Which Drawer Slides? - Finish Carpentry - Contractor Talk
Old 08-25-2020, 07:53 PM   #1
rrk's Avatar
Rewards Points: 6,008
I have to replace 2 sets of drawer slide in a pair of 48" wide drawers that have about 75lbs of cookware in each one. The existing slides are unbranded ball bearing slides integrated in metal drawer sides with a 1/2" drawer bottom. The existing ball bearing cages are torn apart and ball bearings are falling out.
Any ideas on which slides to use?
rrk is online now
Old 08-25-2020, 08:53 PM   #2
tjbnwi's Avatar
Rewards Points: 5,672
Re: Which Drawer Slides?
Get KV heavy duty side mounts. Trying to fit under mounts is probably not worth the effort.
Pictures of the drawer boxes top, bottom, side would help with suggestions.
tjbnwi is online now
pinwheel (08-26-2020)
Old 08-25-2020, 09:07 PM   #3
rrk's Avatar
I have to make them, the other slides were part of the metal drawer box side
rrk is online now
Old 08-25-2020, 09:24 PM   #4
tjbnwi's Avatar
Blum heavy duty under mounts with lateral stabilization system.
https://www.wwhardware.com/blum-tand...eral-stabilzer
I’d use the 563F. slides>>>see reply a few below.
rrk (08-26-2020)
Old 08-25-2020, 09:31 PM   #5
Aaron Berk2's Avatar
Trade: Trim Carpenter/Remodeler
Rewards Points: 270
Standard bottom mount Blum on 30 inch drawers all the time.
I've never done them on a 48.... go with what Tom said.
Face frame or frameless?
If it was a face frame I would also pad the sides with vertical blocking to help carry the weight.
Which Drawer Slides?-20200712_173030.jpg   Which Drawer Slides?-20200707_203114.jpg
Every thread deserves a photo
Aaron Berk2 is offline
Old 08-25-2020, 09:47 PM   #6
tjbnwi's Avatar
Just about every job we do has at least 2 48" drawers.
Old 08-25-2020, 09:54 PM   #7
tjbnwi's Avatar
If you're using 21" drawers, B569H5330B is the slide number you need.
BT51.1901 are the locking devices you need, add an L or R to get the lefts and rights.
rrk (08-26-2020)
Old 08-26-2020, 06:14 AM   #8
Box Builder
Morning Wood's Avatar
Rewards Points: 10,412
Another for Blum.
Morning Wood is offline
Old 08-26-2020, 06:37 AM   #9
rrk's Avatar
Frameless
rrk is online now
Old 08-26-2020, 06:41 AM   #10
rrk's Avatar
Id use the 563F. slides>>>see reply a few below.
Perfect
The lack of stabilization is what has destroyed these slides, the previous homeowners also must have pulled only on 1 side of the drawer also
rrk is online now
Old 08-26-2020, 05:21 PM   #11
tjbnwi's Avatar
These are 48" drawers. I see I have to adjust the right side before the Parade of Homes.
Theres about 100 pounds of pots and pans in each of these.
rrk (08-26-2020)
Old 08-26-2020, 05:32 PM   #12
tjbnwi's Avatar
Originally Posted by rrk View Post
Perfect
Every drawer box 36" or wider gets a stabilizer.
Old Yesterday, 10:40 AM   #13
alexk's Avatar
Rewards Points: 2
Undermount blum slide should do the job. https://www.rockler.com/blum-tandem-...ion-soft-close
alexk is offline
