Dealing Warped Door Slabs. - Finish Carpentry - Contractor Talk
Old 09-22-2020, 02:57 PM   #1
aaron_a's Avatar
Trade: Remodeling and fine carpentry
Rewards Points: 2,284
Any of you guys got any tips for dealing with warped slabs? Iíve been trimming out a house and a handful of door slabs have a bit of twist to them so they donít sit flush. The openings are are in plane, so itís not cross legged. Iíd hate to twist the jamb to fit the door and fight trimming it later. But the slab sitting 1/4Ē proud of the jamb isnít so hot either.
aaron_a is offline
Old 09-22-2020, 03:55 PM   #2
Fire up the BBQ
griz's Avatar
Rewards Points: 18
Re: Dealing Warped Door Slabs.
what kind of doors?
griz is online now
Old 09-22-2020, 04:38 PM   #3
We Fix Houses's Avatar
Trade: Remodeling / Carpentry
follow....
Steve
We Fix Houses is offline
Old 09-22-2020, 05:17 PM   #4
hdavis's Avatar
Rewards Points: 218
Steel, wood, fiberglass?
hdavis is offline
Old 09-22-2020, 05:35 PM   #5
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 12
I haven't dealt with it in new slabs, but have with a couple of transplanted antiques, with moderate success. It ain't quick or easy.
Strip the paint or whatever it's finished with. Wrap the slab in wet rags and plastic for a few days, to get the wood moisturized. Then mount it in the installed jambs. Rig up whatever you have to in order to twist the slab a good bit the opposite way of how it's warped, and keep it that way until the moisture level is equalized to the environment. The slower the drying process, the better the chances it will "take".
Just how much to torque it is a judgement call, and even with experience it's not likely to come out perfect.
With a new slab, I'd just replace it.
Tinstaafl is online now
Old 09-22-2020, 05:54 PM   #6
rblakes1's Avatar
Rewards Points: 16
I remember someone on here recommending ratchet straps on opposing corners
To get a bow out, I've put a door on horses and put some weight in the middle
-Rich
rblakes1 is offline
Old 09-22-2020, 06:12 PM   #7
hdavis's Avatar
Rewards Points: 218
1/4" I might sledge the bottom plate a little. When a flat slab comes along, it gets sledged back.
I wouldn't like doing that, though. Normally I'm sledging framing to get it to fit a flat slab without some funky trim.
hdavis is offline
Old 09-22-2020, 06:30 PM   #8
aaron_a's Avatar
1 3/8Ē knotty alder doors
aaron_a is offline
Old 09-22-2020, 06:47 PM   #9
Texas Wax's Avatar
Rewards Points: 2,286
You can 'Trig' the door so to speak. Slide the jamb head and legs in and out up to 1/8ish and make up 1/4" twist. But you have to roll cut the casing miters and all the crooked jiggy chit your avoiding.
Option B if door inst prefinished, extra labor - Pull the stop. Move hinges in to make up the difference and reset the stop to even things up on the latch side.
If you can get it close either way so the door touches the stop and requires a gentle tug to latch .... ""frequently"" the twist may straighten out some.
...as the page loads, so go the days of our lives, at CT
Texas Wax is offline
The Following User Says Thank You to Texas Wax For This Useful Post:
aaron_a (09-22-2020)
Old 09-22-2020, 06:48 PM   #10
aaron_a's Avatar
These doors are all pre finished. Seriously doubt the builder will spring for replacing them. Theyíre trying to hand over the keys next week as well.
aaron_a is offline
Old 09-22-2020, 06:50 PM   #11
aaron_a's Avatar
I havenít installed stops or hardware yet. The worst door is out 1/4Ē at the top and in 1/4Ē at the bottom. Maybe Iíll try moving the hinges.
aaron_a is offline
The Following User Says Thank You to aaron_a For This Useful Post:
Texas Wax (09-24-2020)
Old 09-22-2020, 06:51 PM   #12
Big Johnson's Avatar
Trade: Contractor Grunt
Rewards Points: 90
If they’re real bad all you can do is send them back.
Big Johnson is online now
hdavis (09-22-2020)
Old 09-22-2020, 06:55 PM   #13
nickko's Avatar
Trade: remodeling-cabinet maker
Rewards Points: 905
Whenever I order my interior doors from my local mill I get them without the stop installed. That way I can install the doors with screws behind where the stop will be. That lets me remove the screws to tweak the gap if needed. Also between cheating the jambs in and out and installing the stop after the door is hung I can usually overcome mildly twisted doors.
Nicko
"Quality work for those who know the difference"
nickko is online now
The Following User Says Thank You to nickko For This Useful Post:
Old 09-22-2020, 07:37 PM   #14
aaron_a's Avatar
Nicko
This builder is installing for gets them the same way, otherwise I remove them before I install. I was just trying to avoid cheating the jamb out too much. The trim is just a 1x4 leg with 5/4x6 head and it looks extra ****ty if it doesnít sit flat to the wall.
aaron_a is offline
Old 09-22-2020, 08:27 PM   #15
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 12
Pretty much par for the course, then. As much as it hurts, in the end the budget dictates what lengths you can go to, and sometimes you just have to schlock it. Sigh.
Old 09-22-2020, 08:43 PM   #16
rrk's Avatar
Rewards Points: 30
pulling a door straight can take a while, a finished door longer and it still may not twist back to straight since its sealed.
I have waited a month or two at times
rrk is online now
Old 09-22-2020, 11:05 PM   #17
hdavis's Avatar
Rewards Points: 218
I'm betting that's just how those doors are going to be.
hdavis is offline
aaron_a (09-23-2020)
Old 09-23-2020, 07:52 AM   #18
aaron_a's Avatar
Youíre probably right. Alder is twisty stuff, those door jambs were a real treat to work with.
aaron_a is offline
hdavis (09-23-2020)
Old 09-23-2020, 11:15 AM   #19
Artist and not a curator
Deckhead's Avatar
Trade: Carpentry,
Rewards Points: 200
Hinges and the stop. You wont be able to get a half inch though.
It is amazing to me how these large companies send out so many twisted doors. I mean, its like the main thing you cant have. They must store them in heat and humidity differentials because the lumber should be perfect coming over to assembly.
Impossible to read
Deckhead is online now
Old 09-24-2020, 04:28 PM   #20
aaron_a's Avatar
I know they at least sit in the garage for a couple weeks before I get there.
aaron_a is offline
