding and Doors 24 12-02-2012 11:46 AM
Paslode Angle Trim Nailer Problem. MF Custom Tools & Equipment 3 07-16-2012 10:19 PM
Proposals...... AAPaint Painting & Finish Work 3 08-25-2007 08:47 AM
