Fastening Rail To Newels - Finish Carpentry - Contractor Talk
Old 02-18-2012, 04:20 PM   #1
trim carpenter/remodeler
MKnAs Dad's Avatar
Trade: trim carpenter/remodeler
Rewards Points: 560
What are you guys usung instead of lag bolts? I have been using lags with1" caps to cover the hole I cut. Looking for something smaller hole wise. Any suggestions??
MKnAs Dad is offline
Old 02-19-2012, 01:17 PM   #2
irockwithdirt's Avatar
Trade: Carpentry, Remodeling
Rewards Points: 75
Re: Fastening Rail To Newels
Are you asking about railbolts? When running a line of rails between newels, opposed to cutting a slot on one end I sometimes countersink a 4" drywall screw above and below the railbolt for the next rail, all being covered when installed.
Are you just face bolting rails thru the newl?
irockwithdirt is offline
Old 02-19-2012, 01:28 PM   #3
Dave in Pa's Avatar
Trade: restoration/remodeling
Rewards Points: 1,272
I use for joining a rail to post a "tap-con" screw for concrete. It will fit into a 1/2" hole, doesn't strip out, and holds tight, won't break on you, then put a mushroom plug in to fill the hole.
And while on the subject of rails, what height have all been setting your rake rail to?
34" or 36" off the front edge of the nosing? What does code require? For a standard code, things appear to be differant.
Dave in Pa is offline
Old 02-19-2012, 01:39 PM   #4
Rewards Points: 75
Used to be 34 on the rake and 36 on the level residential and 36 and 42 commercial. This has changed alot of places. Best to call and ask.
Old 02-19-2012, 04:32 PM   #5
Ciaos mitigator
chris klee's Avatar
Rewards Points: 1,290
36" min on level runs, 34-38 on stairs from the front edge of the nosing. That's residential.
CK Carpentry
chris klee is offline
Old 02-19-2012, 07:31 PM   #6
Rewards Points: 75
It's been a few years since I worked for a stair company, but even then some places in the St Louis area were changing their codes on rail heights. Would be in red sharpie on the cover of the job sheet pack lol. I have no clue if this is nation wide.
Old 02-19-2012, 08:11 PM   #7
chief pencil holder
Scribbles's Avatar
Trade: Custom Cabinet Maker, Handrail
Rewards Points: 1,000
california chanded to 41" 2 years ago
Originally Posted by Greg Di View Post
Nothing you do as a professional should be for free. It's just a silly way of groveling for business if you think about it..
http://sacramentomillworks.com
Scribbles is offline
Old 02-19-2012, 08:11 PM   #8
chief pencil holder
Scribbles's Avatar
rake is still 34"-38"
Old 02-20-2012, 07:27 PM   #9
MKnAs Dad's Avatar
Rewards Points: 560
I had considered using 4" exterior grade screws. It would be for anywhere a lag or rail bolts would be used especially where rail meets newel on the rake.
Tapcons are a great idea. I assume you are using 1/4" by around 4"?
The rake is definitely 34-38". I thought for straight runs, it depended on how high up it was. For example, if it was saybetween kitchen and family room on different levels where there is only a few feet between them, it needewd to be somewhere like 36-40", but if it wason the second floor or higher, it had to be between 40-44" or something like that.
Old 02-20-2012, 10:12 PM   #10
chief pencil holder
Scribbles's Avatar
Originally Posted by MKnAs Dad View Post
Isomewhere like 36-40", it had to be between 40-44" or something like that.
This isn’t a hobby get a copy of the code book and figure it out in your county.
The Following User Says Thank You to Scribbles For This Useful Post:
RAbraker (02-20-2012)
Old 02-20-2012, 10:54 PM   #11
MKnAs Dad's Avatar
Rewards Points: 560
So because I am not positive what code dictates for something that does not pertain to what I am doing makes me a hobbiest????
Labor for cable rail installation Lewwax General Discussion 1 01-17-2012 06:34 PM
terminating chair rail woodworkbykirk Finish Carpentry 1 12-09-2010 09:26 PM
2x6 Rail Install basswood Finish Carpentry 30 11-30-2009 06:13 PM
Chunky Old "Beaded Bread Loaf" Rail basswood Finish Carpentry 18 08-16-2009 07:52 PM
