Door Casing - Page 2 - Finish Carpentry - Contractor Talk
Door Casing
Old 09-28-2012, 11:44 PM   #21
mbryan's Avatar
Trade: water restoration
Rewards Points: 552
Re: Door Casing
Originally Posted by mrcharles
Cut you head nail it up. Cut the miter on each leg. Flip the legs and mark the cut off the bottom. Nail your miter tight. Then work the reveal down as you go. You can get all the flex you need out of the casing.
It is easy to have them both. Only very extreme cases does this not work.
Pretty much what I do. I like to glue the miters. Then like you nail it then tack to door with 18 to set reveal and then hit with a 16 to the stud. Also really helps to add a little but of back bevel to the miter. Can either swing the saw or just lift the edge of it.
Just love a nice tight miter!
mbryan is offline
Old 09-28-2012, 11:47 PM   #22
general b spec. framing
JSM_CC's Avatar
Trade: general b
Rewards Points: 250
Re: Door Casing
That's how I've always done it except adjusting the jamb. I usually have to bend the casing a bit and put extra nails in it so it doesn't spring back.
JSM_CC is offline
Old 09-28-2012, 11:50 PM   #23
JSM_CC's Avatar
Trade: general b
Rewards Points: 250
Re: Door Casing
Ya. He is mainly a rough carpenter. But he's an old timer who should know what he's doing. Maybe he's just getting lazy in his old age.
JSM_CC is offline
Old 09-28-2012, 11:58 PM   #24
Fire up the BBQ
griz's Avatar
Rewards Points: 394
Re: Door Casing
Never have quite understood what a "Rough Carpenter" is...
Careful with this old stuff...
griz is online now
Warren (09-29-2012)
Old 09-29-2012, 12:15 AM   #25
JSM_CC's Avatar
Trade: general b
Rewards Points: 250
Re: Door Casing
Ok. Let me rephrase. He's a silverback.
JSM_CC is offline
Old 09-29-2012, 08:02 AM   #26
KnottyWoodwork's Avatar
Trade: Trade work for money.
Rewards Points: 512
Re: Door Casing
I like a few different ways of hanging/trimming the doors, and switch it up every so often.
If the door is already hung I'll measure the angles while I do my cut list. Glue everything up on the table, then take the frames where they go.
If the cut man went production style and all I have to work with is 45* ends, i'll do it like charles and bryan. I'll set all the headers with glue, then come back and run the legs.
If I'm hanging, I'll make all my casings and pre-attach them to one side. Hang door, and attach other side of casing.
KnottyWoodwork is offline
The Following 2 Users Say Thank You to KnottyWoodwork For This Useful Post:
Gary H (10-03-2012), Tom Struble (09-29-2012)
Old 09-29-2012, 08:54 AM   #27
JSM_CC's Avatar
Trade: general b
Rewards Points: 250
Re: Door Casing
Doesn't that make it harder to put your shims in?
JSM_CC is offline
Old 09-29-2012, 08:57 AM   #28
Tom Struble's Avatar
Trade: siding
Rewards Points: 20
Re: Door Casing
pre-shim
Tom Struble is offline
The Following 2 Users Say Thank You to Tom Struble For This Useful Post:
hdavis (09-30-2012), KnottyWoodwork (09-29-2012)
Old 09-29-2012, 09:10 AM   #29
JSM_CC's Avatar
Trade: general b
Rewards Points: 250
Re: Door Casing
Id like to see some cumulative pictures of that process. I can't figure how you know in advance, where to place your shims. Most jambs I've had lately aren't the straightest. I generally use pre hung.
JSM_CC is offline
Old 09-29-2012, 09:17 AM   #30
Geometrist
Warren's Avatar
Trade: framing/remodeling
Rewards Points: 427
Re: Door Casing
I really dislike the notion that says somehow a finish carpenter is "superior" to a rough carpenter. I have seen many guys who do some great finish work really struggle with basic things on a rough site. To me, rough only refers to the fact that the job is still in it's rough or infancy stage. Finish just means that it is near the end or final stage. A hack is a hack no matter what stage he works in.
Easy Gibson
Warren is offline
The Following 4 Users Say Thank You to Warren For This Useful Post:
CENTERLINE MV (09-29-2012), joethepainter (12-30-2012), KnottyWoodwork (09-29-2012), moorewarner (11-09-2012)
Old 09-29-2012, 09:30 AM   #31
Joseph A. Capece
CENTERLINE MV's Avatar
Trade: Builder - General
Rewards Points: 1,432
Re: Door Casing
This is how I do it when I feel like doing so:
Throw a level on the hinge side; tack a shim either on the top or bottom of the jack (start with farthest side protruding into opening), plumb up and tack in shim so it's plumb. Holding your level between top and bottom shims, tack shim in middle (or wherever you want) so that they're all in a straight line. Easy peasy lemon squeezy.
