Ever Heard Of A Self Opening Pocket Door? - Page 2 - Finish Carpentry - Contractor Talk
Old 04-29-2015, 09:45 PM   #21
hdavis's Avatar
Rewards Points: 1,170
Re: Ever Heard Of A Self Opening Pocket Door?
Originally Posted by m1911 View Post
What, you nail a rubber band in there?
Magnets in the top of the door.
hdavis is online now
Old 05-01-2015, 04:34 PM   #22
Livin the dream...
Spencer's Avatar
Trade: Finish Carpentry
Rewards Points: 5,514
Originally Posted by EricBrancard View Post
I was just messing with you
not necessarily, a small amount of pitch will do it...
Originally Posted by Morning Wood View Post
If it is self opening does it have a catch or locking mechanism to keep it closed? I installed a pocket door on my own bathroom. It was johnson hardware. I set the header dead level. What I didn't check though was the track. We hung the door and if you close it, it will open back up a couple inches and stop. The f'ing track somehow wasn't parallel with the wood header. POS. whatever, it's a bathroom and will be locked by whoever is in there anyway.
Originally Posted by hdavis View Post
I get requests to install doors so they will either swing closed or swing open. Some people want interior doors to stay open unless they close them....
Here ya go. I have two doors like this. Upon further investigation the track is out of level 1/2" in 4'. How do framers even do that? oh wait....one word...amish.
https://www.youtube.com/watch?v=ZttW8Zsffn4
Spencer is offline
The Following 3 Users Say Thank You to Spencer For This Useful Post:
EricBrancard (05-01-2015), hdavis (05-01-2015), m1911 (05-01-2015)
Old 05-01-2015, 07:06 PM   #23
hdavis's Avatar
I have a plumber's level that has the required slope built into it - that'd do it
Old 05-01-2015, 11:04 PM   #24
House surgeon
illbuildit.dd's Avatar
Trade: building/remodeling
Rewards Points: 2,078
I remember seeing them on star trek.
illbuildit.dd is offline
Old 05-02-2015, 08:47 AM   #25
mgb's Avatar
Trade: Finishing Carpenter
Rewards Points: 1,120
Never seen that before. But I have cheated a few doors my unscrewing the track as much as possible from the opening. Then sliding some shims behind it to bring it down. Works well for adjusting out of plumb.
1/2" in 4' is really bad, and in a house that expensive I would want to do it right.
You might be able to use a magnet and remove the screws in the drywall and drive a shim under the plate.
mgb is offline
Old 05-02-2015, 03:39 PM   #26
Livin the dream...
Spencer's Avatar
I think I can get the track loose and add shims under it...or at least someone can do that. Hopefully not me.
Lewis Carpentry
Spencer is offline
Old 05-02-2015, 04:10 PM   #27
Joemack1's Avatar
Rewards Points: 382
What brand is the track?
Joemack1 is offline
Old 05-04-2015, 08:39 PM   #28
StrongTower's Avatar
Trade: Finish Carpenter
Rewards Points: 1,260
If you do another big house for this builder, always require that you set the pocket door frames. On the high end customs you really want to set your own. Thumbsup on shimming the track
StrongTower is offline
Old 05-04-2015, 08:46 PM   #29
JR Shepstone's Avatar
Rewards Points: 1,552
I've seen them in real life, with the "ppsssshhhhht" sound and all.
Only drink 23, that way they won't have a case against you.
JR Shepstone is offline
Old 05-04-2015, 09:01 PM   #30
House surgeon
Old 05-04-2015, 09:06 PM   #31
House surgeon
Idk why but that cracked me up
Old 05-05-2015, 05:00 AM   #32
Livin the dream...
Spencer's Avatar
How would you go about that in this case? These are 2x6 walls so no frame. The track gets screwed to the bottom of the header?
Lewis Carpentry
Spencer is offline
Old 05-05-2015, 08:12 AM   #33
RiverBG's Avatar
Trade: Home rehab specialist
Rewards Points: 764
I think he means hang the tracks yourself. Then you can be sure they are level.
RiverBG is offline
The Following User Says Thank You to RiverBG For This Useful Post:
Spencer (05-05-2015)
Old 05-05-2015, 09:34 AM   #34
Construct your own frame with engineered lumber. The guy I sub with that does all multi-million dollar work makes them out of engineered studs in the shop. Always a 2x6 wall.
The Following 2 Users Say Thank You to StrongTower For This Useful Post:
Justin Huisenga (05-05-2015), Spencer (05-05-2015)
Old 05-18-2015, 06:59 AM   #35
THe IRon Piņata
Gaboy's Avatar
Trade: Exterior/interior carpentry
Rewards Points: 840
Ghostrider pocket door track out of level 99.9% of time.
Gaboy is offline
Old 05-19-2015, 04:27 PM   #36
rob duke's Avatar
Trade: trim carpenter
Rewards Points: 110
1/2" over 4 ft is standard in Louisiana. I am always adjusting pocket doors and hate it. Sometimes I think the framers do it on purpose. Watched the video,and have seen many just like that.
rob duke is offline
The Following User Says Thank You to rob duke For This Useful Post:
Spencer (05-19-2015)
Preferred pocket door hardware Dan_Watson Carpentry 14 05-15-2014 07:32 AM
Install Pocket Door on Load Bearing Wall Waynel Remodeling 13 03-04-2014 09:36 AM
Pocket Door Installation abutting a Bathtub jps614 Kitchens & Baths 9 12-30-2010 05:17 PM
Pocket Door switches? sbcontracting Electrical 7 11-10-2010 11:44 PM
12' Door Opening NWBuilder Construction 11 08-24-2009 12:48 AM
