Formica Back Splash - Finish Carpentry - Contractor Talk
Formica Back Splash
Old 12-08-2009, 11:58 PM   #1
KennMacMoragh's Avatar
Trade: Repair/Remodel
Rewards Points: 3,364
Formica Back Splash
Does anyone know if there is a feasible way to build a kitchen counter back splash with Formica right against the wall with a small piece of trim covering the top edge of Formica and another piece of trim on the inside corner? This is how it was done on old houses, they would use a tiny piece of gold trim about 1/8" to 1/4" big. I looked everywhere for trim like this and the only thing I could find was a metal edge for tile, but not for Formica. Is this just an outdated technique? I went to Home Depot and they had a display set up with Formica wrapped around a 1 x 4 for the back splash. But is that the only way to do a Formica back splash now a days?
KennMacMoragh is offline
Old 12-09-2009, 12:14 AM   #2
Shawn Prentice's Avatar
Trade: carpenter/remodeler
Rewards Points: 250
Re: Formica Back Splash
I've bought it from my laminate supplier, not a box store, but the distributor. It's been 5 or 6 years, though.
Shawn Prentice is offline
Old 12-09-2009, 08:20 PM   #3
Still have all my fingers
Bergstrom's Avatar
Yes it is outdated but you came to the right place. Here is a link to purchase the edging but I warn you it is a little pricey and you can only get it in a stainless finish. http://retrorenovation.com/2008/05/0...te-countertop/
Killing the Earth, one raised panel at a time.......
http://bergstromcabinets.com
http://minneapoliscabinets.biz
http://maplegrovecabinets.com
Bergstrom is offline
Old 12-09-2009, 09:50 PM   #4
HitchC&L's Avatar
Trade: Construction
Rewards Points: 150
So you dont want a "full" formica backsplash, you want the top and edges covered in a molding?
They dont want formica on the entire thing?
HitchC&L is offline
Old 12-10-2009, 01:32 AM   #5
Kgmz's Avatar
What you are looking for is called aluminum cap and cove, available in natural and several anodized or other finishes.
Try who ever distributes Formica or Wilsonart up there, or a good flooring supply that deals in plastic laminates.
Also Wilsonart has a office/distibution point in Algona, basically a block south of the Supermall on SW 15th just off of 167.
400 Boundary Blvd
Algona, WA 98001
Tel: 253-872-8070
Fax: 253-872-8183
Products: Wilsonart Laminate, Wilsonart Adhesives, Wilsonart Custom Edge, Wilsonart Solid Surface, Wilsonart Sinks
And E.Roko is a authorized wholesale distributer for Formica in Kent
http://www.eroko.ca/locations_page.htm
Kgmz is offline
Old 12-10-2009, 01:47 AM   #6
Thanks for the replies, Hitch I will recommend doing a Formica wrap around a 1 x 4 for a back splash but I don't know if he's going to go for that. I need to redo a counter top over an old existing counter top which has the cap and cove detail already, guess that's what you call it. It seems like he wants the same detail but with everything new. So I want to price it out for him and give him the different options.
I will definitely look into those sources you guys posted.
Old 12-11-2009, 08:40 PM   #7
AustinDB's Avatar
Rewards Points: 1,434
I think the advent of the route/laminate trimmer overcame the need for the metal edging. I would recommend the standard backsplash b/c it's easier to clean and more likely to be sealed to the top for water tightness (silicon the adjoining edge).
AustinDB is offline
Old 11-12-2012, 09:04 PM   #8
slowsol's Avatar
Rewards Points: 2,248
Have bought it several times from a local laminate top maker. $14 for a 12' stick.
-John
slowsol is offline
I need A Chemical To Turn Patina Copper Back To Bright Penny Color Ed the Roofer Roofing 30 02-19-2010 10:04 PM
Are these back charges legit? Bsecdone Business 46 12-01-2009 01:52 AM
and yet, I can't wait to get back to work Mrmac204 Off Topic (Non Trade) 4 10-26-2009 10:13 PM
claiming money back at the end of the tax year.. frain21 General Discussion 5 04-09-2009 11:53 AM