Follow us on FACEBOOK
www.centerlinebuilders.net
Martha's Vineyard General Contractors - Builders -
Commercial/Residential - Additions - Renovations
CENTERLINE MV is offline
Old 09-29-2012, 09:33 AM   #32
JSM_CC's Avatar
Trade: general b
Rewards Points: 250
Re: Door Casing
Yes. That works on the hinge side. What about the latch side?
JSM_CC is offline
Old 09-29-2012, 09:39 AM   #33
Joseph A. Capece
Re: Door Casing
That's the side that the leg is left off of, so you can jam your shims through that opening.
Old 09-29-2012, 09:41 AM   #34
Finishing Carpenter
Mrmac204's Avatar
Trade: finishing Carpenter
Rewards Points: 720
Re: Door Casing
Ok, so get up on your ladder, and with your pencil make a little mark at the reveal (1/4? 3/16?) Then grab some casing, hold it in place and transfer your mark to the casing. Repeat for the other side.
Measure the inside of the jamb, and add for your reveals (for the header) IE: 32" inside, then add 1/2" (assuming a 1/4" reveal)
Cut your pieces on the saw at 45 deg.
Next using your Lee Valley super glue or Fast Cap 2p-10, glue up the casing on your bench (or floor) give it 60 seconds to set.
Take the whole thing, lean it up and start with the header as you can then see your reveal marks.
Work your way down each leg, bending the casing to the reveal. I use a little wood gadget that I made up to set the reveals. Its fast and accurate, the miters are dead tight, and the reveals are correct.
Sometimes you run into a door that's way out - no choice then but to measure the angle and cut appropriately on your saw.
It's more of an issue when the casing is 1x4 flat stock - that doesn't bend so well
What I've found more and more is that clients want a "craftsman" look, so no miters at all. The header extends past the legs 3/4" or so, and put a 15 deg. out angle on it. So easy it's scary.
Mrmac204 is offline
Old 09-29-2012, 09:44 AM   #35
Trade: siding
Rewards Points: 20
Re: Door Casing
i seen a guy that shims both sides before install on a fhb video so if your very careful i guess you can do it
Old 09-29-2012, 09:50 AM   #36
Rewards Points: 512
Re: Door Casing
Why do your shims have to protrude through both sides of the door casing? Just slide 'em through 'till they hit the backside of the installed casing.
The Following User Says Thank You to KnottyWoodwork For This Useful Post:
ROVACON (09-29-2012)
Old 09-29-2012, 10:11 AM   #37
JSM_CC's Avatar
Trade: general b
Rewards Points: 250
Re: Door Casing
Dunno. Just how I've always done it. But thanks for snapping me out of it.
I could definitely use some more fresh perspective in other things. I get so used to my routine methods.
I forget there's a thousand ways to skin a cat.
JSM_CC is offline
Old 09-29-2012, 10:58 AM   #38
topsail's trimcat
woodworkbykirk's Avatar
Rewards Points: 384
Re: Door Casing
.... ewwwww prehungs... had to hang two yesterday i forgot how bad they are.. been making my own jambs for some time now...
the ones i dealt with yesterday had hinges that didnt have the right bend in the leaf so i had to tweak that with a wrench.... plus the hing pin was loose in the hinges.. 1/16 + of wiggle when the pin is all the way down... it took me about 30% longer to hang the prehung and have it look like something than it took me to make my own jamb for a set of double doors then hang them
woodworkbykirk is offline
The Following User Says Thank You to woodworkbykirk For This Useful Post:
Old 09-29-2012, 11:03 AM   #39
JSM_CC's Avatar
Trade: general b
Rewards Points: 250
Re: Door Casing
Exactly
JSM_CC is offline
Old 09-29-2012, 11:09 AM   #40
Lazy Millennial
Youngin''s Avatar
Rewards Points: 506
Re: Door Casing
I was trying to hang a pre hung door yesterday. The jambs popped off the header with very little effort. It looks like whomever put it together had their compressor psi jacked so high that the staples over-penetrated and only had 1/8 of jamb material to grab onto. No glue either.
Originally Posted by mnld View Post
Home Depot... you can glue it, we can help!
Youngin' is offline
