Drilling Marble Shower Walls? - Page 2 - Finish Carpentry - Contractor Talk
Old 01-22-2014, 12:42 AM   #21
m1911's Avatar
Trade: finish carpenter
Rewards Points: 15,632
Re: Drilling Marble Shower Walls?
Originally Posted by hdavis View Post
Matbe I do things backwards, but something like cultured marble I put in place and then drill it.
Kind of hard to do with the shower mixing valve sticking out the wall...
m1911 is offline
The Following User Says Thank You to m1911 For This Useful Post:
Willy1959 (01-22-2014)
Old 01-22-2014, 06:42 AM   #22
90%-er
onmywayup's Avatar
Rewards Points: 2,254
That's what I was thinking. Unless he treats like cutting drywall around a light box or something, but I don't see how that's practical with Marbelite
onmywayup is online now
Old 01-22-2014, 07:59 AM   #23
hdavis's Avatar
Rewards Points: 2,464
PEX lets you move all that out of the way. With copper you can do it if the inspector will do rough with it in place - the two plumbers I work with are OK with it.
hdavis is offline
nadodarkhorse (02-27-2014)
Old 01-26-2014, 11:04 PM   #24
KermieB's Avatar
Trade: Remodeler, Kitchen and Bath
Rewards Points: 331
I know I'm a little late to the party but I've had this and it's really easy. If you think about it, the hole for the valve doesn't have to be round. Most valve come with a throw away square plastic piece for the rough in. I stopped trying to make round cuts a long time ago. It's not necessary, so I use my Roto Zip with a diamond blade and make four nice neat cuts and move on.
KermieB is offline
Old 01-27-2014, 08:05 PM   #25
pappagor's Avatar
Trade: general contractor
Rewards Points: 32
one way is mark it out take it to a top shop have them drill it for you
pappagor is offline
Old 01-30-2014, 11:08 PM   #26
Builder, Remodeler
thill's Avatar
Trade: Builder, Remodeling Contractor
Rewards Points: 25
roto zip works great, and a regular carbide hole saw works great too.
I guess you found out the need to support the material the hard way.
Experience is NOT the best teacher, but you generally don't forget it when you learn the hard way!
-TH
thill is offline
Old 02-21-2014, 08:21 AM   #27
Willy1959's Avatar
Trade: Carpenter/contractor
Rewards Points: 109
Thanks all.
we set the marble on 1.5" foam, used a carbide hole saw as suggested for both cuts. used a little spray water as well. Worked GREAT. all installed and I am happy its over!
Willy1959 is offline
Old 02-21-2014, 05:14 PM   #28
goneelkn's Avatar
Trade: home remodel/repair
Rewards Points: 26
Congrats! How about some pictures??
Just did one today to.
goneelkn is offline
Old 02-23-2014, 08:54 PM   #29
Willy1959's Avatar
Rewards Points: 109
never really took a picture of the completed work, but here are a few in progress
Old 02-23-2014, 08:59 PM   #30
Willy1959's Avatar
Rewards Points: 109
the next panel was an accent panel with 2" x 2" groove patterns cut in it, about 12" high, and the final piece went to the ceiling. then there were 2 soap dish things in the corner. will see if I can remember to snap a pic of the completed job tomorrow.
Old 02-23-2014, 09:02 PM   #31
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 5,074
Shower valve holes can be cut with an angle grinder in seconds. Doesn't have to be a perfect circle.
Inner10 is offline
Old 02-23-2014, 09:05 PM   #32
Willy1959's Avatar
Rewards Points: 109
yes I know, I am just kinda anal about things like that
The Following User Says Thank You to Willy1959 For This Useful Post:
m1911 (02-23-2014)
Old 02-23-2014, 09:09 PM   #33
Inner10's Avatar
I hear ya, I'd rather just have a little more time at the bar that evening.
Inner10 is offline
Old 02-23-2014, 09:11 PM   #34
Willy1959's Avatar
Rewards Points: 109
The other room has a resistance pool in it, with an artificial cloud we made
Old 02-23-2014, 09:16 PM   #35
Inner10's Avatar
I put a sound system in a room with an "endless pool" last year, neat piece of equipment.
Inner10 is offline
Old 02-23-2014, 11:05 PM   #36
MTN REMODEL LLC's Avatar
Trade: Remodel and new build Colorado @ 7651 FT
Rewards Points: 1,428
I hear ya, I'd rather just have a little more time at the bar that morning.
fify
Never stop learning (xcep fer speling en typeing)
MTN REMODEL LLC is offline
What shelf pin drilling jig? NINZAN STUDIO Finish Carpentry 35 11-04-2016 06:18 PM
Custom shower base - granite Charles_cz Tiling 16 01-08-2015 09:34 PM
Marble Wall / Floor Grout Maintenance ? We Fix Houses Tiling 4 08-14-2012 12:00 PM
What is the max distance for load baring walls in a residence? kgcaddesign Architecture & Design 13 06-03-2012 02:35 PM
